    Plugins Issue
    9 Posts 4 Posters 887 Views 4 Watching
      cameleyes
      Hi Guys,
      My HD failed. I've reinstalled Sketchup PRO 8.0.14345 (on a SSD if that makes any difference).
      Ever since then SUpodium doesn't show up although its clearly in the plugins folder. I've downloaded some more ruby script files and they don't show up in sketch up either.
      Any idea what could be causing this - I've reinstalled several times now. Driving me mad.
        What Plugins folder ?
        On a MAC it must the root Mac'HD one, and NOT the 'User' one ??
        Open your Window > Ruby Console and type [or copy/paste] this:
        Sketchup.find_support_file("Plugins")
        It should return the path to the Plugins folder.
        Also type in:
        $LOAD_PATH
        to see all of the paths to the folders it's using to auto-load from - it's typically the Plugins folder and the Tools folder [which is reserved for 'system' plugins]; if you are getting complex toolsets auto-loading then there might be additional folder paths adding by them too...
          cameleyes
          Hey,
          Thanks for your reply. Yes its a Mac and yes the plugins folder is the HD one.
          I don't use sketch up everyday - as and when in certain projects - however now reading what you've put I've noticed that I don't have a Ruby console under Window>Ruby Console
          Also type in:
          $LOAD_PATH
            cameleyes
            Here is a pic
              Apparently the 'Console' might appear under Tools on a MAC [OSX] and not under Windows as on a PC - perhaps my mistake ?
              However, if it's still not there... 😲 Here's one possible reason
              ...When I started SU on my Macbook, the expected "Ruby Console" menu item did not appear at all in the Tools menu.
              The problem is that the installed resources and ruby files have capitalization that is different from what the installed ruby scripts use.
              For example, sketchup.rb looks for "gettingstarted.strings", but units.rb (and others)
              look for "GettingStarted.strings".
              If you chose to install OS X as a "case-sensitive file-system", this won't work.
              A workaround is to patch up all of these ruby files to use the names with the correct capitalization.
              Change those and the Ruby Console will work again.
              Also see here http://productforums.google.com/forum/#!category-topic/sketchup/sketchup/mY_L8Xoe-Jk
              However, it's mad to use a case-sensitive file set up on a MAC - a PC expects 'file' OR 'File' to be the same file, if you set you MAC up the 'Unix' way you can have two files in the same folder named 'file' AND 'File' - confusion reigns...
              Do you get the 'Plugins' ['plugins'?] path with the code I posted ??
                mwm5053
                Ruby Console on Mac ( Lion ) under Window, or should be.
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                  cameleyes
                  Hey TIG,
                  Many thanks for your help - that was the issue - a case sensitive HD. Not sure why that happened but probably my fault.
                  Anyhow I've re-formatted drive and redistilled everything over the weekend and all working fine now.
                  Many thanks for your help.
                  Much appreciated.
                    cameleyes
                    Thanks for your input.
                    Ruby Console is showing up where you've mentioned now I resolved the other problem.
                    • jeff hammondJ Offline
                      jeff hammond
                      @cameleyes said:
                      Hey TIG,
                      Much appreciated.
                      ugh.. good thing you caught onto it now (the HD was still basically fresh).. but yeah, always use the default formatting options with OSX unless you deliberately want to (and know the reasoning behind) make a case sensitive drive..
                      dotdotdot
