    Concrete Skatepark
    16 Posts 6 Posters 1.7k Views 6 Watching
      racksat
      Hi! My name is Göran and im a 37 year old carpenter. I've been using Sketchup about 4 years for all kind of designs.
      I'm into skateboarding and so far I've built two skateparks and I used Sketchup to design one of them.
      The recent parks have been made of wood, but now I started designing on a concretepark, but I ran in to problems.
      In one section theres supposed to be three different bowls that are connected. (Check the attached file) I made it with one sidecut and depth, but i would like three different sizes. I guess I'll be needing some kind of plugin but I dont know were to start. Now when I've found this forum I hope someone know how to solve my problem!
      Thanks 😎
        No doubt than Jeff Hammond will be interested of that and will give you some cool advices
        You must edit your tittle post and put something like "Concretepark"
          racksat
          Wicked! I'll do that. Thanks
          • jeff hammondJ Offline
            jeff hammond
            hey goran.
            here's a little video showing an approach to making these kinds of blends.. i left some things out and went through is sort of quickly but i think it will get the idea across.. if you have any questions about the video, feel free to ask..
            [flash=853,480:483qcswa]http://www.youtube.com/v/N4Z89k3n7Xc?version=3&hl=en_US&rel=0"%20type=[/flash:483qcswa]
            http://www.youtube.com/watch?v=N4Z89k3n7Xc&feature=youtu.be&hd=1
            link to TIG's Extrude Edges suite which includes the lathe tool used in the video:
            http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            link to Fredo's CurviLoft tool:
            http://forums.sketchucation.com/viewtopic.php?t=28586
            dotdotdot
            • brookefoxB Offline
              brookefox
              That's nice, Jeff.
              Please add to your new Curvi-tut™ thread, alongside Charly's.
              ~ Brooke
                racksat
                Hi Jeff!
                Now were talking! Thanks man!
                  racksat
                  Hey Jeff!
                  I got really far, thanks to your tip, but when i loft a corner (or a hip) the outlines seem to end up in segments.
                  That gives me problem when im trying to select a curve. Do you know why?
                  /Göran
                    racksat
                    Hey!
                    Sitting here fooling around with some Skatepark, but having trouble, It seems that I just can select bits of an edge
                    Instead of the whole edge, do you have any ideas?
                    [/img][/img]
                    hey goran.
                    [flash=853,480:72d5lga1]http://www.youtube.com/v/N4Z89k3n7Xc?version=3&hl=en_US&rel=0"%20type=[/flash:72d5lga1]
                      Seems normal as it's a curvated surface!
                      All is segmented!
                        racksat
                        So its not possible to select the whole curve?
                        quote="Pilou"]Seems normal as it's a curvated surface!
                        All is segmented![/quote]
                          Depending how your project is made
                          Normally in view top
                          Double Click on the surface must select only the Surface + Perimeter
                          then Click again at the same place with Shift = you must have only the perimeter
                          You can post here your file skp (save as v6) for a more large audiance!
                          • gillesG Offline
                            gilles
                            Have a look there:
                            http://sketchucation.com/forums/viewtopic.php?p=324196%23p324196#p324196
                              racksat
                              @gilles said:
                              Have a look there:
                              Merci!
                              Thats what I needed!
                                racksat
                                Finally I finished something! 😮 Check it out and give me some feedback!
                                Thanks to everyone that helped me out.
                                Newbowl fini.skp
                                • Wo3DanW Offline
                                  Wo3Dan
                                  @racksat said:
                                  ... Check it out and give me some feedback!...
                                  Nice model!
                                  There are two lines (series of edges) that somehow appear to be profiles and that need to be fixed into (hidden) edges between face segments (so no thick profiles). They border the surfaces between flat highest floor level and curved surface towards the middle leveled bowl and further down, between this curved surface and the flat floor of the middle leveled bowl. (I hope the description is clear).
                                  I (for fun) ran a series of cross section animation "tests",(see*) eyeballing.....to see if the surface is smooth in "all" directions. This is crucial! But so far I couldn't find any alarming irregularity. The surface seems smooth. Good modeling. But now, how to get this skate parc built in real life! Lots of success!
                                  (*) Various scenes, each with its own active section cut.
                                  Scene transition enabled, set at 30 seconds
                                  No camera location saved per scene
                                  One active seltion plane (plane invisible but cut visible) per scene.
                                  "Section Cuts" with 4, in X direction saved red, in Y direction saved green.
                                  These are just some settings that I found helpful. (personal matter)
                                  You could also create a animation with a "rotating" section cut or section cuts whereever you like, just to check the smoothness and curvation of the surface.
                                    racksat
                                    @wo3dan said:
                                    Nice model!
                                    Thanks for input, found it!
