    Concrete Skatepark
    16 Posts 6 Posters 1.8k Views 6 Watching
    • jeff hammondJ Offline
      hey goran.
      here's a little video showing an approach to making these kinds of blends.. i left some things out and went through is sort of quickly but i think it will get the idea across.. if you have any questions about the video, feel free to ask..
      [flash=853,480:483qcswa]http://www.youtube.com/v/N4Z89k3n7Xc?version=3&hl=en_US&rel=0"%20type=[/flash:483qcswa]
      http://www.youtube.com/watch?v=N4Z89k3n7Xc&feature=youtu.be&hd=1
      link to TIG's Extrude Edges suite which includes the lathe tool used in the video:
      http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      link to Fredo's CurviLoft tool:
      http://forums.sketchucation.com/viewtopic.php?t=28586
      • brookefoxB Offline
        brookefox
        That's nice, Jeff.
        Please add to your new Curvi-tut™ thread, alongside Charly's.
        ~ Brooke
          racksat
          Hi Jeff!
          Now were talking! Thanks man!
            racksat
            Hey Jeff!
            I got really far, thanks to your tip, but when i loft a corner (or a hip) the outlines seem to end up in segments.
            That gives me problem when im trying to select a curve. Do you know why?
            /Göran
              racksat
              Hey!
              Sitting here fooling around with some Skatepark, but having trouble, It seems that I just can select bits of an edge
              Instead of the whole edge, do you have any ideas?
              [/img][/img]
              hey goran.
              [flash=853,480:72d5lga1]http://www.youtube.com/v/N4Z89k3n7Xc?version=3&hl=en_US&rel=0"%20type=[/flash:72d5lga1]
                Seems normal as it's a curvated surface!
                All is segmented!
                  racksat
                  So its not possible to select the whole curve?
                  quote="Pilou"]Seems normal as it's a curvated surface!
                  All is segmented![/quote]
                    Depending how your project is made
                    Normally in view top
                    Double Click on the surface must select only the Surface + Perimeter
                    then Click again at the same place with Shift = you must have only the perimeter
                    You can post here your file skp (save as v6) for a more large audiance!
                    • gillesG Offline
                      gilles
                      Have a look there:
                      http://sketchucation.com/forums/viewtopic.php?p=324196%23p324196#p324196
                        racksat
                        @gilles said:
                        Have a look there:
                        Merci!
                        Thats what I needed!
                          racksat
                          Finally I finished something! 😮 Check it out and give me some feedback!
                          Thanks to everyone that helped me out.
                          Newbowl fini.skp
                          • Wo3DanW Offline
                            Wo3Dan
                            @racksat said:
                            ... Check it out and give me some feedback!...
                            Nice model!
                            There are two lines (series of edges) that somehow appear to be profiles and that need to be fixed into (hidden) edges between face segments (so no thick profiles). They border the surfaces between flat highest floor level and curved surface towards the middle leveled bowl and further down, between this curved surface and the flat floor of the middle leveled bowl. (I hope the description is clear).
                            I (for fun) ran a series of cross section animation "tests",(see*) eyeballing.....to see if the surface is smooth in "all" directions. This is crucial! But so far I couldn't find any alarming irregularity. The surface seems smooth. Good modeling. But now, how to get this skate parc built in real life! Lots of success!
                            (*) Various scenes, each with its own active section cut.
                            Scene transition enabled, set at 30 seconds
                            No camera location saved per scene
                            One active seltion plane (plane invisible but cut visible) per scene.
                            "Section Cuts" with 4, in X direction saved red, in Y direction saved green.
                            These are just some settings that I found helpful. (personal matter)
                            You could also create a animation with a "rotating" section cut or section cuts whereever you like, just to check the smoothness and curvation of the surface.
                              racksat
                              @wo3dan said:
                              Nice model!
                              Thanks for input, found it!
