    DXF / DWG with text and linetypes in SketchUP !
    7 Posts 6 Posters 6.8k Views 6 Watching
    • beginnerB
      beginner
      Dear All,
      I was looking for some good solution to get DXF/DWG including text and line types into the SketchUP.
      And this is the result.
      http://www.lomal.co.uk/SU_Topo1.jpg
      http://www.lomal.co.uk/SU_Topo2.jpg
      Standard DXF/DWG Import done in SketchUP Pro
      http://www.lomal.co.uk/SU_Topo3.jpg
      http://www.lomal.co.uk/SU_Topo4.jpg
      Regards, SU 'beginner'
      • J
        jsl
        so, how was it done? ❓
        • S
          Sir
          Can you give us some more information please - is the imported drawing readable as seperate lines and text? or is it more of an image?
          How do you do it?
          etc etc
          • A
            ArCAD-UK
            How do you do it?
            etc etc
            If this is vector I'm very interested!
            • thomthomT
              This thread need more info. As it stands now it's doesn't really help much.
              • TIGT
                Looks like the text was exploded into lines that would then be importable [although the file size gets very big!].
                It's good idea to edit the CAD file to remove unwanted/unused detail that won't get imported [like hatching], then purge/audit before trying the import.
                If you save the DWG as a DXF [say r2004] then you can import that DXF's raw geometry [keeping the CAD origin], then use my 'importDXFtext' script to import the CAD text part only, it comes in as 'flat' 3d-text, using the equivalent size/font/style/location/layer/color etc wherever possible.
                The two imports should then overlay properly; so that then grouping them as one you can move them back to a sensible SKP origin...
                • beginnerB
                  beginner
                  TIG, I've managed to import my text using 'importDXFtext', but only once. I tried to import the text once again and it didn't work 😞 and I looked for other solution.
                  The problem with the text is that you don't have any common origin point between imported lines and imported text - sometimes it is crucial to have the same reference point to align drawings.
                  Dear All,
                  As TIG said it is a bunch of vectors – approx. 15,500 of them, but it works !
                  I don’t have enough time to do the ‘proper’ tutorial, but I have listed the software and steps taken.
                  You need the following:
                  • AutoCAD (LT is fine)
                  • PDF Creator
                  • Any PDF to DWG Converter
                  • SketchUP PRO
                  Step 1 – Open DWG, explode all objects, change all fonts to simplex.shx
                  Step 2 – Draw rectangle around the drawing – would be used to scale the drawing in SU
                  Step 3 – Print to PDF – I used PDF Creator
                  Step 4 – Save the drawing as exploded DWG – we will use the drawing as ‘Scale Reference’ in SU
                  Step 5 – Download ‘Any PDF to DWG Converter’
                  Step 6 – Open the PDF with 'Any PDF to DWG Converter', set in ‘Options - Centreline’ and ‘Convert Now’ – it could be converted to DWG or DXF – I used AutoCAD 13
                  • I didn’t manage to have the right scale but, the rectangle from Step 2 would come to the rescue later (see Step 10)
                  Step 7 – Open SU PRO, import ‘exploded DWG from Step 4’ and make group
                  Step 8 – Open 2nd session of SU PRO and import ‘converted DWG from Step 6’ and make group
                  Step 9 – You could copy one of the drawings (Select and Ctrl+C) and paste to the other (Ctrl+V)
                  Step 10 – Scale using ‘anchors’ – simply drag ‘edge to edge’ of previously drawn rectangle to match the converted drawing size
                  Regards
