    Webdialogs: inputbox shows black background (sketchup webkit
    50 Posts 22 Posters 36.6k Views 22 Watching
      TeamSDA
      Hi All,
      The fix Peter provided worked for the fields in my DC options window. But when I open my custom attributes window and look at the "Display Label" it is black as well. I couldn't find the style in the css style sheet that changed this input field. Does anyone know the style I need to change.
      Custom Attributes
      (On OSX 10.6.8 Snow Leopard, Sketchup 8.0.14345 Pro)
      Regards,
      Christian
        mwm5053
        @juantxo said:
        When I updated to Safari to 5.1.7 in Mac Leopard webdialogs boxes turn black in Sketchup.
        I've installed an older version of safari with pacifist and now it works again.
        http://www.charlessoft.com/ (pacifist software)
        http://mac.oldapps.com/safari.php (Safari 5.1.1 (Snow Leopard))
        Update If you find more black dialoge boxes blacked out like in profile builder or at 3d warehose this solution of Juantxo will work for all blacked
        out dialoge boxes follow instructions on this page to revert Safari back to 5.1.1 even though it's for a earlier ver.
        (appletoolbox.com)
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • jeff hammondJ Offline
          jeff hammond
          fwiw, i did the DC fix a while ago and yes, it works but as mentioned in this thread, it only works with the DC dialog.. skindigo was also exhibiting this blacked out behavior so i eventually downgraded safari using the method mentioned by Juantxo a few posts back.. pacifist with an older version of safari..
          and that fixes everything in sketchup instead of just the DC dialog.
          dotdotdot
            mwm5053
            I wonder if this has been reported to apple so the next Safari update will resolve this? BTW Still love my MAC
            2011 iMac
            V2 Twilight
              driven
              I'm using the developer release of Safari 6 and the problem remains in SU.
              Safari's User Agent Style Sheet, handles the input border correctly but SU doesn't use that, so it's a WebCore update that's needed. i'm looking for a patch at the moment.
              john
                mwm5053
                Thanks John I'd like to stay updated on this as I like to stay updated on all software.
                2011 iMac
                V2 Twilight
                • G Offline
                  gohch
                  Thanks guys!
                  I managed to get all the dialog boxes of 1001bit fixed following the suggestions on the css;
                  patch in html file to fix the black textbox
                  It's a lot of work to edit all the html files, but at least the problem is solved. 😄
                  Cheers!
                  • RichMorinR Offline
                    RichMorin
                    I grabbed a copy of Pacifist, but I can't find a copy of Safari 5.1.5 to install.
                    For example, the page http://support.apple.com/kb/DL1070
                    has a Download button that leads to http://www.apple.com/safari/download/.
                    However, this page only supports downloading of Safari 5.1.7.
                    Help?
                      troypiggo
                      I found it here:
                      http://mac.oldapps.com/safari.php?old_safari=813
                      This is not my signature. I type it at the end of every message for quality control.
                        driven
                        update to my investigation.
                        WebView uses a different version of Webkit than Safari (and not just in SU) and I can't find a way to change the userAgent from within SU, so been trying another approach.
                        dlg.execute_script %(function addGlobalStyle(css) {
                           var head, style;
                           head = document.getElementsByTagName('head')[0];
                           if (!head) { return; }
                           style = document.createElement('style');
                           style.type = 'text/css';
                           style.innerHTML = css;
                           head.appendChild(style);
                        addGlobalStyle('input {border; 1px solid gray;}'))
                        This works if you know the name of the dialog, but how can I get that with ruby to apply a global patch. Is it possible to get a new dialog name in ruby.
                        Using WebInspector to add the JS I can also exclude type with
                        addGlobalStyle('input, input;not[type="submit"];not[type="button"];not[type="file"];not[type="search"]{border; 1px solid gray;}'))
                        , but that returns true and fails in RubyConsole
                        john
                          @aerilius said:
                          UI::WebDialog.open
                          You mean UI::WebDialog.show ?
                            Aerilius
                            fixed it.
                              driven
                              @aerilius said:
                              fixed it.
                              hi, I'm getting
                              Error: #<SyntaxError: (eval):24: compile error (eval):15: parse error, unexpected '(' alias(:show_orig, :show) ^ (eval):20: both block arg and actual block given> (eval):24
                              I'd much rather use a small amount of ruby to 'fix' the input problem
                              cheers for your efforts
                              john
                              • Dan RathbunD Offline
                                Dan Rathbun
                                @Aerilius
                                It's much more complicated than that.
                                I have a patch that does similar.. (and more,) but we can't release such a thing without Boulder's blessing.
                                We have realized, that it's best not to show how to modify the API modules and classes. Some newbie's just run with it and start hacking away, and worse. (Yes we've all been guilty of openly discussing such things in the past. I'm sure I have. Sometimes we forget the "kids" come along and read what we've written later.)
                                Anyway... you don't need the literal block when you pass to the orig method, as the wrapper method has already converted any block argument to a Proc object.
                                So instead you do:
                                block_given? ? show_orig(&proc) : show_orig()
                                But it will not work like that, for the same reasons that the current API show(), show_modal() and set_on_close() block form methods do not work on Mac. (The webpage is never ready when Ruby executes the block.)
                                I'm not here much anymore.
                                  driven
                                  Improved my 'GreaseKit' UserScript using a file from Dan (cheers)
                                  with safari Css style on input borders
                                  // ==UserScript==
                                  // @name           inputPatch
                                  // @author	       driven
                                  // @namespace      http://drivenupthewall
                                  // @description    fixes webkit input boxes in SketchUp.
                                  // @include        *
                                  // ==/UserScript==
                                  (function() {
                                  	function main() {
                                  // ====== DO NOT TOUCH ANYTHING ABOVE =====
                                  // ===== PLACE CUSTOM CODE UNDER THIS LINE =====
                                  		function patchStyle(css) {
                                     var head, style;
                                  patchStyle('input;not([type=button]);not([type=file]);not([type=checkbox]);not([type=image]);not([type=radio]);not([type=reset]);not([type=search]);not([type=submit]){background-color; rgb(255, 255, 255); border-bottom-color; rgb(238, 238, 238); border-bottom-style; inset; border-bottom-width; 1px; border-collapse; separate; border-left-color; rgb(238, 238, 238); border-left-style; inset; border-left-width; 1px; border-right-color; rgb(238, 238, 238); border-right-style; inset; border-right-width; 1px; border-top-color; rgb(238, 238, 238); border-top-style; inset; border-top-width; 1px;}');
                                  // ===== KEEP CUSTOM CODE ABOVE THIS LINE =====
                                  // ===== DO NOT TOUCH ANYTHING BELOW =====
                                  	var script = document.createElement('script');
                                  	script.appendChild(document.createTextNode('('+ main + ') ();'));
                                  	(document.body || document.head || document.documentElement).appendChild(script);
                                  john
                                    driven
                                    working with Safari 6[dev] as main browser
                                    I added GreaseKit to SketchUp Menu and wrote a userScript to intercept ALL WebDialogs to add the patch.
                                    It only affects input[type=text] even when it's not been declared. (e.g. at 3D Warehouse site)
                                    Here are some instructions and my userScript if anyones interested.
                                    You need to instal SIMBL and GreaseKit in these locations
                                    /Library/Application\ Support/SIMBL
                                    %(#4040BF)[/Library/Application\ Support/SIMBL/Plugins/GreaseKit.bundle
                                    ~/Library/Application Support/GreaseKit/apps.plist
                                    ~/Library/Application Support/GreaseKit/config.xml]
                                    ~/Library/Application\ Support/GreaseKit/inputPatch.user.js
                                    Edit:SCRIPT REMOVED -better version below
                                    add SketchUp to greaseKit from Safari Menu, then in SU Reload All UserScripts and Select 'InputPatch'
                                    that's it
                                    john
                                      Aerilius
                                      You could carefully "alias" the WebDialog class in SketchUp, that means you add a script that is loaded first where you redefine the UI::WebDialog.open method so that it injects your JavaScript after the WebDialog has opened. Maybe like (untested):
                                      class UI;;WebDialog
                                        # this gives a new name to the method "show"
                                        alias ;show_orig ;show
                                        private ;show_orig
                                        def show(&proc)
                                          # this calls the original "show" method
                                          show_orig(&proc){ proc.call }
                                          execute_script(" /*your script*/ ")
                                      However re-defining base classes is something that no published plugin should do.
                                        troyhome
                                        @petersaal said:
                                        I found the same problem last week. The source of the problem is the Safari update that Apple pushed out last week (5.1.7). Here's a work-around for dynamic components: make the following edits in red to the manager.css and configurator.css files. (located in Library/Application Support/Google SketchUp 8/SketchUp/Tools/Dynamic Components/css)
                                        In Manager.css:
                                        .edit-field {
                                        position: absolute;
                                        border-top: 2px solid #3063C9;
                                        border-left: 2px solid #3063C9;
                                        border-right: 2px solid #A5C4FF;
                                        border-bottom: 2px solid #A5C4FF;
                                        background-color: white; font-size: 12px;
                                        font-family: sans-serif;
                                        width: 100%;
                                        height: 100%;
                                        overflow: hidden;
                                        padding-left: 2px;
                                        padding-top: 1px;
                                        border: 1px solid #000000;
                                        In Configurator.css:
                                        .config-field {
                                        width: 100%;
                                        font-size: 11px;
                                        font-family: tahoma, sans-serif;
                                        height: 22px;
                                        .config-field-readonly {
                                        width: 100%;
                                        font-size: 11px;
                                        height: 22px;
                                        background-color: threedface;
                                        Thank you!! this worked for me!!!
                                        IOviz.com
                                        SU Pro 2024 PC
                                          troyhome
                                          Thanks guys!
                                          [attachment=0:1pgsvrh4]<!-- ia0 -->black_textbox_patch.jpg<!-- ia0 -->[/attachment:1pgsvrh4]
                                          Cheers!
                                          what files exactly did you modify?
                                          IOviz.com
                                          SU Pro 2024 PC
                                          • P Offline
                                            phaseOne
                                            To avoid any confusion over installation of the script, I created this guide:
                                            1. Download SIMBL
                                            2. Unzip the file
                                            3. Launch the SIMBL-..*.pkg installer
                                            4. Download GreaseKit
                                            5. Mount the GreaseKit-..dmg image
                                            6. Copy GreaseKit.bundle to /Library/Application Support/SIMBL/Plugins/
                                            7. Launch Safari
                                            8. Select the GreaseKit item in the menubar
                                              http://grab.bovie.me/eUVw
                                            9. Select Manage Applications...
                                              http://grab.bovie.me/eUVy
                                            10. Add Sketchup to the application list
                                              http://grab.bovie.me/eUVI
                                            11. Quit Safari
                                            12. Download inputPatch.user.js created by driven (his original post)
                                            13. Copy inputPatch.user.js to **~/**Library/Application Support/GreaseKit/
                                            14. Launch SketchUp
                                            15. Select inputPatch from the GreaseKit menu
                                              http://grab.bovie.me/eUW4
                                            Your text boxes are now white!
                                            • 2 / 3
