    No idea for this animation (Mini challenge) ? :)
    14 Posts 4 Posters 971 Views 4 Watching
      I have yet 55 scenes of a Go Game (Goban) file linked
      Same size, same measure between each, each bases on the red axe
      How make for have exact surimposition of the gobans when the animation is launched ?
      Size wished at the screen is for example size of the number 48 of the scene 48
      for have each play of a "stone" (black & white) like an apparition ๐Ÿ˜„
      Make zoom / movement by hand for each Goban adjusment is some hard!
      No idea for the moment, i surely something missed! ๐Ÿ˜ณ
      Partie Gov601.skp
      • TIGT
        This should do it ?
        • TIGT
          Select a scene with the desired view.
          In the Scene Manager select all scenes [highlight first in the list, scroll to the end, hold shift-key and select the last one, they are all highlighted].
          The click the top left update button in the dialog only select to update the camera as I have shown and the camera is then common to all scene tabs...
          BUT now I see the issue - you have done this the hard way ! ๐Ÿ˜ฎ
          If you had placed the various versions of the board exactly one on top of the other, and used layers to control their visibility in each scene tab then it would be easy.
          As it is it you will give scene specific layers to each scene's board/pieces and then you need to relocate all of them over each other in the same view, so then the scene tab changes simply step through the visible layers one by one... ๐Ÿ˜’
            Hum hum
            That is not the case ๐Ÿ˜„
            I though at something like a "move camera" as a traveling as boards are "side by side"
            and wanted used that yet existing (if possible) ๐Ÿ˜„
            (copy the "position camera" of the scene 48 with changing Start End/ Position target to each scene but don't know if it's possible)
            • andybotA
              andybot
              could you place all the boards in the same location and then put them on different layers to turn them on and off per layer?
              • andybotA
                andybot
                ah, I see, you'd like a shortcut, wouldn't we all ๐Ÿ˜†
                I do wish SU had better camera tools, but then I wouldn't have any reason to learn Blender. ๐Ÿ˜‰
                  @ Andy
                  I want with the file positions given make the less actions possible
                  Use layers is a little nightmare (visibility) for one (unvisibilty for other ) etc... ๐Ÿ˜„
                  For the moment my method of camera seems the more easy against the layers method
                  need only one line copy move *55, 55 cameras built
                  If i could "Copy Move" a camera * 55 by scene that will be the ultima trick!
                    Seems each scene has this case yet enable or must I all disable ๐Ÿ˜ณ
                      I have find something ๐Ÿ˜‰
                      I draw a line who is the Start / End of the camera
                      Copy past this line to each board
                      and make for all scene a new camera Start / Target / Up Date Scene
                      At the end kill all lines
                      Easy & works fine
                      but 55 new cameras drawings! ๐Ÿ˜„
                      Height of the line = zoom
                      If line is centered = View top
                      Have you better with the file linked ?
                      • C
                        Charlie__V
                        @ Andy
                        Pilou,
                        Well you can copy a "camera" multiple times (advanced camera tools)but it will still leave a bit of work to do.
                        EDIT: You will need to set the first camera.....make cameras visible...then copy 54x.(oc/oc)
                        Rt click on camera....look thru camera.......Rt. click done......name & update scene....navigate to next camera...repeat.
                        FYI: I scaled the camera up 10x.
                        Charlie
                        Copy camera
                        • TIGT
                          RickW has a free tool to add scenes/view orthogonally offset in specified x/y/z directions - which would work if the boards are equally spaced ???
                          See http://www.smustard.com/script/AddPages
                            Works fine but only with Inch ! ๐Ÿ˜‰
                            So Unity Inch Menu animations / Settings
                            Disable Transition and Delay Menu Animation / Settings
                            Kill all scenes
                            View top on first Goban
                            Create Scene (no need Update)
                            Call the Plug Menu View / Add Page Orthographically
                            Thx Rick WIlson! ๐Ÿ˜Ž
                            54 pages asked
                            X = length in Inch between middle's side of 2 gobans edges
                            y =0, Z = 0
                            When that is made : regulate delay and transition
                            Works like a charm and it's very easy and very speedy! ๐Ÿ‘
                            Many thanks TIG for the trick! And bravo Rick WIlson! ๐Ÿ˜Ž
                              @Charly
                              These advanced camera tools are not just inside the V8 ?
                              @ Tig Just read your post !
                              That is the case! ๐Ÿ˜‰
                              I will see that! ๐Ÿ˜‰
                                Here the result ๐Ÿ˜‰
                                A little Offset image 24 (test file) ๐Ÿ˜‰
                                Perfection is not existing in this word ๐Ÿ˜„
                                Ps For the theorie of the Go Game ๐Ÿ˜„
                                I you look the Scene 55 : Black seems to win : 17 to 13 so 4 points
                                But no possibility to make equality at this diabolic game! ๐Ÿ’š
                                Fact to play first (Black)gives you 4.5 points' advantage!
                                So Black is losting by 0.5 point! ๐Ÿค“
                                Partie Go.skp
