    Mini-challenge
    328 Posts 26 Posters 39.8k Views 26 Watching
    • andybotA Offline
      andybot
      Jason, I think the issue is that you are manually placing an inference where it doesn't exist in SU. Like thomthom says, that can lead to inaccuracy down the road.
      • jason_marantoJ Offline
        jason_maranto
        I got it as close the the guideline as I can (with the tolerance of the rotate tool maxed out) and then adjust using the VCB to fine tune (if needed)... I'm not very experienced with advanced math (calc and trig) so I try to keep it simple.
        I'm sure there is some math that could explain why this works and how to setup the construction point absolutely perfectly without rotating it into place -- but I'm far to math illiterate to figure that out.
        But like I say, all the dimensions in the file I just posted are completely accurate as far as SketchUp can measure -- there's no flaw that SketchUp can find (it doesn't mean one doesn't exist).
        Also for clarity, this is just my version of the same technique somebody else posted here earlier -- It's not my solution, just one that seems to work really well.
        Best,
        Jason.
        • andybotA Offline
          andybot
          Well, I meant was that there are lots of ways to approximate the result, but only a few ways to use internal SU inferencing to get there. Oh well, no use arguing over a thousandths of a degree is there... β˜€
          edit: sure there is! πŸ’š
            jason_maranto
            Absolutely -- I don't disagree, I'm waiting for somebody to give the math to make it predictable/easy... also really, open the file, there's no error you can find in SketchUp.
            We are talking rhetorical "issues" at this point because I've posted a file with no errors.
            Best,
            Jason.
              jason_maranto
              I'd just negative invert copy and connect the top and bottom middles... but I'm sure there is a better way to do it.
              I like puzzles πŸ˜„
              Best,
              Jason.
              • jeff hammondJ Offline
                jeff hammond
                Best,
                Jason.
                close.. no cigar πŸ˜‰
                re: the math.. i've shown one approach in the DC.. there are about 50 ways i can think of doing the math but they all involve trig to find the angle of the hypotenuse then subtracting the angle of the board's hypotenuse to arrive at the final rotation angle..
                dotdotdot
                  jason_maranto
                  I get 10 even -- I think you may have mis-measured.
                  I'm not talking about the angle -- you don't need any math for that at all, what you need to know is how long the board should be.
                  Best,
                  Jason.
                    jeff hammond
                    Yes, but I am getting down into 1000ths of a degree on that rotation --
                    a 100% solution is necessary to relax the πŸ€“ in some people..
                    an example of a much easier challenge would be this:
                    there's a pure geometrical approach to finding the solution.. and finding these can actually be geeky fun instead of 'i need to build this' (or whatever)..
                    so with the challenge i've presented, sketchup has a speed bump in that we need to find this without using the rotate tool in the way we think we should be able to.. (a similar situation would occur with the example in this post if we didn't have midpoint snaps… we'd have to find another way and in that particular scenario, there is another way to do it without using a mid snap)
                    dotdotdot
                      jeff hammond
                      Best,
                      Jason.
                      i upped the precision to another decimal..
                      re: your edit.. right.. knowing the length would solve it too.. (which encompasses a few of the 50 approaches i mentioned πŸ˜‰ ) but to get that length, you'll still need to use trig (and angles) albeit they may be 'behind the scenes' the dc i made arrives at a final rotation angle.. but i could switch it up to where it gives the board length.. the same underlying maths are still in action..
                      but again, i'm trying to stress finding a geometrical approach.. one that can be done within sketchup itself.. i already have a trig solution and i use it but i'm still not 100% convinced that i'm missing a key element which makes this possible with sketchup tools and no guess work..
                      dotdotdot
                        jeff hammond
                        Best,
                        Jason.
                        I've got mine maxed out too -- maybe SketchUp is converting something upon opening the file?
                        [attachment=0:p19ezxh7]<!-- ia0 -->challenge_altfinameasurel.jpg<!-- ia0 -->[/attachment:p19ezxh7]
                        Best,
                        Jason.
                        delete the post.. i think you're measuring to the top of the post instead of the top of the diagonal board.. it's all so very close together in there that the inference gets confused..
                        dotdotdot
                          jason_maranto
                          Best,
                          Jason.
                          I'll tell you what would make it possible to do with just the tools (no math at all), would be if the construction point would snap to the guideline as I rotate it.
                          Best,
                          Jason.
                            jason_maranto
                            Yep, that found it -- crap... that's some serious precision. Any math would have to calculate down to those many decimal places to match it... and even then it may not be right.
                            Best,
                            Jason.
                            • andybotA Offline
                              andybot
                              @pbacot said:
                              all these methods are the same. You are either rotating a guide point or the board, to an insecure target along a line.... It is just that missing "projected arc intersection" function.
                              Which TIG's tool neatly restores β˜€
                              • pbacotP Offline
                                Jason,
                                How do you know the 1000th of degrees and upping the precision to another decimal etc.? What do you mean?
                                Peter
                                  jason_maranto
                                  Under Window> Model Info> Units you can set the precision of SketchUp (to its limits) -- generally I never get this precise because it's not practical for what I do, but it is there if you want it.
                                  Best,
                                  Jason.
                                    jeff hammond
                                    @pbacot said:
                                    all these methods are the same. You are either rotating a guide point or the board, to an insecure target along a line. SU should rotate using the projected arc intersection and that would be no issue for SU? I assume the rotate arc IS on a true curve. It is just that missing "projected arc intersection" function. In my CAD program (which does have arcs of course) a downfall is inability of lines and arcs to find (snap) that projected intersection point without using a trim tool. SU does line completion correctly why not rotation.
                                    It should be part of the SU inference tools (and toggling OFF the inference tools should also be a part! 😑 )
                                    right. I think the devs could make sketchup inferencing work the way we're expecting it to without changing the essence of sketchup.. a 'smart rotate' tool might be able to be created via ruby but for all I know, a ruby coder may end up facing the same brick wall?
                                    dotdotdot
                                    • pbacotP Offline
                                      all these methods are the same. You are either rotating a guide point or the board, to an unsecured target along a line. SU should rotate using the projected arc intersection and that would be no issue for SU? I assume the rotate arc IS on a true curve. It is just that missing "projected arc intersection" function. In my CAD program (which does have arcs of course) a downfall is inability of lines and arcs to find (snap) that projected intersection point without using a trim tool. SU does line completion correctly why not rotation.
                                        Pilou
                                        If the 'cut' end of the rail has the same 'height' when it is flat as it does when it is angled, then the sloping rail has been distorted and it is no longer the same 'width' [i.e. the square/vertical dimension] as it was before it was rotated...
                                          When testing I recommend you put the posts further apart as with near square shape deviances might be so small that you think you have a correct solution.
                                          I don't understand why you don't receive my test? 😲
                                          All seems perfect! πŸ˜„
                                          Where is the glitch ? (I am in decimal with maximum precision alowed by SU )
                                          test_jeff.skp
                                            i'm not quite sure they could give us true arcs in sketchup without entirely changing the way sketchup works.. (how would a cylinder be drawn if there were no segments in the arcs? a nurbs surface? )
                                            I do nor care for any "real" geometry. Let it me an approximated, segemented surface model.
                                            What should be here is circular guides. To let us do geometry we learnt in secondary/high school at our teen ages... That's not much but fairly enough.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 16
                                            • 17
                                            • 7 / 17
