    Mini-challenge
    328 Posts 26 Posters 74.1k Views 26 Watching
    • jason_marantoJ Offline
      jason_maranto
      I get 10 even -- I think you may have mis-measured.
      I'm not talking about the angle -- you don't need any math for that at all, what you need to know is how long the board should be.
      Best,
      Jason.
      • jeff hammondJ Offline
        @jason_maranto said:
        Yes, but I am getting down into 1000ths of a degree on that rotation --
        a 100% solution is necessary to relax the πŸ€“ in some people..
        an example of a much easier challenge would be this:
        there's a pure geometrical approach to finding the solution.. and finding these can actually be geeky fun instead of 'i need to build this' (or whatever)..
        so with the challenge i've presented, sketchup has a speed bump in that we need to find this without using the rotate tool in the way we think we should be able to.. (a similar situation would occur with the example in this post if we didn't have midpoint snaps… we'd have to find another way and in that particular scenario, there is another way to do it without using a mid snap)
          Best,
          Jason.
          i upped the precision to another decimal..
          re: your edit.. right.. knowing the length would solve it too.. (which encompasses a few of the 50 approaches i mentioned πŸ˜‰ ) but to get that length, you'll still need to use trig (and angles) albeit they may be 'behind the scenes' the dc i made arrives at a final rotation angle.. but i could switch it up to where it gives the board length.. the same underlying maths are still in action..
          but again, i'm trying to stress finding a geometrical approach.. one that can be done within sketchup itself.. i already have a trig solution and i use it but i'm still not 100% convinced that i'm missing a key element which makes this possible with sketchup tools and no guess work..
            Best,
            Jason.
            I've got mine maxed out too -- maybe SketchUp is converting something upon opening the file?
            [attachment=0:p19ezxh7]<!-- ia0 -->challenge_altfinameasurel.jpg<!-- ia0 -->[/attachment:p19ezxh7]
            Best,
            Jason.
            delete the post.. i think you're measuring to the top of the post instead of the top of the diagonal board.. it's all so very close together in there that the inference gets confused..
              jason_maranto
              Best,
              Jason.
              I'll tell you what would make it possible to do with just the tools (no math at all), would be if the construction point would snap to the guideline as I rotate it.
              Best,
              Jason.
                jason_maranto
                Yep, that found it -- crap... that's some serious precision. Any math would have to calculate down to those many decimal places to match it... and even then it may not be right.
                Best,
                Jason.
                • andybotA Offline
                  andybot
                  @pbacot said:
                  all these methods are the same. You are either rotating a guide point or the board, to an insecure target along a line.... It is just that missing "projected arc intersection" function.
                  Which TIG's tool neatly restores β˜€
                  • pbacotP Offline
                    Jason,
                    How do you know the 1000th of degrees and upping the precision to another decimal etc.? What do you mean?
                    Peter
                      jason_maranto
                      Under Window> Model Info> Units you can set the precision of SketchUp (to its limits) -- generally I never get this precise because it's not practical for what I do, but it is there if you want it.
                      Best,
                      Jason.
                        @pbacot said:
                        all these methods are the same. You are either rotating a guide point or the board, to an insecure target along a line. SU should rotate using the projected arc intersection and that would be no issue for SU? I assume the rotate arc IS on a true curve. It is just that missing "projected arc intersection" function. In my CAD program (which does have arcs of course) a downfall is inability of lines and arcs to find (snap) that projected intersection point without using a trim tool. SU does line completion correctly why not rotation.
                        It should be part of the SU inference tools (and toggling OFF the inference tools should also be a part! 😑 )
                        right. I think the devs could make sketchup inferencing work the way we're expecting it to without changing the essence of sketchup.. a 'smart rotate' tool might be able to be created via ruby but for all I know, a ruby coder may end up facing the same brick wall?
                        • pbacotP Offline
                          all these methods are the same. You are either rotating a guide point or the board, to an unsecured target along a line. SU should rotate using the projected arc intersection and that would be no issue for SU? I assume the rotate arc IS on a true curve. It is just that missing "projected arc intersection" function. In my CAD program (which does have arcs of course) a downfall is inability of lines and arcs to find (snap) that projected intersection point without using a trim tool. SU does line completion correctly why not rotation.
                            Pilou
                            If the 'cut' end of the rail has the same 'height' when it is flat as it does when it is angled, then the sloping rail has been distorted and it is no longer the same 'width' [i.e. the square/vertical dimension] as it was before it was rotated...
                              When testing I recommend you put the posts further apart as with near square shape deviances might be so small that you think you have a correct solution.
                              I don't understand why you don't receive my test? 😲
                              All seems perfect! πŸ˜„
                              Where is the glitch ? (I am in decimal with maximum precision alowed by SU )
                              test_jeff.skp
                                i'm not quite sure they could give us true arcs in sketchup without entirely changing the way sketchup works.. (how would a cylinder be drawn if there were no segments in the arcs? a nurbs surface? )
                                I do nor care for any "real" geometry. Let it me an approximated, segemented surface model.
                                What should be here is circular guides. To let us do geometry we learnt in secondary/high school at our teen ages... That's not much but fairly enough.
                                  My Tangent Tools fill the gap [for now] and allow you to find the real intersection points of tangents to arcs, lines and arcs, arcs and arcs etc etc...
                                  They are not new πŸ˜•
                                    [attachment=0:1h4o0r1i]<!-- ia0 -->test_jeff.jpg<!-- ia0 -->[/attachment:1h4o0r1i]
                                    I think presenting the problem in 3D could of been confusing. the direction youre measuring 5 in this latest image is insignificant.. try drawing the 2D version (posted on pg 2 or so)
                                      Aaaaaaaaaaaaahhhhh πŸ˜„
                                      Call me Fredo! πŸ˜† πŸ˜† πŸ˜† I was suffering from hallucinations! 😳
                                        I just avoid to test the height result! πŸ˜’ πŸ˜’ πŸ˜’ A sort of rotating geometric mirage! πŸ˜„
                                        2.670000 against 2.470811m 😳
                                        • gillesG Offline
                                          gilles
                                          I'm back!
                                          Mini-challenge2v6.skp
                                            yeah, true tangents seems to be the only viable ruby solution at this time.
                                            is it possible to make it more interactive? to where it basically acts like the standard rotate tool but it will snap to an arbitrary point along a line segment? or is something like that impossible to code with the current API?
                                            • 16
                                            • 17
                                            • 7 / 17
