    Multiple Holes
    14 Posts 8 Posters 2.3k Views 8 Watching
    • K
      kalli
      I need to cut a great many holes in a flat surface approx 1/8 thick.
      Is there a way to do this in one shot - "subtract" wants each hole cut individually.
      We'll be doing this over and over for mulitple render models.
      Any suggestions?
      Kalli
      Multiple Holes.skp
        Is it pegboard? Why not use a material instead of all those real holes?
        • jeff hammondJ
          jeff hammond
          work on a single plane instead of a solid.
          array the circles as you like on the plane.
          select the surface
          copy/move it to another location (or select it, clipboard, delete everything, paste in place)
          push/pull to required thickness.
          dotdotdot
            If you really must have holes, here's an alternative to Jeff's method. See the attached SKP file. I made three separate components, a corner, an edge and a central section. These are then arrayed to get the required sheet size. Since I used components instead of groups, the three sections can be saved and reused any time you need a sheet with holes in it.
            Multiple Holes.skp
            • GaieusG
              Another approach is to make a combined component (of two children), array that and at the end, select all instances and explode. There sre two examples that work this way here
              http://sketchup.google.com/3dwarehouse/details?mid=19117ee553b17296419a54028b473680
              and here
              http://sketchup.google.com/3dwarehouse/details?mid=dafc9e4c19c92809649d9dccc59cec7
              • TIGT
                Copy 'holes' is quite possible...
                  Doh of the day! we can make "12" or "12" in the VCB after the first copy move ! 😲 β˜€
                    Or "x12" or "12x" if you wish. πŸ˜‰
                      SUPER DOH 😲 😲 😎
                      • K
                        kalli
                        Thanks guys for all the input. Logical answers I didn't see the other day. Perhaps just staring at the darn thing (and way too many hours at the computer).
                        As a colleague of mine often states : "the blindingly obvious."
                        I really do appreciate all the input.
                        kalli
                        • Jean LemireJ
                          Jean Lemire
                          Hi folks.
                          A while ago, I have made a tutorial about making such a model real quick. You can find it here:
                          http://sketchup.google.com/3dwarehouse/details?mid=21769e98f6c04b1612cfb0c58382469f
                          The principle applies to punching multiple holes having different shapes in one operation.
                          The steps are:
                          1 - Draw the object in 2D, ie, the plate and the holes figured out by circles, polygons, shapes, whatever.
                          2 - Select all. This select the plate and all the shapes figuring out the holes.
                          3 - Press and hold the SHIFT key down to Add/Subtract from the selection.
                          4 - While still holding down the SHIFT key, double click on the area between the shapes. This deselects it as well as all its perimeter which is the plate perimeter and all the shapes perimeters. Only the insides of all the shapes are still selected.
                          5 - Delete the selection. This empties all the holes in one shot.
                          6 - Now, using the Push/Pull Tool, give thickness to the plate.
                          Just ideas.
                          • oganocaliO
                            oganocali
                            Just a warning here, SketchUp does not like faces with too many sides (internal and/or external).
                              Why not and what should be the acceptable numbers ? 65 535 as the 3DS format?
                              • oganocaliO
                                oganocali
                                I am not sure why sketchup does not like faces with too many sides. Modifications on such a face takes forever. A single face with 65K edges is on the too much side. You can always add redundant softened planar edges to divide the whole face to faces with each one having manageable number of faces.
