    Filling a Space with Components.
    21 Posts 6 Posters 1.8k Views 6 Watching
    • david_hD Offline
      david_h
      Here's one for the gurus. . .
      Im drawing a Lottery ball pin and want to fill it with ping pong balls, but I am not sure how to fill the bin with the balls in a random like way. I am not good with Compo Spray. But that is the first thing I thought of to use, and I am just not good with it. It kept asking me if I wanted to go ahead and add 8000 copies. . ..
      uh. . .NO.
      I need about 50 or so inside the bin. as you can see I am trying to find an easy way to give this a random look. Right now I just have them all lined up. dumb.
      See image below. Any ideas?
      thx,
      David
        I'm not really up on Sketchy Physics but I wonder if it might be the way to go. Could you put a temporary opening on the top of the basket and set the balls up to drop into it when you say, "Go?"
        • david_hD Offline
          david_h
          That would be terrific except for one little hiccup. I havent even looked at SuPhy in about 4 years. I wouldnt know how to begin.
          thanks for the thought tho.
          D
            Sorry I can't tell you where to begin either. You might pose your question on the Sketchy Physics forum, though. One of those rocket scientists will probably have the answer for you.
            • david_hD Offline
              david_h
              good point, and therefore I shall do just that.
              Thx
              D
              ps if anyone else has any thoughts on this. . please chime in
              D
                https://sites.google.com/site/sketchyphysicstutorial/basics
                • david_hD Offline
                  david_h
                  Hey Hey! Thanks Rich. I'll check this out.
                  D
                  • F Offline
                    fransko
                    look like this?
                    Lotto machine.skp
                    • david_hD Offline
                      david_h
                      Not exactly . . .but thanks for the effort / response.
                      I think my image above was misleading. What I need is to show this bin (Image A) filled with ping pong balls like image B. I am just not sure how to make this happen in a fairly natural random way. . .
                      Image AImage B
                        Did Sketchy Physics not work for this?
                          A few years back I did something similar with spray cans dropping out of a box.
                          It works fine if you use the earlier link as a base. I'd try again except I don't have it installed.
                          • david_hD Offline
                            david_h
                            I guess I didn't understand that the attached model was a SUPhys model. I guess I am going to have to learn it in order to do what I need to do.
                            Thanks for the help.
                            D
                              You can use that πŸ˜‰ (file linked)
                              Take any number of Spheres you want (groups or components) at any place above the SkateRamp πŸ˜‰
                              Launch Sketchyphysics
                              Make a Pause at any time you want
                              Open the Outliner
                              Select Spheres inside the Oultliner else the animation go to the start!!!
                              Copy / Past balls in your project πŸ˜‰
                              During the animation you can take and move any ball !
                              If you want another curvated form blocks : just make 2 separated blocks A & B! (groups or components)
                              StaticMesh / Convexhull
                              Have fun πŸ˜‰
                              PS And if you want more sophisticated balls with Number : use the very tricky
                              Relplace random Component by Sdmitch πŸ˜‰
                              balls.skp
                                I have replaced the file on the previous post πŸ˜‰
                                Groups are now components so you can remplace them at the end by anything you want πŸ˜„
                                Yes you must install SketchyPhysics else nothing will arrive πŸ˜‰
                                Even you don't know Sketchyphysics : You have no more to make
                                Just Press Start and Pause and re read the post above πŸ˜„
                                • david_hD Offline
                                  david_h
                                  Merci Mon ami. Je vais le faire!
                                  David
                                  • david_hD Offline
                                    david_h
                                    so I downloaded the latest and greatest of SP3 and on the start up I get this. . .
                                    and when I press the Play button I get this. . .
                                    any thoughts?
                                      Ah damned 😲
                                      I am affraid to say that I don't know why you have this sort of thing πŸ˜•
                                      Try to install a previous versions of Su
                                      That I shown was done with a recent version of Sketchyphysics on an old SU 7 version πŸ˜„
                                      Another thing : seems Sketchyphics makes some interference with some other plugs
                                      so disable it when you don't use!
                                      I just change the name of its extension ".rb" as ".rbo" in the plugin folder πŸ€“
                                      • david_hD Offline
                                        david_h
                                        I was afraid of that. I've only got 1400 Plugins that could be the problem. Should be no problem going through all of them. πŸ˜’
                                          Save somewhere the folder Plugins
                                          Create a new folder Plugins
                                          Install Sketchyphysics
                                          run it
                                          but from you error messages I doubt that will be sufficient πŸ˜‰
                                          • david_hD Offline
                                            david_h
                                            it usually never is-- πŸ’š
                                            when it comes to me, but I will give it a try.
                                            Thx,
                                            d
                                            • 1 / 2
