    Help! How to make a spiral like a paper?
    29 Posts 12 Posters 1.4k Views 12 Watching
      [off:25v2rhb7]Un chien mâle qui pisse, vu de derrière 😲[/off:25v2rhb7]
        Very conceptual avatar! 💚
        • brookefoxB Offline
          brookefox
          Thanks for learnin' me a little, after which, for me, extrude edges by rails works best, simply because I could not make the length of the helix and the diagonal to match so shape bender had an annoying error (the little projecting tab). How to make these equal? Note also the disagreement about the length of the scaled helix curve info=112', label=245'. I assume the scaling threw a wrench in the works?
          ~ Brooke
          • gillesG Offline
            gilles
            #1 draw the path ( helix )
            #2 select it, open entity info to get the length
            #3 draw the line the same length
            #4 draw the diagonal sheet the same length
            #5 draw the sheet with circle tool set to 4 segments ( if you want a square sheet )
            #6 erase the diagonal
            #7 group the sheet
            #8 run shape bender.....wait....
            #9 resize the model with tape tool. done
            it takes five minutes.
              brookefox
              Thanks for that.
              Sly:
              Perhaps that method it is more accurate than 'extrude edges by rails' even if a little slower.
              ~ Brooke
              • gillesG Offline
                gilles
                If your paper is square it's fast as you already have the diagonal.
                • mitcorbM Offline
                  mitcorb
                  Anybody tried Spirix on this? I am not sure if it can be applied here. Some more info, I think is in a thread back about 4months. As far as I know, the author doesn't post here.
                    brookefox
                    Heck, man. That thing looks real nifty.
                    spirixcode
                    The Chaos Trilogy: Better Life Through ACME Available in Kindle format and paperback from Amazon. Spirix Plugin for SketchUp (works with SketchUp 2015, 2016, and 2017) The Spirix Ruby plugin allows you to revolve or extrude any 3D sequence of edges (both open and closed loop) about or along the
                    (sites.google.com)
                    ~ Brooke
                      brookefox
                      I like your way because it has the rotated sheet (corner up). I cannot do it faster than EEbyR, though.
                      ~ Brooke
                      • 2 / 2
