    Cocoon facade structures....
    Scheduled Pinned Locked Moved Organic Modelling
    18 Posts 7 Posters 22.9k Views 7 Watching
    • pep75P
      pep75
      Cocoon-FS-2.jpgDear Sketch-Uppers,
      I'm Sketch-upping for quite some years now, and I'm using alot of plugins, but I found a shape in a magazine which I think, is hardly to model in SU. ❓ Offcourse, everthing can be modelled, but this one is, I think, a real pain in the....The "Cocoon" is designed by POHL architects and is build with all individual panels(groups/components). What I really really really like to know if there is a method or plugin that can handle/project, components to shapes so that you can maken these kind of shaped structures....Does anyone has a suggestion, is this possible with SU?
      Thanks!!!!
      Pep
      • numbthumbN
        numbthumb
        Maybe with Artisan-made components bent into the shape, and rotated arround in an array πŸ˜•
        Comfortably numb...
        • TIGT
          First make the 'onion form'.
          Un-smooth all geometry/
          Then divide it up into say 24 equal sectors, make a component of one and edit it to 'tessellate'.
          Divide the 5 main pieces of that component into separate tessellating sub-components.
          Now you do want you want with them... here I have used the LatticeMaker plugin on an explode mesh made from them to 'glaze' them - you could 'emboss the panels etc as needed - changing one component changes all to match...
          • pep75P
            pep75
            Haha nice work Tig!!! mmm okay that's a great suggestion, I've never tried LatticeMaker....And yes Numbthumb, it must be done with a little help of Artisan....But still it is a hell to model... 😲
              Maybe a precise drawing curves sections with the Extrude Edges by rail can make the trick for one module! πŸ˜‰
              • pep75P
                pep75
                ...πŸ˜„ We're coming close..but it still doesn't do the "trick"....It's hard.... πŸ‘Š
                  In fact maybe something something like Round corner (here just the front top face but it's the same for the internal face bottom ) + Shape Bender
                  • pep75P
                    pep75
                    In fact something like Round corner + Shape Bender
                    [attachment=0:1tc9u1l3]<!-- ia0 -->round.jpg<!-- ia0 -->[/attachment:1tc9u1l3]
                    πŸ‘ Hi Pilou...I tried this to, and that is still an option. Shapebender does the job, but it also changes the components to groups, so they all change(hard to explain but they're getting mixed up). What I tried is to bend it first in height and then to tue onion shape...but you must do this extremely precise...it doesn't work that well to come to workable output. 😞
                    • TIGT
                      Mine was a quick example.
                      Draw the profile of the 'onion-dome'.
                      Use EEbyLathe to make a 24 sided 360 degree mesh.
                      Un-smooth all edges.
                      Draw some diagonal lines to make interlocking [tessellating] forms.
                      How can you hope to bend individual parts that will then somehow magically join togethr ?
                      You must make them like that initially...
                      Make components/subcomponents of 1/24th.
                      Rotate+Ctrl to radial array it.
                      Add whatever details you want to modulate or emboss the components..
                      I only used 'Lattice Maker' because it was a fast way to show an effect...
                      The effort goes into the drawing of the interlocking forms of the surface of a larger mesh - knowing they will tessellate afterwards...
                      • DareDevilD
                        DareDevil
                        In fact something like Round corner + Shape bender
                        Yes, ShapeBender is a good way...
                        But, there are two things to model : the element and the cocoon.
                        I tried to model both together, but I think I need a super-computer to finish the work πŸ˜„
                        For the element, I use Subdivide and Smooth (now it's Artisan...)
                        For the cocoon, I used ShapeBender twice, first for the profile, after for the round shape.
                        • TIGT
                          Once you have one set of tessellating parts you can do anything you like to the insides...
                          Provided that the parts' edges remain unchanged they'll still interlock even if the 'embossing' is very organic...
                            Seems not πŸ˜‰
                            Shape Bender makes
                            Component --> Component
                            Group --> Component
                            And it's better if you want edit some component πŸ˜‰
                            • pep75P
                              pep75
                              Sorry I went to bed....But wow!! 😍 I think it's fixed...And yes, the segment that has to be repeated(the slice) must be perfect. And the you bend it twice with Shapebender. Last night I was thinking about a plugin that would be groundbreaking. Like Component sprayer, but then you fill or project "surfaces" with components so you can make complex structures with repetitive elements. As being an architect I always have to deal with the actual realization and these organic forms are hard to realize. But when you design repeating shapes it's another story. That's why I mentionned the fact the Shapebender adds line to the elements, that's okay to shape things but for realization it's hard to sell...
                              Nevertheless this method still makes it possible...the arc-element where you project the segment on must be segmented equally and then it should work!!
                              ...there's more in SU...pfveeewww!!!
                                SU is not first a sudivide modeler
                                Artisan makes that but it's like a perversion because Su is not first existing for manage such number of polygons!
                                Blender or such programm is more suit for that πŸ˜‰
                                • pep75P
                                  pep75
                                  Hi Pilou, you are totally right, I'm using Cinema4D besides SU, but I prefer to do everything in SU. SU is, in my opinion they best (and only) intuitive modelling/design tool...So as far I can create it with SU I prefer that! πŸ˜‰
                                    SU best (and only) intuitive modelling/design tool
                                    Yes for "box modeling" and Moi is the same for Nurbs modeling πŸ˜‰
                                    Try it, it's working very well (export Ngones) with C4D β˜€
                                    • A
                                      azmiafin
                                      damn, this who I looking for along time! thx alot master! πŸ˜„
                                      • P
                                        pinoy
                                        Have you try flowify plugin?
