    Cocoon facade structures....
    Scheduled Pinned Locked Moved Organic Modelling
    18 Posts 7 Posters 23.2k Views 7 Watching
    • pep75P
      pep75
      In fact something like Round corner + Shape Bender
      [attachment=0:1tc9u1l3]<!-- ia0 -->round.jpg<!-- ia0 -->[/attachment:1tc9u1l3]
      πŸ‘ Hi Pilou...I tried this to, and that is still an option. Shapebender does the job, but it also changes the components to groups, so they all change(hard to explain but they're getting mixed up). What I tried is to bend it first in height and then to tue onion shape...but you must do this extremely precise...it doesn't work that well to come to workable output. 😞
        Mine was a quick example.
        Draw the profile of the 'onion-dome'.
        Use EEbyLathe to make a 24 sided 360 degree mesh.
        Un-smooth all edges.
        Draw some diagonal lines to make interlocking [tessellating] forms.
        How can you hope to bend individual parts that will then somehow magically join togethr ?
        You must make them like that initially...
        Make components/subcomponents of 1/24th.
        Rotate+Ctrl to radial array it.
        Add whatever details you want to modulate or emboss the components..
        I only used 'Lattice Maker' because it was a fast way to show an effect...
        The effort goes into the drawing of the interlocking forms of the surface of a larger mesh - knowing they will tessellate afterwards...
        • DareDevilD
          DareDevil
          In fact something like Round corner + Shape bender
          Yes, ShapeBender is a good way...
          But, there are two things to model : the element and the cocoon.
          I tried to model both together, but I think I need a super-computer to finish the work πŸ˜„
          For the element, I use Subdivide and Smooth (now it's Artisan...)
          For the cocoon, I used ShapeBender twice, first for the profile, after for the round shape.
            Once you have one set of tessellating parts you can do anything you like to the insides...
            Provided that the parts' edges remain unchanged they'll still interlock even if the 'embossing' is very organic...
              Seems not πŸ˜‰
              Shape Bender makes
              Component --> Component
              Group --> Component
              And it's better if you want edit some component πŸ˜‰
              • pep75P
                pep75
                Sorry I went to bed....But wow!! 😍 I think it's fixed...And yes, the segment that has to be repeated(the slice) must be perfect. And the you bend it twice with Shapebender. Last night I was thinking about a plugin that would be groundbreaking. Like Component sprayer, but then you fill or project "surfaces" with components so you can make complex structures with repetitive elements. As being an architect I always have to deal with the actual realization and these organic forms are hard to realize. But when you design repeating shapes it's another story. That's why I mentionned the fact the Shapebender adds line to the elements, that's okay to shape things but for realization it's hard to sell...
                Nevertheless this method still makes it possible...the arc-element where you project the segment on must be segmented equally and then it should work!!
                ...there's more in SU...pfveeewww!!!
                  SU is not first a sudivide modeler
                  Artisan makes that but it's like a perversion because Su is not first existing for manage such number of polygons!
                  Blender or such programm is more suit for that πŸ˜‰
                  • pep75P
                    pep75
                    Hi Pilou, you are totally right, I'm using Cinema4D besides SU, but I prefer to do everything in SU. SU is, in my opinion they best (and only) intuitive modelling/design tool...So as far I can create it with SU I prefer that! πŸ˜‰
                      SU best (and only) intuitive modelling/design tool
                      Yes for "box modeling" and Moi is the same for Nurbs modeling πŸ˜‰
                      Try it, it's working very well (export Ngones) with C4D β˜€
                        azmiafin
                        damn, this who I looking for along time! thx alot master! πŸ˜„
                        • P
                          pinoy
                          Have you try flowify plugin?
