    Collapsing vertices or points as in Cinema4d
    3 Posts 3 Posters 948 Views 3 Watching
    • B
      bkjernisted
      Is it possible to collapse vertices or points in Sketchup as you can in Cinema4d.
      • TIGT
        If you mean flatten vertices to a plane, or combine vertices into one, then there are several scripts to do this...
        Search the 'Plugins Index'...
        • thomthomT
          Merge all selected vertices to a point?
          I added such a feature to Vertex Tools 1.1 which I will release soon. It also has a function to merge vertices within a given proximity of each other.
