    Image around cylinder
    19 Posts 8 Posters 844 Views 8 Watching
    • V Offline
      Vicspa
      Hello All,
      I need to know how to wrap an image around a cylinder,( see enclosed file) I tried projecting texture but it's
      not working too well, what is the best way to do this???
      jar2.skp
      • jeff hammondJ Offline
        jeff hammond
        a way to do it without a plugin:
        -edit the texture so it's width matches the circumference of the jar (in this case, it's ~12'- 1 5/16")
        -turn hidden edges on
        -use the paint tool to apply the texture to One of the facets of the cylinder
        -right click the painted facet then texture->position
        -align the texture to desired height as well as place the seam of the texture on the edge of the facet
        -using the paint tool, sample the facet then paint the next one (paint brush with the cmmd key samples on mac.. not sure about windows)
        -so on and so forth until you make it all the way around.. (in many cases, such as a cylinder, you won't have to keep sampling each successive facet.. just the first one then just paint around in order and everything will map properly)
        jarJH.skp
        dotdotdot
        • numbthumbN Offline
          numbthumb
          A quick tryout using Whaat´s UVTools 0.1 ("Cylindrical Map" option from the context menu)jar2UV.skp
          Comfortably numb...
          • V Offline
            Vicspa
            Thanks Jeff, still trying but not working out for me yet.
            • V Offline
              Vicspa
              Thanks Numbthumb, will try the UV tools.
              Do the plugins appear in the plugins menu as UV tools ???
                Jeff1s solution with another example (from the past):
                http://sketchup.google.com/3dwarehouse/details?mid=672e39e6eed2aab4f5e0eb0152f85f19&prevstart=0
                • BoxB Offline
                  One of the youtubes.
                    numbthumb
                    It will create a context menu called 'UVTools'
                    Comfortably numb...
                      Roger
                      Look at the bottom of the page at"
                      http://forums.sketchucation.com/viewtopic.php?f=81&t=26545&p=230303&hilit=Tigre#p230303
                      It shows a texture wrapped around the barrel of a cannon using the4 method described by Jeff Hammond.
                      http://www.azcreative.com
                      • V Offline
                        Vicspa
                        Thanks so much guys, 👍 👍 👍 I will look into and try all you have said.
                        • V Offline
                          Vicspa
                          Numbthumb, sorry to be a pain in the A@#, but I still cannot find it in the plugins folder.
                            numbthumb
                            No hassle 😄
                            You should find it in the context menu, not in the plugins folder.
                            Comfortably numb...
                            • V Offline
                              Vicspa
                              thanks again Numbthumb, I'm going to be 65 this year, and I'm amazed how many "senior Moments" I'm having. 😲
                              Thanks again to everyone, see you on the next senior moment. 🎉 🎉 🎉
                                Roger
                                Shh!, I'm 67.
                                • V Offline
                                  Vicspa
                                  Shhhhhhhhh!!!!!
                                  • mitcorbM Offline
                                    mitcorb
                                    Hi, Fredo:
                                    I know you are not ready to release, but the gif sequence is too fast in the first "frames"?
                                      jeff hammond
                                      dotdotdot
                                      • fredo6F Offline
                                        fredo6
                                        Vicspa
                                        If you wait a little bit, I will soon release a new plugin, ThruPaint, that can help of this kind of situation.
                                        Here is how it would handle it:
                                        1. Apply the texture'
                                        2. Tiling 1 x 1
                                        3. Translate in U direction to position the texture (in your case it does not matter as your cylinder is symmetrical)
                                        Fredo
                                        • fredo6F Offline
                                          fredo6
                                          @mitcorb said:
                                          Hi, Fredo:
                                          The first frame is an artefact. No special meaning.
                                          I updated the video anyway.
                                          Fredo
