    Image around cylinder
    19 Posts 8 Posters 1.3k Views 8 Watching
    • jeff hammondJ
      a way to do it without a plugin:
      -edit the texture so it's width matches the circumference of the jar (in this case, it's ~12'- 1 5/16")
      -turn hidden edges on
      -use the paint tool to apply the texture to One of the facets of the cylinder
      -right click the painted facet then texture->position
      -align the texture to desired height as well as place the seam of the texture on the edge of the facet
      -using the paint tool, sample the facet then paint the next one (paint brush with the cmmd key samples on mac.. not sure about windows)
      -so on and so forth until you make it all the way around.. (in many cases, such as a cylinder, you won't have to keep sampling each successive facet.. just the first one then just paint around in order and everything will map properly)
      jarJH.skp
      • numbthumbN
        numbthumb
        A quick tryout using Whaatยดs UVTools 0.1 ("Cylindrical Map" option from the context menu)jar2UV.skp
        Comfortably numb...
        • V
          Vicspa
          Thanks Jeff, still trying but not working out for me yet.
          • V
            Vicspa
            Thanks Numbthumb, will try the UV tools.
            Do the plugins appear in the plugins menu as UV tools ???
            • GaieusG
              Jeff1s solution with another example (from the past):
              http://sketchup.google.com/3dwarehouse/details?mid=672e39e6eed2aab4f5e0eb0152f85f19&prevstart=0
              • BoxB
                One of the youtubes.
                • numbthumbN
                  numbthumb
                  It will create a context menu called 'UVTools'
                  Comfortably numb...
                    Roger
                    Look at the bottom of the page at"
                    http://forums.sketchucation.com/viewtopic.php?f=81&t=26545&p=230303&hilit=Tigre#p230303
                    It shows a texture wrapped around the barrel of a cannon using the4 method described by Jeff Hammond.
                    http://www.azcreative.com
                    • V
                      Vicspa
                      Thanks so much guys, ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ I will look into and try all you have said.
                      • V
                        Vicspa
                        Numbthumb, sorry to be a pain in the A@#, but I still cannot find it in the plugins folder.
                        • numbthumbN
                          numbthumb
                          No hassle ๐Ÿ˜„
                          You should find it in the context menu, not in the plugins folder.
                          Comfortably numb...
                          • V
                            Vicspa
                            thanks again Numbthumb, I'm going to be 65 this year, and I'm amazed how many "senior Moments" I'm having. ๐Ÿ˜ฒ
                            Thanks again to everyone, see you on the next senior moment. ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
                              Roger
                              Shh!, I'm 67.
                              • V
                                Vicspa
                                Shhhhhhhhh!!!!!
                                • mitcorbM
                                  mitcorb
                                  Hi, Fredo:
                                  I know you are not ready to release, but the gif sequence is too fast in the first "frames"?
                                  • jeff hammondJ
                                    ๐Ÿ˜ฒ ๐Ÿ˜ฎ
                                    • fredo6F
                                      Vicspa
                                      If you wait a little bit, I will soon release a new plugin, ThruPaint, that can help of this kind of situation.
                                      Here is how it would handle it:
                                      1. Apply the texture'
                                      2. Tiling 1 x 1
                                      3. Translate in U direction to position the texture (in your case it does not matter as your cylinder is symmetrical)
                                      • fredo6F
                                        @mitcorb said:
                                        Hi, Fredo:
                                        The first frame is an artefact. No special meaning.
                                        I updated the video anyway.
