    Image around cylinder
    19 Posts 8 Posters 1.0k Views 8 Watching
    • numbthumbN Offline
      numbthumb
      A quick tryout using Whaatยดs UVTools 0.1 ("Cylindrical Map" option from the context menu)jar2UV.skp
      Comfortably numb...
      • V Offline
        Vicspa
        Thanks Jeff, still trying but not working out for me yet.
        • V Offline
          Vicspa
          Thanks Numbthumb, will try the UV tools.
          Do the plugins appear in the plugins menu as UV tools ???
            Jeff1s solution with another example (from the past):
            http://sketchup.google.com/3dwarehouse/details?mid=672e39e6eed2aab4f5e0eb0152f85f19&prevstart=0
            • BoxB Offline
              One of the youtubes.
                numbthumb
                It will create a context menu called 'UVTools'
                Comfortably numb...
                  Roger
                  Look at the bottom of the page at"
                  http://forums.sketchucation.com/viewtopic.php?f=81&t=26545&p=230303&hilit=Tigre#p230303
                  It shows a texture wrapped around the barrel of a cannon using the4 method described by Jeff Hammond.
                  http://www.azcreative.com
                  • V Offline
                    Vicspa
                    Thanks so much guys, ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ I will look into and try all you have said.
                    • V Offline
                      Vicspa
                      Numbthumb, sorry to be a pain in the A@#, but I still cannot find it in the plugins folder.
                        numbthumb
                        No hassle ๐Ÿ˜„
                        You should find it in the context menu, not in the plugins folder.
                        Comfortably numb...
                        • V Offline
                          Vicspa
                          thanks again Numbthumb, I'm going to be 65 this year, and I'm amazed how many "senior Moments" I'm having. ๐Ÿ˜ฒ
                          Thanks again to everyone, see you on the next senior moment. ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
                            Roger
                            Shh!, I'm 67.
                            • V Offline
                              Vicspa
                              Shhhhhhhhh!!!!!
                              • mitcorbM Offline
                                mitcorb
                                Hi, Fredo:
                                I know you are not ready to release, but the gif sequence is too fast in the first "frames"?
                                • jeff hammondJ Offline
                                  ๐Ÿ˜ฒ ๐Ÿ˜ฎ
                                  • fredo6F Offline
                                    Vicspa
                                    If you wait a little bit, I will soon release a new plugin, ThruPaint, that can help of this kind of situation.
                                    Here is how it would handle it:
                                    1. Apply the texture'
                                    2. Tiling 1 x 1
                                    3. Translate in U direction to position the texture (in your case it does not matter as your cylinder is symmetrical)
                                    • fredo6F Offline
                                      @mitcorb said:
                                      Hi, Fredo:
                                      The first frame is an artefact. No special meaning.
                                      I updated the video anyway.
