    Move points to a '3D grid'
    26 Posts 8 Posters 4.2k Views 8 Watching
    • R
      rossthompson
      I am trying to write a script for cleaning up geometery created from another program (IES VE). Essentially what I want to achieve is to move each vertex so it sits on a '3D grid'. I believe this could be achieved by applying a rounding function to the X,Y and Z coordinates of each point.
      The attached image hopefully illustrates what I am trying to achieve. Ideally the degree of rounding would be a user input variable.
      Any help on this would be greatly appreciated.
      Ross
      • gillesG
        gilles
        You can use the scale tool: begin to scale then type 400mm;400mm;400mm + enter.
        Note that the separator may be "," for you .
        • thomthomT
          • thomthomT
            This is a nice idea - I might implement such a feature in Vertex Tools.
            Of the top of my head, something like this:
            pt = Geom::Point3d.new( 3.976879, 3.970209, 1.002568 ) grid_pt = pt.to_a.map { |n| n.round() } v = pt.vector_to( grid_pt )
            You can do something like that - iterate the vertices of a mesh, for each vertex find the nearest grid position to the vertex, collect the vertex and adjustment vector to each their array and use Entities.transform_by_vectors https://developers.google.com/sketchup/docs/ourdoc/entities#transform_by_vectors
            Note that this simple example rounded to nearest whole number. Modifications is needed to account for grids fitted to decimal precision.
            • thomthomT
              Actually, that example will round to nearest inch - which is SketchUp's internal unit...
              • thomthomT
                <span class="syntaxdefault">pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> 3.976879</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 3.760209</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 1.002568</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">tolerance </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.25</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m<br />grid_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">n</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  b </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> n </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> tolerance </span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_i </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> tolerance<br />  r </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> n </span><span class="syntaxkeyword">%</span><span class="syntaxdefault"> tolerance<br />  </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">r </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> tolerance </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> 2</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> b </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> tolerance </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> b<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">grid_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">grid_pt </span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Original; #{pt}"<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Tolerance; #{tolerance}"<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Grid Point; #{grid_pt}"&nbsp;</span><span class="syntaxdefault"></span>
                Output:
                Original: (3976,879mm, 3760,209mm, 1002,568mm) Tolerance: 250mm Grid Point: (4000mm, 3750mm, 1000mm)
                • thomthomT
                  Test module - adjust the vertices in the active context to grid.
                  <span class="syntaxdefault">module&nbsp;GridSnap<br /><br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">point</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">grid_pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">point</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">n</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">=&nbsp;(&nbsp;</span><span class="syntaxdefault">n&nbsp;</span><span class="syntaxkeyword">/&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_i&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">tolerance<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;r&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">n&nbsp;</span><span class="syntaxkeyword">%&nbsp;</span><span class="syntaxdefault">tolerance<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">r&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">/&nbsp;</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)&nbsp;?&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxdefault">b<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(&nbsp;*</span><span class="syntaxdefault">grid_pt&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">test_it<br />&nbsp;&nbsp;&nbsp;&nbsp;pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(&nbsp;</span><span class="syntaxdefault">3.976879</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">3.760209</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1.002568</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0.25</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m<br />&nbsp;&nbsp;&nbsp;&nbsp;grid_pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Original;&nbsp;#{pt}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Tolerance;&nbsp;#{tolerance}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Grid&nbsp;Point;&nbsp;#{grid_pt}"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">adjust_vertices</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0.25</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;vertices&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Collect&nbsp;vertices.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;vertices&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Calculate&nbsp;grid&nbsp;adjustments.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vectors&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">vertex&nbsp;in&nbsp;vertices<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">vertex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;grid_pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vector&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">grid_pt&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;unless&nbsp;vector</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">vertex<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;vectors&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">vector<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Apply&nbsp;transformations<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform_by_vectors</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">vectors&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"#{entities.size}&nbsp;adjusted&nbsp;to&nbsp;grid."<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /><br />end<br /></span>
                  • Dan RathbunD
                    Dan Rathbun
                    How about that ??
                    ... from concept to module in under a hour. 👍
                    I'm not here much anymore.
                    • TIGT
                      Could this then be a tiny step towards a poly-reducer?
                      As the vertices are 'rationalized' onto a 'grid' some faces could become coplanar and therefore the superfluous shared edges could be removed.
                      The fineness/coarseness of this 'grid' removes less/more 'detailing'... 😕
                      • thomthomT
                        Cubificator?
                        I was thinking it might be usable to repair troublesome model imported from CAD drawings. Occasionally I run into models where splitting a face with an edge results in duplicate faces. I suspect its due to some precision errors. Maybe if the vertices where adjusted to fit to a finely grained 3D grid the troubles would go away... ?
                        • R
                          rossthompson
                          ThomThom thanks so much for your support! I have had a go at running your test module. My understanding is that it should shift the points in the active selection to a 0.25m grid as specified in the code.
                          However I am having problems running the module. I have attempted to add it to the tools menu as below, but I am not 100% sure how to 'call' the routine. Appologies if I'm being an idiot - I am new to ruby scripting!
                              module GridSnap
                                def self.round_point( point, tolerance )
                                  grid_pt = point.to_a.map { |n|
                                    b = ( n / tolerance ).to_i * tolerance
                                    r = n % tolerance
                                    (r > tolerance / 2) ? b + tolerance ; b
                                  Geom;;Point3d.new( *grid_pt )
                                def self.test_it
                                  pt = Geom;;Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
                                  tolerance = 0.25.m
                                  grid_pt = self.round_point( pt, tolerance )
                                  puts "Original; #{pt}"
                                  puts "Tolerance; #{tolerance}"
                                  puts "Grid Point; #{grid_pt}"
                                def self.adjust_vertices( tolerance = 0.25.m )
                                  model = Sketchup.active_model
                                  vertices = []
                                  # Collect vertices.
                                  for e in model.active_entities
                                    vertices << e.vertices if e.is_a?( Sketchup;;Edge )
                                  vertices.flatten!
                                  vertices.uniq!
                                  # Calculate grid adjustments.
                                  vectors = []
                                  entities = []
                                  for vertex in vertices
                                    pt = vertex.position
                                    vector = pt.vector_to( grid_pt )
                                    next unless vector.valid?
                                    entities << vertex
                                    vectors << vector
                                  # Apply transformations
                                  model.active_entities.transform_by_vectors( entities, vectors )
                                  puts "#{entities.size} adjusted to grid."
                          # Menu Entry;
                          UI.menu("Tools").add_item("GridSnap") { GridSnap } if not file_loaded?("GridSnap.rb")
                          file_loaded("GridSnap.rb")
                          I think this could be a very useful tool for cleaning many types of imported geometry.
                          Ross
                          • Dan RathbunD
                            Dan Rathbun
                            @thomthom said:
                            Cubificator?
                            Polyhedronizer ?
                            Orthogonizer ?
                            Orthographizer ?
                            OrthograFixer ?
                            • TIGT
                              In case TT is away...
                              Inside the code making the menu use
                              {GridSnap**.adjust_vertices(1.cm)**}
                              It affects the whole model.
                              This example uses 1cm grid
                              Use another 'tolerance' if desired...
                              If you use () it defaults to 0.25m anyway...
                              It's only some example code and could be better assembled into something working on a selection with warnings and an 'undo' ???
                              • TIGT
                                Not sure this reduced poly rock is so good ?Cuboidalizer.PNG'Cuboidalizer' is another name idea too... that or 'Discombobulizer' 😲
                                • Dan RathbunD
                                  Dan Rathbun
                                  Here's a beta version with an inputbox and undo operation...
                                  It seemed to only change a cubes vertices in the Z axis ??
                                  module GridSnap
                                    @@last_tolerance = 0.25.m
                                    class << self # PROXY CLASS
                                      def round_point( point, tolerance )
                                          r = n % tolerance
                                      def test_it
                                        tolerance = @@last_tolerance
                                        grid_pt = round_point( pt, tolerance )
                                      def adjust_vertices( tolerance = @@last_tolerance )
                                        vertices = []
                                        # Collect vertices.
                                        vertices.flatten!
                                        vertices.uniq!
                                        vectors = []
                                        entities = []
                                          entities << vertex
                                          vectors << vector
                                      def menu_command()
                                        title   = 'Adjust Vertices'
                                        prompt  = 'Tolerance'
                                        default = @@last_tolerance
                                        result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
                                        if result
                                          begin
                                            Sketchup.active_model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
                                            adjust_vertices( result[0] )
                                            Sketchup.active_model.commit_operation()
                                          rescue
                                            Sketchup.active_model.abort_operation()
                                          else
                                            @@last_tolerance = result[0]
                                    end # PROXY CLASS
                                    #{# RUN ONCE
                                    unless file_loaded?("GridSnap.rb")
                                      # Menu Entry;
                                      UI.menu("Tools").add_item("GridSnap") { menu_command() }
                                    end #}
                                  end # module
                                  • thomthomT
                                    Should apply to X,Y and Z... Seemed to work correctly in my quick test...
                                    • daikuD
                                      daiku
                                      @dan rathbun said:
                                      @thomthom said:
                                      Cubificator?
                                      Polyhedronizer ?
                                      Orthogonizer ?
                                      Orthographizer ?
                                      OrthograFixer ?
                                      It's like Autotune for cad! They can make you sound good, even if you can't sing.
                                      If you are editing digital music, and you need to make the drum beats perfect, you can move the beats to the nearest sixteenth note, or whatever. It's call "quantizing".
                                      Clark Bremer
                                      http://www.northernlightstimberframing.com
                                      • Dan RathbunD
                                        Dan Rathbun
                                        @daiku said:
                                        It's called "quantizing".
                                        TRUE !!
                                        Restriction to discrete values (or multiples thereof,) rather than any values in the set of possibles (real numbers, in this case.)
                                        So.. the long term:
                                        Vertex Positional Quantization
                                        The short form:
                                        Vertex to Grid
                                        • R
                                          rossthompson
                                          Hi guys, I have had a play with Dan's Beta version and for me it works really well. The verticies are adjusted in X,Y and Z directions and the undo function works fine!
                                          The only slight problem: it adjusts all the geometry in the model, rather than just the active selection. The original module just adjusted the active selection.
                                          Any ideas?
                                          Again thanks for the support - this script should be a realy time saver!
                                          Ross
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Well .. I did not think I changed the context of what Thomas' code did... just tried to wrap the code properly and added the menu_command() method to handle an inputbox.
                                            I'll have a look at it.. again.
                                            (And it's not really MY edition just because I added the inputbox.. it's still Thomas' thing.)
                                            • 1 / 2
