    Move points to a '3D grid'
    26 Posts 8 Posters 3.0k Views 8 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      OK... added support for a selection. (Pssst! ... there was no selection support from the beginning Ross.)
      This utility should probably be wrapped in Thomas' toplevel author module, and reside below his author directory in some manner.
      I'll leave those choices up to him, and when he releases version 1.0.0, we'll delete these beta versions in this thread and put in a link to the release thread.
      #  GridSnap.rb
      #  by Thomas Thomassen
      #  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      #  IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      #  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      #  This utility quantizes the vertex locations, of the current selection,
      #    of the model, or just the current context, to a 3D grid, whose interval
      #    can be set via a popup inputbox.
      #  Revisions;
      #   0.1.0 ; 2012-03-26 ; by Thomas Thomassen
      #   initial beta release
      #   0.2.0 ; 2012-03-26 ; by Dan Rathbun
      #   + Added menu_command() method for inputbox and undo operation.
      #   0.3.0 ; 2012-03-28 ; by Dan Rathbun
      #   + Revised the menu_command() method to pass a selection set to the
      #       adjust_vertices() method as a 2nd argument.
      module GridSnap
        @@last_tolerance = 0.25.m
        class << self # PROXY CLASS
          def round_point( point, tolerance )
            grid_pt = point.to_a.map { |n|
              b = ( n / tolerance ).to_i * tolerance
              r = n % tolerance
              (r > tolerance / 2) ? b + tolerance ; b
            Geom;;Point3d.new( *grid_pt )
          def test_it
            pt = Geom;;Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
            tolerance = @@last_tolerance
            grid_pt = round_point( pt, tolerance )
            puts "Original; #{pt}"
            puts "Tolerance; #{tolerance}"
            puts "Grid Point; #{grid_pt}"
          def adjust_vertices( tolerance = @@last_tolerance, ents = nil )
            model = Sketchup.active_model
            vertices = []
            # determine the context;
            ents = model.active_entities() if ents.nil?
            # Collect vertices.
            for e in ents #model.active_entities
              vertices << e.vertices if e.is_a?( Sketchup;;Edge )
            vertices.flatten!
            vertices.uniq!
            # Calculate grid adjustments.
            vectors = []
            entities = []
            for vertex in vertices
              pt = vertex.position
              vector = pt.vector_to( grid_pt )
              next unless vector.valid?
              entities << vertex
              vectors << vector
            # Apply transformations
            model.active_entities.transform_by_vectors( entities, vectors )
            puts "#{entities.size} adjusted to grid."
          def menu_command()
            title   = 'Adjust Vertices'
            prompt  = 'Tolerance'
            default = @@last_tolerance
            result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
            if result
              begin
                model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
                  if model.selection.empty?
                    adjust_vertices( result[0] )
                  else
                    adjust_vertices( result[0], model.selection.to_a() )
                model.commit_operation()
              rescue
                model.abort_operation()
              else
                @@last_tolerance = result[0]
        end # PROXY CLASS
        #{# RUN ONCE
        unless file_loaded?("GridSnap.rb")
          # Menu Entry;
          UI.menu("Tools").add_item("GridSnap") { menu_command() }
          file_loaded("GridSnap.rb")
        end #}
      end # module
      I'm not here much anymore.
      • V Offline
        VertexMover
        Is there an easy way to have it go through the Outliner list and open each model group and snap those corners to the grid?
        What would need changed in the script so that it would snap all visible geometry to the grid, Without having to manually select and open each group?
          Dan Rathbun
          It would need to iterate the model's definition list, changing those that have instances.
          But I'm not sure if it is really safe to change entities collections outside the current context?
          PM'ing TT
          • tt_suT Offline
            tt_su
            That should be ok. One just need to keep in mind that the current open context apply a transformation that affect 3d points.
              Dan Rathbun
              Ok.. but are ya gonna repost under TT_GripSnap or whatever? (I had said we'd remove the code blocks above and replace with Store links when done.)
                This wasn't something I ever planned to publish. It was just a code snipped posted for anyone to grab.
                • 2 / 2
