    Move points to a '3D grid'
    26 Posts 8 Posters 3.2k Views 8 Watching
      This is a nice idea - I might implement such a feature in Vertex Tools.
      Of the top of my head, something like this:
      pt = Geom::Point3d.new( 3.976879, 3.970209, 1.002568 ) grid_pt = pt.to_a.map { |n| n.round() } v = pt.vector_to( grid_pt )
      You can do something like that - iterate the vertices of a mesh, for each vertex find the nearest grid position to the vertex, collect the vertex and adjustment vector to each their array and use Entities.transform_by_vectors https://developers.google.com/sketchup/docs/ourdoc/entities#transform_by_vectors
      Note that this simple example rounded to nearest whole number. Modifications is needed to account for grids fitted to decimal precision.
        Actually, that example will round to nearest inch - which is SketchUp's internal unit...
          <span class="syntaxdefault">pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> 3.976879</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 3.760209</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 1.002568</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">tolerance </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.25</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m<br />grid_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">n</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  b </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> n </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> tolerance </span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_i </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> tolerance<br />  r </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> n </span><span class="syntaxkeyword">%</span><span class="syntaxdefault"> tolerance<br />  </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">r </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> tolerance </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> 2</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> b </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> tolerance </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> b<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">grid_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">grid_pt </span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Original; #{pt}"<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Tolerance; #{tolerance}"<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"Grid Point; #{grid_pt}"&nbsp;</span><span class="syntaxdefault"></span>
          Output:
          Original: (3976,879mm, 3760,209mm, 1002,568mm) Tolerance: 250mm Grid Point: (4000mm, 3750mm, 1000mm)
            Test module - adjust the vertices in the active context to grid.
            <span class="syntaxdefault">module&nbsp;GridSnap<br /><br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">point</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">grid_pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">point</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">n</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">=&nbsp;(&nbsp;</span><span class="syntaxdefault">n&nbsp;</span><span class="syntaxkeyword">/&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_i&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">tolerance<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;r&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">n&nbsp;</span><span class="syntaxkeyword">%&nbsp;</span><span class="syntaxdefault">tolerance<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">r&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">/&nbsp;</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)&nbsp;?&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxdefault">b<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(&nbsp;*</span><span class="syntaxdefault">grid_pt&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">test_it<br />&nbsp;&nbsp;&nbsp;&nbsp;pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(&nbsp;</span><span class="syntaxdefault">3.976879</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">3.760209</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1.002568</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0.25</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m<br />&nbsp;&nbsp;&nbsp;&nbsp;grid_pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Original;&nbsp;#{pt}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Tolerance;&nbsp;#{tolerance}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"Grid&nbsp;Point;&nbsp;#{grid_pt}"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">adjust_vertices</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0.25</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">m&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;vertices&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Collect&nbsp;vertices.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;vertices&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Calculate&nbsp;grid&nbsp;adjustments.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vectors&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">vertex&nbsp;in&nbsp;vertices<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">vertex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;grid_pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tolerance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vector&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">grid_pt&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;unless&nbsp;vector</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">vertex<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;vectors&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">vector<br />&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Apply&nbsp;transformations<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform_by_vectors</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">vectors&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"#{entities.size}&nbsp;adjusted&nbsp;to&nbsp;grid."<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /><br />end<br /></span>
            • Dan RathbunD Offline
              Dan Rathbun
              How about that ??
              ... from concept to module in under a hour. 👍
              I'm not here much anymore.
              • TIGT Online
                Could this then be a tiny step towards a poly-reducer?
                As the vertices are 'rationalized' onto a 'grid' some faces could become coplanar and therefore the superfluous shared edges could be removed.
                The fineness/coarseness of this 'grid' removes less/more 'detailing'... 😕
                  Cubificator?
                  I was thinking it might be usable to repair troublesome model imported from CAD drawings. Occasionally I run into models where splitting a face with an edge results in duplicate faces. I suspect its due to some precision errors. Maybe if the vertices where adjusted to fit to a finely grained 3D grid the troubles would go away... ?
                    rossthompson
                    ThomThom thanks so much for your support! I have had a go at running your test module. My understanding is that it should shift the points in the active selection to a 0.25m grid as specified in the code.
                    However I am having problems running the module. I have attempted to add it to the tools menu as below, but I am not 100% sure how to 'call' the routine. Appologies if I'm being an idiot - I am new to ruby scripting!
                        module GridSnap
                          def self.round_point( point, tolerance )
                            grid_pt = point.to_a.map { |n|
                              b = ( n / tolerance ).to_i * tolerance
                              r = n % tolerance
                              (r > tolerance / 2) ? b + tolerance ; b
                            Geom;;Point3d.new( *grid_pt )
                          def self.test_it
                            pt = Geom;;Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
                            tolerance = 0.25.m
                            grid_pt = self.round_point( pt, tolerance )
                            puts "Original; #{pt}"
                            puts "Tolerance; #{tolerance}"
                            puts "Grid Point; #{grid_pt}"
                          def self.adjust_vertices( tolerance = 0.25.m )
                            model = Sketchup.active_model
                            vertices = []
                            # Collect vertices.
                            for e in model.active_entities
                              vertices << e.vertices if e.is_a?( Sketchup;;Edge )
                            vertices.flatten!
                            vertices.uniq!
                            # Calculate grid adjustments.
                            vectors = []
                            entities = []
                            for vertex in vertices
                              pt = vertex.position
                              vector = pt.vector_to( grid_pt )
                              next unless vector.valid?
                              entities << vertex
                              vectors << vector
                            # Apply transformations
                            model.active_entities.transform_by_vectors( entities, vectors )
                            puts "#{entities.size} adjusted to grid."
                    # Menu Entry;
                    UI.menu("Tools").add_item("GridSnap") { GridSnap } if not file_loaded?("GridSnap.rb")
                    file_loaded("GridSnap.rb")
                    I think this could be a very useful tool for cleaning many types of imported geometry.
                    Ross
                      Dan Rathbun
                      @thomthom said:
                      Cubificator?
                      Polyhedronizer ?
                      Orthogonizer ?
                      Orthographizer ?
                      OrthograFixer ?
                      • TIGT Online
                        In case TT is away...
                        Inside the code making the menu use
                        {GridSnap**.adjust_vertices(1.cm)**}
                        It affects the whole model.
                        This example uses 1cm grid
                        Use another 'tolerance' if desired...
                        If you use () it defaults to 0.25m anyway...
                        It's only some example code and could be better assembled into something working on a selection with warnings and an 'undo' ???
                        • TIGT Online
                          Not sure this reduced poly rock is so good ?Cuboidalizer.PNG'Cuboidalizer' is another name idea too... that or 'Discombobulizer' 😲
                            Dan Rathbun
                            Here's a beta version with an inputbox and undo operation...
                            It seemed to only change a cubes vertices in the Z axis ??
                            module GridSnap
                              @@last_tolerance = 0.25.m
                              class << self # PROXY CLASS
                                def round_point( point, tolerance )
                                    r = n % tolerance
                                def test_it
                                  tolerance = @@last_tolerance
                                  grid_pt = round_point( pt, tolerance )
                                def adjust_vertices( tolerance = @@last_tolerance )
                                  vertices = []
                                  # Collect vertices.
                                  vertices.flatten!
                                  vertices.uniq!
                                  vectors = []
                                  entities = []
                                    entities << vertex
                                    vectors << vector
                                def menu_command()
                                  title   = 'Adjust Vertices'
                                  prompt  = 'Tolerance'
                                  default = @@last_tolerance
                                  result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
                                  if result
                                    begin
                                      Sketchup.active_model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
                                      adjust_vertices( result[0] )
                                      Sketchup.active_model.commit_operation()
                                    rescue
                                      Sketchup.active_model.abort_operation()
                                    else
                                      @@last_tolerance = result[0]
                              end # PROXY CLASS
                              #{# RUN ONCE
                              unless file_loaded?("GridSnap.rb")
                                # Menu Entry;
                                UI.menu("Tools").add_item("GridSnap") { menu_command() }
                              end #}
                            end # module
                              Should apply to X,Y and Z... Seemed to work correctly in my quick test...
                              • daikuD Offline
                                daiku
                                @dan rathbun said:
                                @thomthom said:
                                Cubificator?
                                Polyhedronizer ?
                                Orthogonizer ?
                                Orthographizer ?
                                OrthograFixer ?
                                It's like Autotune for cad! They can make you sound good, even if you can't sing.
                                If you are editing digital music, and you need to make the drum beats perfect, you can move the beats to the nearest sixteenth note, or whatever. It's call "quantizing".
                                Clark Bremer
                                http://www.northernlightstimberframing.com
                                  Dan Rathbun
                                  @daiku said:
                                  It's called "quantizing".
                                  TRUE !!
                                  Restriction to discrete values (or multiples thereof,) rather than any values in the set of possibles (real numbers, in this case.)
                                  So.. the long term:
                                  Vertex Positional Quantization
                                  The short form:
                                  Vertex to Grid
                                    rossthompson
                                    Hi guys, I have had a play with Dan's Beta version and for me it works really well. The verticies are adjusted in X,Y and Z directions and the undo function works fine!
                                    The only slight problem: it adjusts all the geometry in the model, rather than just the active selection. The original module just adjusted the active selection.
                                    Any ideas?
                                    Again thanks for the support - this script should be a realy time saver!
                                    Ross
                                      Dan Rathbun
                                      Well .. I did not think I changed the context of what Thomas' code did... just tried to wrap the code properly and added the menu_command() method to handle an inputbox.
                                      I'll have a look at it.. again.
                                      (And it's not really MY edition just because I added the inputbox.. it's still Thomas' thing.)
                                        Dan Rathbun
                                        OK... added support for a selection. (Pssst! ... there was no selection support from the beginning Ross.)
                                        This utility should probably be wrapped in Thomas' toplevel author module, and reside below his author directory in some manner.
                                        I'll leave those choices up to him, and when he releases version 1.0.0, we'll delete these beta versions in this thread and put in a link to the release thread.
                                        #  GridSnap.rb
                                        #  by Thomas Thomassen
                                        #  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                                        #  IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                                        #  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                        #  This utility quantizes the vertex locations, of the current selection,
                                        #    of the model, or just the current context, to a 3D grid, whose interval
                                        #    can be set via a popup inputbox.
                                        #  Revisions;
                                        #   0.1.0 ; 2012-03-26 ; by Thomas Thomassen
                                        #   initial beta release
                                        #   0.2.0 ; 2012-03-26 ; by Dan Rathbun
                                        #   + Added menu_command() method for inputbox and undo operation.
                                        #   0.3.0 ; 2012-03-28 ; by Dan Rathbun
                                        #   + Revised the menu_command() method to pass a selection set to the
                                        #       adjust_vertices() method as a 2nd argument.
                                        module GridSnap
                                                r = n % tolerance
                                            def test_it
                                            def adjust_vertices( tolerance = @@last_tolerance, ents = nil )
                                              vertices = []
                                              # determine the context;
                                              ents = model.active_entities() if ents.nil?
                                              # Collect vertices.
                                              for e in ents #model.active_entities
                                              vertices.flatten!
                                              vertices.uniq!
                                              vectors = []
                                              entities = []
                                                entities << vertex
                                                vectors << vector
                                            def menu_command()
                                              if result
                                                begin
                                                    if model.selection.empty?
                                                    else
                                                      adjust_vertices( result[0], model.selection.to_a() )
                                                rescue
                                                else
                                          end # PROXY CLASS
                                          #{# RUN ONCE
                                            # Menu Entry;
                                          end #}
                                        end # module
                                        • V Offline
                                          VertexMover
                                          Is there an easy way to have it go through the Outliner list and open each model group and snap those corners to the grid?
                                          What would need changed in the script so that it would snap all visible geometry to the grid, Without having to manually select and open each group?
                                            Dan Rathbun
                                            It would need to iterate the model's definition list, changing those that have instances.
                                            But I'm not sure if it is really safe to change entities collections outside the current context?
                                            PM'ing TT
