    Sketchup 8pro and surveying/drafting
    27 Posts 9 Posters 8.2k Views 9 Watching
    • E Offline
      eddix99
      Hello All,
      I have been learning sketchup for a couple of months now and I'm getting to grips with the fundamentals of the software. The tools are starting to become familiar to me now and I’m quite happy with the progress that i’m making. I’m lucky to have the pro version which I originally bought for my woodworking (solid tools) but I absolutely love Layout as a tool.
      Over the last few weeks I have found a need to start doing some simple site surveys using some second hand surveyors tools that have been made available to me. I have access to a total station and a laser level which I want to put to good use in cobbling together a half decent set of scale drawings for eventual use with sketchup. I think that Layout would be just fine for my requirements of presenting the results.
      I’m getting to grips with the basic principles of surveying, in particular the use of the total station to give me distance and bearing of a series of points. The next step is to complete a simple survey of a small area and then construct a simple 2d drawing in sketchup before starting the 3d process using sketchup’s tools.
      The only thing that I’m unsure about is whether Sketchup can handle drawing outlines using distance and bearing to/from a given point. I also don’t think that I can simply place a dot on the plan and join them all together later on to create an outline.
      I was looking at autocad LT for drafting purposes but nearly fell of my seat when I saw the price. With this in mind I was hoping to stick to sketchup as much as possible and maybe make use of some rubies to create a rudimentary drafting capability within sketchup. If I am forced to use another software package I’d like to find something that’s inexpensive and simple to use.
      Any advice would be really appreciated.
      Thanks in advance!
        Hi Eddi,
        "As if..." I remembered a plugin that can bring in distance and bearings info - but I cannot find it now (hopefully someone can remember the name).
        As for generating the mesh from guide points, there are good plugins for that - first we should solve how you get the data into SketchUp.
          It's John Wehby's 'survey-tool' [ http://www.wehbycreative.com ]
            Thanks TIG. It's shared in the Ruby depot: http://rhin.crai.archi.fr/rld/plugin_details.php?id=434
            • dukejazzD Offline
              dukejazz
              camera plugin will do it
              TT View Direction (HUD)
              by thomthom
              Sections: Animation - Camera ; Text ; Files - Misc
              Adds a note acting as a Head Up Display with location info about the model and the camera angle in relationship to the north angle. This HUD will update the info instantly as it changes.
              surveytool
              by J. Wehby
              Sections: Architecture ; Geometry - Drawing
              Uses distance and bearing to draw property data. Starts at Origin.Prompts for Distance and Bearing until user presses Cancel. Draws boundary segment after each entry. Zooms to extents of geometry drawn by the script.
              • E Offline
                eddix99
                Guys,
                Thanks for all the quick responses!
                I will check out this tool and report back.
                Edward
                • E Offline
                  eddix99
                  Sorry to be a complete noob but I have pasted the surveytool.rb file directly into my SU8 plugins folder, but I cant seem to find the tool anywhere, even after reloading SU a couple of times. I've tried the toolbar window and by right clicking a line.
                  Can you offer any advice/ assistance?
                  Thanks in advance.
                  Edward
                    It says it should be under the Draw menu.
                    • E Offline
                      eddix99
                      Got it! Thanks Gai
                        So how is it going?
                        • E Offline
                          eddix99
                          Hey Gai,
                          Thanks for checking in! I've had a quick play with the tool and I think that it's going to suit my requirements just fine.
                          Thanks for all your help.
                          • E Offline
                            eddix99
                            Just a quick update on the use of the survey tools plugin:
                            Although this ruby is really simple it does it's job very well. Its a bit of a pain converting my angles from an azumeth to a bearing but once the data is put into the tool it handles everything well.
                            Although this tool is designed to carry out boundary surveys it works well with other types of survey too. I only use it to do bearing distance calculations then then join the ends of the lines to make up the outline of the object being surveyed.
                            One thing that the survey tool ruby doesn't do is allow me to move the axis to another location and begin plotting distance/bearing from that new location. This is a real pain as it means that I cant move to another station and continue my survey from there.
                            If there are others out there that are into the surveying ruby, how do they get round these limitations?
                            • BepB Offline
                              Bep
                              Hallo Edward,
                              Look at driving dimensions maybe it will be of any help.
                              http://drivingdimensions.com/SketchUp/overview/
                              Bep
                              "History is written by the winners"
                              • G Offline
                                gregw
                                Hello,
                                I don't have any experience using the survey tools plugin but I do have a bit of experience using survey equipment so I thought I would offer a few ideas..
                                I'm not sure exactly which total station you are using but I think that some of them allow the measurement data to be output in rectangular coordinates (x,y) relative to the instrument location. The rectangular coordinates would allow you to easily enter the measurement data into your sketchup model and it would also allow you to orient the new station locations to your existing data by measuring three known (previously measured) non linear points from the new station location.
                                Even if the total station you are using doesn't output rectangular coordinates it's easy to convert the instruments polar coordinates to rectangular by using a simple formula.
                                • E Offline
                                  eddix99
                                  @bep said:
                                  Hallo Edward,
                                  Bep
                                  Thanks Bep,
                                  I will look into this later today!!
                                  • E Offline
                                    eddix99
                                    Hi Greg,
                                    What you are saying is absolutely right. My total station has a coordinates function, which I haven't got round to figuring out yet.
                                    Combining surveying principles with sketchup is a bit of a learning process. As you may have guessed I don't have a lot of experience with either Sketchup or Surveying but I seem to be muddling my way through.
                                    Early on in my learning process I decided to go with Bearing/Distance data as this seemed to fit in with the survey tools ruby. Perhaps in hindsight I should have learned about coordinates and started using pointcloud.
                                    What would be really great is if there were some additions made to the survey tools ruby that would allow the axis to be moved around and rotated . I may write Mr Wehby an email asking nicely if there are any plans for some changes in the future.
                                    Failing that I guess I’ll have to change my methods and move over to coordinates.
                                    Many thanks for your replies.
                                    Edward
                                    • Jean LemireJ Offline
                                      Jean Lemire
                                      Hi Edward, hi folks.
                                      Maybe you can use the axes repositionning feature built natively in SlektchUp to reposition the red axis, for example, along a line.
                                      For example, lets suppose that you posotion the measuring device at 0,0,0 and the first point you get is at 50,100,0. Then, you draw a line from 0,0,0 to 50,100,0. After that, you reposition the axes origin at 50,100,0 and the red axis on the direction of this line. Then the process can be repeated.
                                      See attached SU file for ideas.
                                      Surveying.skp
                                      • E Offline
                                        eddix99
                                        Hey Jean,
                                        Thanks for the file, which explained perfectly your method. I have made the decision to give coordinates a try out and will do some reading on the subject this evening.
                                        I have installed Didiers point cloud ruby and will try to get some test data plotted in the next couple of days. I want to use my total station and get some very basic coordinates recorded and then I will see the results of both methods.
                                        Now its just a question of finding out what works best for me.
                                        On a side note I'm wondering whether Trimbles SU will have all these features natively. It would be cool for me if they did!
                                        • G Offline
                                          gregw
                                          Hi Edward,
                                          Another option you might want to try out is the polar line plugin by Matt666...it looks like it will allow you to enter your azimuth and distance readings directly to input the survey measurements into your sketchup file, so you wouldn't need to convert the azimuth to a bearing.
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=10997&hilit=polarline
                                          Regardless of which method you use (azimuth/distance, bearing/distance, or coordinates) here is one way to orient the measurement data from multiple instrument locations in sketchup.
                                          1. enter the measurements from the first station location into sketchup
                                          2. draw lines between the resection points you measured from station1 to orient it with station2
                                          3. Select all and make a group/component called "station1"
                                          4. Hide the station1 group/component and then repeat steps 1 through 3 for the station2 data
                                          5. unhide the station1 group/component
                                          6. use the move tool to reposition the station2 group/component by grabbing the midpoint of the line you created between the resection points and moving it to the corresponding line midpoint in the station1 group/component
                                          7. use the rotate tool to complete the alignment of the station2 group/component by rotating the group about the midpoint of the station2 resection point line to make it align with the corresponding resection point line in the station1 group/component
                                          8. Now that the two stations are aligned you should check the distance between the corresponding resection points to ensure that you have an acceptable alignment.
                                          here are a few things you may want to consider when performing the measurements...
                                          Even though you can align the data using two points you should measure at least four resection points. The redundant points can be used to validate the alignment and also to achieve a better alignment if necessary.
                                          Ideally the resection points will lie outside of the boundary of the object your measuring, the span between the points should be greater than the distance between the two stations you are trying to orient, and the most accurate result is achieved when the apex angle formed by the station you are orienting and the resection points is 90 degrees.
                                          The measured relationship between the resection points will be slightly different from any two stations.. all of the variables (environment, instrument and target tolerances, etc..) are never going to let you get the same exact readings twice. Using the midpoint of the line created between the resection points allows you to average some of the error between the sightings, but the accuracy achieved from performing a two point resection alignment may not always meet your requirements.
                                          • E Offline
                                            eddix99
                                            Greg,
                                            A big thank you for your reply above. It's great that the community here put alot into helping out us noobs!
                                            I'm pretty sure that I understand your concept. The great thing about doing things within sketchup is that you can simply just grab the rotate tool and realign your data so that it fits. This means that you can get away with getting your backsight sorted AFTER you do your survey. As long as the data is in the right position from the station I would imagine it to be pretty easy to align it with existing points.
                                            One thing I really like about the survey tool.rb is that it puts the point in its own separate group. This means that I can group my groups together and add them to another layer. I did have a go with the plain ol' compass and line tool but I found that even lines on a hidden layer caused the current line to intersect with existing lines. This made selecting the line as a whole quite time consuming, especially if the lines were close together. Ideally I'd like a slightly beefed up survey tool to do all my work as It's extremely satisfying joining all the points together.
                                            I've attached my work so far using the survey tool only. From now on I have to use another station and therefore the survey tool is not feasible so its probably going to be finished using coordinates and the point cloud ruby.
                                            Please bear in mind that I have not done anything like this before and my file is definitely a work in progress.
                                            I'm still trying to get the concept of XYZ coordinates straight in my head
                                            My work so far
                                            • 1 / 2
