    Rotate texture
    7 Posts 5 Posters 3.3k Views 5 Watching
    • T
      tspco
      I just tried using the pin method for rotating a texture, with varied results. Is there a way to rotate the texture to a specific rotation, say 16 degrees without scaling the texture?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        Maybe you can with the new Plug of Tig: Texture Randomizer
        (put same value Min 16 and Max 16 at the rotation
        • massimoM
          massimo Moderator
          Try this. It's a must-have plugin.
          • ntxdaveN
            ntxdave
            I have another question related to the topic. I can rotate a texture without a problem but I cannot then apply the rotated texture to multiple faces.
            To keep it easy, I created a box and made it a group. I then applied a wooden texture to one of the faces of the box. I rotated the texture so that the grain ran horizontal to the ground rather than vertical. I wanted to then apply that rotated texture to the other faces of the box. I tried using the eye dropper to copy the texture but when I then clicked on another side the texture was applied to the new face in the vertical orientation instead of the horizontal orientation.
            I have also tried to just select the box (group) and apply the wood texture which was OK because it applied the texture to the entire box. However, when I then went to rotate the texture I could not see the Transform Texture selection in the context menu.
            Is there a way to do this that I am just missing?
            Press F1...thank me later
            • massimoM
              massimo Moderator
              Never apply textures to an entire group/component at once. Open the group-->apply the texture to a face-->rotate it-->pick the paint bucket tool-->alt+click on the face with the texture-->paint the adiacent face-->alt+click on that face and pick the adiacent face and so on.
              • cottyC
                cotty
                Or have a look at Fredo6s Thrupaint.
                my SketchUp gallery
                • ntxdaveN
                  ntxdave
                  Well, I did some more testing and this time I got the eye dropper to work so I did not have to use the alt+click methond (which BTW worked). I created my box. Applied the texture and then rotated it. Once again, after rotating I used the eye dropper to click on the rotated texture. I then just clicked on an additional face and it applied the rotated texture. I also tried a second time by doing the first 2 steps, then just selected the entire box (did not make it a group) and when I used the paint bucket while the entire box was selected, it applied the rotated texture to all sides........
                  Makes me wonder what I did the first time that the eye dropper method did not work........
                  I really appreciate the feed back from you and cotty......
