    Drawings for milling ????
    5 Posts 3 Posters 349 Views 3 Watching
    • K
      ksor
      When using a mill for metal you aften need do something like the attach file.
      How can I make such drawings ?
      I did the drawing by using the LINE-tool to draw the "connected faces" - but there must be a better method !
      test.skp
      Best regards
      KSor, Denmark
      Skype: keldsor
        You could use a shape representing the volume of space through which the cutter would pass. Intersect it with the shape then delete the cutter and the waste.
        test.skp
        • K
          ksor
          Yeah, but try do it and show me by attaching file
          Best regards
          KSor, Denmark
          Skype: keldsor
            I edited my previous post. No try. Just do.
            And yeahbuts live in the woods. πŸ˜„
            • TIGT
              Position/rotate, then intersect two or more suitable forms, and finally erase unwanted parts to leave the required 3d solid. Reverse/orient the object's faces so all of them look outwards consistently...
              Use a group/component for these to avoid raw geometry clashes/sticking whilst positioning/rotating etc.
              [Edit: Dave has now added an example to his earlier post...]
              If you have v8-Pro there are native 'Solid' tools to simplify the adding/subtracting/trimming etc of forms.
              There are also a couple of 'Boolean' scripts to do similar work for 'Free' - one is free [by Oscar?] the other is inexpensive [available via Smustard.com?]...
