    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Drawings for milling ????
    5 Posts 3 Posters 154 Views 3 Watching
      ksor
      When using a mill for metal you aften need do something like the attach file.
      How can I make such drawings ?
      I did the drawing by using the LINE-tool to draw the "connected faces" - but there must be a better method !
      test.skp
      Best regards
      KSor, Denmark
      Skype: keldsor
        You could use a shape representing the volume of space through which the cutter would pass. Intersect it with the shape then delete the cutter and the waste.
        test.skp
          ksor
          Yeah, but try do it and show me by attaching file
          Best regards
          KSor, Denmark
          Skype: keldsor
            I edited my previous post. No try. Just do.
            And yeahbuts live in the woods. πŸ˜„
            • TIGT Online
              Position/rotate, then intersect two or more suitable forms, and finally erase unwanted parts to leave the required 3d solid. Reverse/orient the object's faces so all of them look outwards consistently...
              Use a group/component for these to avoid raw geometry clashes/sticking whilst positioning/rotating etc.
              [Edit: Dave has now added an example to his earlier post...]
              If you have v8-Pro there are native 'Solid' tools to simplify the adding/subtracting/trimming etc of forms.
              There are also a couple of 'Boolean' scripts to do similar work for 'Free' - one is free [by Oscar?] the other is inexpensive [available via Smustard.com?]...
