    Arcs and Circle question
    16 Posts 7 Posters 1.1k Views 7 Watching
    • C
      Cubcrafter
      Is there a max size for the number of sides for circles and arcs. When I laser cut arcs and circles out of acrylic I want the sides to be as smooth as possible.
      • jason_marantoJ
        jason_maranto
        I used up to 360 sides to a circle for many objects without issue.
        Best,
        Jason.
          Seems 1 000 the maximum because I enter and 2 000 draw a circle 😉
          Entity Info gives 1 000 😉
          And when I recall the circle 1 000 was in the text box! ❗
          • thomthomT
            • thomthomT
              But question is, maybe you should be using a different tool that doesn't segment curves...?
              When I used the laser cutter I used either Rhino or Illustrator. Mainly Rhino. Never have to worry about the segmentation then. Worth considering if you're using the right tool for the right job.
              • jason_marantoJ
                jason_maranto
                Illustrator still segments -- just at a very fine level.
                Best,
                Jason.
                • thomthomT
                  ey? I've never seen that - not even when zoomed to the max.
                  • jason_marantoJ
                    jason_maranto
                    The preview is dynamic to keep it smooth at whatever zoom -- but Bézier curves are segmented to whatever the RIP (or whatever output device) decides at output time... technically there is no curve at all (until it is output) as it is just a visual construct for our needs.
                    But there is no device that I know of that can output a true Bézier curve without converting in some fashion (even a computer monitor).
                    Best,
                    Jason.
                    • thomthomT
                      Ah, yes - like that. Gotcha.
                      • C
                        Cubcrafter
                        Thanks guys.
                        I also have Rhino but I am trying to use SketchUp for all of my work. I have a commercial model building project for the U. S. Coast Guard. A generic cruise ship model for training classes. This is 8 feet long, 15 1/2" wide and 30" tall. This has all been created with SketchUp. I then export .svg files of the faces of the components, open these files with Corel and then send them to the laser.
                        I am working on the funnel right now and want to make it as smooth as I can.
                        Larry
                        • jason_marantoJ
                          jason_maranto
                          If you are not already using this http://forums.sketchucation.com/viewtopic.php?p=100509 I would use it, as it can dynamically change the segments like circles/arcs and is very flexible.
                          BTW Thomthom I feel like a fool saying anything at all to you since I eagerly await your outstanding looking "Bezier Surface" plugin.
                          Best,
                          Jason.
                          • thomthomT
                            I'm eager to get it out there as well. But it's a somewhat bigger task than I first thought. But it will come. When you see the update of Vertex Tools you can be sure Bezier Surface will speed up production. (They both share some code I'm currently working on. So they both benefit.)
                            • Jean LemireJ
                              Jean Lemire
                              Hi folks.
                              See attached image to see that SU accept up to 9999 sides in the Entity info window. At 10000 it gives the message shown by Thomthom. Is the limit 999 or 9999 ?
                              Funny.
                              • thomthomT
                                It's 9999 - the messagebox is lying. Maybe it was an old limit and the text not updated.
                                • C
                                  chrisjk
                                  On the Mac it appears to be 1000 upper limit.
                                  https://img.skitch.com/20120229-k14suabby1eurqf2di8g8bsrjf.jpg
                                  Chris
                                  • TIGT
                                    With 360 segments a circle has only 1 degree subtended for each segment, irrespective of the segments' length.
                                    With more segments the shorter the segment length for the same radius; but the sensible [self-imposed] upper limit should be something like 1.mm [or a lot less to be practical for large radii!].
                                    The circumference of a circle is 2PIr, so to work backwards from a radius to 1.mm segments use
                                    numsegs=(2*Math::PI*radius/1.mm).to_i
                                    As the radius increases the number goes up proportionally...
                                    radius >>> numsegs
                                    1.mm >>> 6
                                    5.mm >>> 31
                                    10.mm >>> 62
                                    50.mm >>> 314
                                    100.mm >>> 628
                                    1000.mm >>> 6283
                                    etc...
                                    Note that ~1591.mm is therefore the radius limit as ~9999 segments gives segments of ~1.mm long.
                                    So a circle about 3m/10' across is the limit for 1/mm segments... BUT of course thousands of circle segments translates to many more thousands of edges and facets when it's extruded into 3d... which is a sure fired way to kill your model! So don't be silly!! 😒
