    Is it Possible to put a Texture to V-plane?
    renderpluginsextensions
    11 Posts 6 Posters 8.7k Views 6 Watching
    • P Offline
      pololo
      Is it Possible to put a Texture to V-plane /infinite ground plane in vray 1.49.01 for sketchup?? πŸ˜’
      • eidam655E Offline
        eidam655
        no. πŸ˜„
        I'm using SketchUp 2017, V-Ray 3.4
        • andybotA Offline
          andybot
          Actually - would it be possible as long as you use the vray uv setting instead of from SU? I'll try it when I have a chance.
          • P Offline
            pololo
            I understand... thanks Eidam , Andy!! Well, I'll try it another way. 😐
            • eidam655E Offline
              eidam655
              i read somewhere that the VRay plane cannot be textured (accepts only the color from SU's material).
              the information about vray infinite plane [in rhino, but since no texture is showing up in my tests...]
              andy, i've no idea what exactly you mean πŸ˜„ i'd be very eager to see your results.
              • andybotA Offline
                andybot
                if you use UV mapping of "UVWGenPlanarWorld" for your material, you can use a texture on the infinite plane. The repeat amount is inverse (for example 8" = 0.125 repeat) Here's an example
                • P Offline
                  pololo
                  Amazing!!!!!!!!!!!!!!!!!!!!! Thank you so much Andy!!! πŸ‘
                  • majidM Offline
                    majid
                    handy trick πŸ‘
                    • eidam655E Offline
                      eidam655
                      πŸ‘ πŸ‘
                      this is awesome. i just tried to apply a bump texture with the same method, and it works.
                      i wonder why is this not in any pdf manual?
                      EDIT: displacement doesn't work.
                      • jonedvardJ Offline
                        jonedvard
                        soooo - i'm not getting this.
                        i created an infinite plane - applied my texture to the infinite plane. hit render - nothing.
                        andy - can you explain the 8"=.125 ?
                        thanks
                        • faBcnF Offline
                          faBcn
                          Thanx a lot, itΒ΄s first time I see the answer !!
                          To be more precise, and for those who work in other units than inches like in Europa, let's take an example :
                          Wood parquet floor in SU : go and check texture size by clicking on Edit in SU Materials.
                          I work in cm, so it tells me : 304.8 cm x 121.9 cm.
                          You convert in inches (1 inch = 2.54 cm), or for lazy bums, you go and change units in Model info / units.
                          So it turns that texture size is 120" x 48".
                          Take the smaller value, and inverse : 1/48 = 0.02
                          Fill in Repeat on 3 axis (even though this a 2D image) : X 0.02, Y 0.02 Z 0.02
                          And thatΒ΄s it !
