    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 95.8k Views 23 Watching
    • sdmitchS Offline
      sdmitch
      I beg to differ. The faces pointing into the room are front faces. I only apply material to the front face so, if they were back faces, you would not be able to see it.
      Making the tiles components is impractical. Yes, all the full tiles could be a single component, but any and all partials would have to be unique components. You could not edit one and affect them all.
      http://sdmitch.blogspot.com/
      • massimoM Offline
        massimo Moderator
        Then I'm probably doing something wrong. It's the same starting with a back or a front face.
        That's why it would be really useful. πŸ˜‰
        • guanjinG Offline
          guanjin
          @sdmitch said:
          Yet another final update with the option to add tiles to the grid.
          Same face of the front are generally below, upside down is a problem
          I come from China, is to learn
          • sdmitchS Offline
            sdmitch
            Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
              Mra
              The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
              One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
              • sdmitchS Offline
                sdmitch
                mra, you are right. Don't know why I thought that actual tiles were necessary.
                massimo, It seems you were right also. It seems that the pushpull operation "flips" the face and apparently moves the texture to the back. How weird is that.
                • Z Offline
                  ZFRPS
                  Hi:
                  Dear sdmitch,your plugin nice,maybe have little need to change:
                  sketchup is bim
                    SUFractal
                    Sdmitch ... I was getting an odd result when I tried your latest update. Some of the tiles were positioned low, and some were high ... and faces were flipped too?
                      tomot
                      Hi:
                      Please lets not get carried away here! whats ... next a request for the actual supporting hanger holes and hanger wires? πŸ‘Ž
                      [my plugins](http://thingsvirtual.blogspot.ca/)
                      tomot
                        SUFractal
                        @tomot said:
                        Hi:
                        πŸ˜„
                          tomot
                          It should be noted that not all ceiling tiles are designed to simply drop into the metal grid, some manufacturers also provide Ceiling tiles that do indeed project below the metal grid hence providing a nice rebated look to the entire ceiling.
                          Regardless its great to see the option of adding real tiles or using a texture map. πŸŽ‰
                          tomot
                            SUFractal
                            Good point tomot ... I agree with you.
                            One benefit of the individual tiles being created is the ability to switch them out with a lighting fixture.
                            • gullfoG Offline
                              gullfo
                              @tomot said:
                              Hi:
                              next thing people will want an algorithm to place light and vent openings πŸ‘Ώ πŸ‘Š
                              Glenn
                              http://www.runnel.com
                              • sdmitchS Offline
                                sdmitch
                                Was this a one time thing or have you had this result on other occasions. I have never seen this.
                                Anyone else having this problem?
                                  SUFractal
                                  I tried a handful of times and kept getting the same result unfortunately. And it was a simple rectangular ceiling shape.
                                    tomot
                                    FYI: In several previous version I was able to add tiles sizes, see attached pic, when I do the same with the current version I get a ruby console error Ceiling Grid.rb:95:in `max'
                                    tomot
                                    • sdmitchS Offline
                                      sdmitch
                                      tomat, check the case of the "x" in the options. It looks like lower case which will not match the "X" in the case statement.
                                      • gullfoG Offline
                                        gullfo
                                        seems to work perfect. including complex ceilings. but... if you have the face @ zero on the z-axis, you do see the inverted faces which are flush with the grid and not dropping through. so just make sure your ceiling face is above the zero plane... then again i may have spoke too soon... a complex ceiling definitely exhibits some strange results even when sitting above the 0 on z-axis...
                                        ceiling tile example
                                        result from face @ zero on z-axis
                                        complex ceiling.skp
                                        Glenn
                                          SUFractal
                                          Each time I've tried (and just did again), my ceiling plane was 'elevated'. The plugin worked perfectly until this last tweak ... I'm no programmer or ruby person, but it would appear something occurred w/in the last effort?
                                          I've also tried both 2 x 2 and 2 x 4 grids.
                                            tomot
                                            YES! YES!...... I forgot to read my own Sticky note "Watch the use of case" 😳
                                            (if the SU API Ruby Console was more inclusive by incorporating the entire Ruby reference perhaps this error would have been properly flagged when a script is run)
                                            tomot
                                            • 3 / 5
