    [Plugins] TIG-splitTOOLS
    50 Posts 17 Posters 75.5k Views 17 Watching
      mwm5053
      I didn't change the script at all, seems to work fine now but I still have to view with hidden geometry on to see the dashed lines with hidden geo off I see no subdivision. The reason it SU was not responding was because I did it twice because thinking it didn't work the first time just misunderstood the concept here I guess.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • TIGT Online
        OK - glad everything seems to be working OK now ๐Ÿ˜„
          Does this can work with V 7 ? (I have used the second Zip file)
          Because I have nothing to enable in the SubMenu / Toolbar ๐Ÿ˜ฎ
          Edit : ahhhhhhhh! ๐Ÿ˜ณ
          I must add by hand the 3 variations Split, SplitDonut, SplitSausage from other threads! ๐Ÿ˜ฒ
          That is a curious intallation! ๐Ÿ’š
          Why not all in one file zipped ? ๐Ÿ˜ฎ
          I must miss something ๐Ÿ˜„
          • TIGT Online
            It should work will all SUp versions...
            The tools were written as separate utilities - they have their own threads...
            This tool simply provides a toolbar/Tools-submenu IF the tools are already installed...
            There are clear links on the download page to get the three main tools AND the Extrusion Tools zipped set if you want to add some of those tools by editing the script yourself...
              Ok thx for the explanation! ๐Ÿ˜Ž
              • panixiaP Offline
                panixia
                hi tig i'm going crazy attempting to install the plugin on 8proM2 (running on win7x64) but unfortunately it seems not to work at all!
                it does not show neither in any plugin/tools/context menu or toolbars list..
                i tryed to install it both automatically (using both the su built-in installer and the tt plugin installer) i also try to install it manually with copy/paste into the plugin folder but just didn't work for me?
                is there any possible solution?
                  schnydix
                  HelloIInstallet tigs split tools withtomtoms installer but ihave no Plugin and no icons in sketchup ?
                  Latest sketchup version on XP Any Idea Why?
                  Thanks for help and for all your workings here
                  • TIGT Online
                    It is pointless installing this script "on its own"...
                    It will only do anything IF you have also installed one or more of the three 'Split...' tools' scripts, which are clearly listed on the download page, AND even linked off to those tools' own download pages, to help you get them relatively easily.
                    This script simply provides a tools-submenu/toolbar[actived from view>toolbars] IF one or more of the 'Split...' scripts is found to be installed.
                    Note too that if you want the related 'EEby...' tools adding to the submenu/toolbar you will need to install the files for that toolset too [again it's clearly linked off to the download page] AND in this case you will need to edit the script itself, using a plain text editor [Notepad++ etc] and remove the '#' in front of those tools' code you want to include...
                    All of this is clearly explained in the script itself too...
                    ๐Ÿ˜•
                    • panixiaP Offline
                      panixia
                      yeah i was missing pieces.. it's working fine now.. thanks TIG
                      • G Offline
                        gelbuilding
                        Thanks Tig,
                        Cannot wait to try.
                          cuttingedge
                          Hi TIG, been waiting for this tool, Its great that there's a tool to divide the face equally. I always thought this should have been native to sketchup. Im just wondering if you can include the option for "split vertical only" or "split "horizontal only" rather than if I type 4 for example , it divides the face 4x4. (not sure though if vertical or horizontal is the correct term as the face may not be along x,y or z)
                          Actually what Ive been looking for is something like "connect" in 3ds max, where it split the faces when you connect the selected edges in specified number (if youre familiar with it.)
                          The easiest is to copy one edge to the other and say โ€œ/4โ€ if you wanna divide by four, but this is possible only with regular perpendicular quads similar to what you have suggested here:
                          http://forums.sketchucation.com/viewtopic.php?f=79&t=27689&p=240018&hilit=+connect+tool+#p240018
                          Anyways, There may be a tool for this already that Im not fmiliar with. Thanks.
                          • N Offline
                            niks
                            thank Tig..
                            I'm lost here
                            could someone highligh what to delete
                            =begin
                            (c) TIG 2012
                            Script:
                            TIG-splitTOOLS.rb
                            Makes a Tools menu submenu and toolbar 'Split Tools' which run the
                            following tools;-
                            -SplitUp
                            http://forums.sketchucation.com/viewtopic.php?p=377338#p377338
                            -SplitDonut
                            http://forums.sketchucation.com/viewtopic.php?p=386601#p386601
                            -SplitSausage
                            http://forums.sketchucation.com/viewtopic.php?p=386610#p386610
                            See there respective threads...
                            Download and install each of the individual tools as desired...
                            If you don't have a tool installed then there'll be no button/menu-item.
                            ### CURTAILED BY TIG...
                            • TIGT Online
                              niks
                              What's up ๐Ÿ˜•
                              Please explain your issue clearly...
                              You don't normally need to 'delete' anything.
                              You don't need to edit the file, unless it is that you want to add some of the extra 'ExtrusionTools' onto the toolbar and then as explained in the file itself, you remove the # in front of the line that sets up that tool - e.g. **#**eeo=true... >>> eeo=true. The full set of Extrusion tools must of course be installed separately for this to work...***
                              Also please don't post 'whole scripts' in code-blocks like that - it just leads to confusion.
                              I have curtailed your post accordingly...
                              ***If you read what it says in the file/help... there are a bunch of links given to various tools, IF you have these tools in your Plugins folder they are added to the toolbar, if not then they are not - so you need at least one tool loading to get a toolbar...
                              • TIGT Online
                                http://sketchucation.com/forums/viewtopic.php?p=377338#p377338 is the very first link given that takes you to the SplitUp tool's download page...
                                • N Offline
                                  niks
                                  hi tig i apologize for codes i posted i won't do that again next time.
                                  my only issue is i do not know where the split tool is, not showing in Plugin list showed in the video.. the split sausage and split donnut tools is showning fine.
                                  i will figure this myself i will read again and again ๐ŸŽ‰ ..Great Script Thank you ๐Ÿ‘
                                  • N Offline
                                    niks
                                    thank you. i have not download that one
                                    the one i download are two of your attachment on this thread. Thank you for being patient with me.
                                    Works! ๐Ÿ˜„
                                      Seems there is a glitch with the Split tools! ๐Ÿ˜ฒ
                                      Manual or automatic install
                                      There are well in the Plugins folder but nothing appear on the menu Tools of the 2014!
                                      Don't appear on the Tools bar, on the Preference extensions
                                      I used the French version of Su Make
                                      All other plugs like Solid Solver are works fine on the same menu Tools
                                      • TIGT Online
                                        This script makes the Tools 'Split Tools' submenu entry and/or Toolbar... BUT only if you have at least one of these Plugins installed TIG-splitdonut/TIG-splitsauage/SplitUp.rb ???
                                        You must install these individually from the PluginStore...
                                        Works fine for me...
                                          Aaaaaaaaaaaaaaaaaaah ! ๐Ÿ˜ณ
                                            Works fine! ๐Ÿ˜‰
                                            • 2 / 3
