    [Plugins] TIG-splitTOOLS
    50 Posts 17 Posters 79.4k Views 17 Watching
      Ok thx for the explanation! 😎
      • panixiaP Offline
        panixia
        hi tig i'm going crazy attempting to install the plugin on 8proM2 (running on win7x64) but unfortunately it seems not to work at all!
        it does not show neither in any plugin/tools/context menu or toolbars list..
        i tryed to install it both automatically (using both the su built-in installer and the tt plugin installer) i also try to install it manually with copy/paste into the plugin folder but just didn't work for me?
        is there any possible solution?
          schnydix
          HelloIInstallet tigs split tools withtomtoms installer but ihave no Plugin and no icons in sketchup ?
          Latest sketchup version on XP Any Idea Why?
          Thanks for help and for all your workings here
            It is pointless installing this script "on its own"...
            It will only do anything IF you have also installed one or more of the three 'Split...' tools' scripts, which are clearly listed on the download page, AND even linked off to those tools' own download pages, to help you get them relatively easily.
            This script simply provides a tools-submenu/toolbar[actived from view>toolbars] IF one or more of the 'Split...' scripts is found to be installed.
            Note too that if you want the related 'EEby...' tools adding to the submenu/toolbar you will need to install the files for that toolset too [again it's clearly linked off to the download page] AND in this case you will need to edit the script itself, using a plain text editor [Notepad++ etc] and remove the '#' in front of those tools' code you want to include...
            All of this is clearly explained in the script itself too...
            πŸ˜•
            • panixiaP Offline
              panixia
              yeah i was missing pieces.. it's working fine now.. thanks TIG
                gelbuilding
                Thanks Tig,
                Cannot wait to try.
                  cuttingedge
                  Hi TIG, been waiting for this tool, Its great that there's a tool to divide the face equally. I always thought this should have been native to sketchup. Im just wondering if you can include the option for "split vertical only" or "split "horizontal only" rather than if I type 4 for example , it divides the face 4x4. (not sure though if vertical or horizontal is the correct term as the face may not be along x,y or z)
                  Actually what Ive been looking for is something like "connect" in 3ds max, where it split the faces when you connect the selected edges in specified number (if youre familiar with it.)
                  The easiest is to copy one edge to the other and say β€œ/4” if you wanna divide by four, but this is possible only with regular perpendicular quads similar to what you have suggested here:
                  404 Not Found
                  (forums.sketchucation.com)
                  Anyways, There may be a tool for this already that Im not fmiliar with. Thanks.
                  • N Offline
                    niks
                    thank Tig..
                    I'm lost here
                    could someone highligh what to delete
                    =begin
                    (c) TIG 2012
                    Script:
                    TIG-splitTOOLS.rb
                    Makes a Tools menu submenu and toolbar 'Split Tools' which run the
                    following tools;-
                    -SplitUp
                    http://forums.sketchucation.com/viewtopic.php?p=377338#p377338
                    -SplitDonut
                    http://forums.sketchucation.com/viewtopic.php?p=386601#p386601
                    -SplitSausage
                    http://forums.sketchucation.com/viewtopic.php?p=386610#p386610
                    See there respective threads...
                    Download and install each of the individual tools as desired...
                    If you don't have a tool installed then there'll be no button/menu-item.
                    ### CURTAILED BY TIG...
                      niks
                      What's up πŸ˜•
                      Please explain your issue clearly...
                      You don't normally need to 'delete' anything.
                      You don't need to edit the file, unless it is that you want to add some of the extra 'ExtrusionTools' onto the toolbar and then as explained in the file itself, you remove the # in front of the line that sets up that tool - e.g. **#**eeo=true... >>> eeo=true. The full set of Extrusion tools must of course be installed separately for this to work...***
                      Also please don't post 'whole scripts' in code-blocks like that - it just leads to confusion.
                      I have curtailed your post accordingly...
                      ***If you read what it says in the file/help... there are a bunch of links given to various tools, IF you have these tools in your Plugins folder they are added to the toolbar, if not then they are not - so you need at least one tool loading to get a toolbar...
                        http://sketchucation.com/forums/viewtopic.php?p=377338#p377338 is the very first link given that takes you to the SplitUp tool's download page...
                        • N Offline
                          niks
                          hi tig i apologize for codes i posted i won't do that again next time.
                          my only issue is i do not know where the split tool is, not showing in Plugin list showed in the video.. the split sausage and split donnut tools is showning fine.
                          i will figure this myself i will read again and again πŸŽ‰ ..Great Script Thank you πŸ‘
                          • N Offline
                            niks
                            thank you. i have not download that one
                            the one i download are two of your attachment on this thread. Thank you for being patient with me.
                            Works! πŸ˜„
                              Seems there is a glitch with the Split tools! 😲
                              Manual or automatic install
                              There are well in the Plugins folder but nothing appear on the menu Tools of the 2014!
                              Don't appear on the Tools bar, on the Preference extensions
                              I used the French version of Su Make
                              All other plugs like Solid Solver are works fine on the same menu Tools
                                This script makes the Tools 'Split Tools' submenu entry and/or Toolbar... BUT only if you have at least one of these Plugins installed TIG-splitdonut/TIG-splitsauage/SplitUp.rb ???
                                You must install these individually from the PluginStore...
                                Works fine for me...
                                  Aaaaaaaaaaaaaaaaaaah ! 😳
                                    Works fine! πŸ˜‰
                                      Here's v2.0
                                      The three 'Split' tools are now included in this tool's RBZ. They are signed for v2016.
                                      404 Not Found
                                      (sketchucation.com)
                                      There is no need to install the separate Split tools.
                                      These will no longer be available from the PluginStore individually...
                                        johnnygitarr
                                        hi TIG,
                                        thank you for the split tool plugin. its very usefull.
                                        can you uprade the tool for also splitting triangles in quadfaces?
                                        (draw a line perpendicular from each side of the triangle to the midpoint
                                        of the triangle = then you have a quadface triangle).
                                        greetings
                                        johnny
                                          There is a tool already,,,
                                          https://sketchucation.com/pluginstore?pln=Quadrilateralizer
                                          If there's more than one connected face, then you need to do the following steps...
                                          If you select the required face, then make it into a group, edit that group, then next run the tool on the freshly selected face - if desired you can exit the edit and explode the temporary group...
                                          Edit: This recent extension might also be of interest...
                                          https://sketchucation.com/pluginstore?pln=SB_Trilateration
                                            CesPv
                                            Where can I download the others split tools?? I can use anything because I don't have SplitUp, SplitDonut and SplitSausage.. Help!!
                                            • 2 / 3
