    [Plugins] TIG-splitTOOLS
    50 Posts 17 Posters 79.4k Views 17 Watching
    • DareDevilD Offline
      DareDevil
      Here's v1.0
      Here's v1.1
      Here's v1.2
      Too fast !!! I will wait next week for the v3.6 😆 😆
      Thanks TIG 👍 👍
        mwm5053
        Must be something I'm doing wrong or did. I installed TIG-splitTOOLS-20120219a.rbz ,SplitUp v1.5 20120219 and the newest Split doughnut and sausage and Su stops responding after making the split, I watched the video Rich did for SplitUp so I'm pretty sure I'm doing it right any suggestions?
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • TIGT Online
          Walt
          The result looks OK as far as it goes - but the split edges should be 'smoothed'.
          There's a lot more to that error message than you show.
          Retry, then scroll up and print the start of the error - which tells us where the error originates - the ending of the message only shows the outcome and some other weirdly affected tools [the closing errors have nothing to do with these tools at all 😕 ].
          Have you edited the script[s] at all - e.g. using a wordprocessor rather than a plain-text editor ?
          It looks like the TIG-splitTOOLS.rb file's code has been somehow garbled - so the splitup code is executed and it's running straight on into loading splitdonut/splitsausage's code without completing it's task - which of course it shouldn't in a valid installation of the file ! 😲
          This can occur if a wordprocessor were used on the file, because extra formating is added to the file.
          I suspect this as the main-suspect [Plan A].
          Could you also try getting the ZIP version and then manually extracting and installing the file/subfolder as directed - I am wondering if something in the v8M2 MAC's RBZ auto-installer is adrift... 😮 Plan B.
          Some scripts like SketchyPhysics or DrivingDimensions can mess with base-classes ill-advsedly - these can then cause unexpected results in 'legitimate' tools using some 'group' related commands - but I'd not expect that here... If you have an of these or other obscure scripts can you try disabling them and retry... 😕 Plan C.
            Not yet test this new plugin 😳
            but what is the difference with Show Hidden Geometry ?
            There is a new "triming" of surfaces?
            • TIGT Online
              This new tool assembles some other tools in a submenu/toolbar.
              They are useful for subdividing [SPLITting] faces etc.
              • SplitUp divides selected 'quad'/'quad-donut' faces into smaller 'quads' [new edges are smoothed - use View > Hidden Geometry ON to see them]
              • SplitDonut divides any number of selected donut shaped faces [e.g. a 'ring' made with FollowMe] into 'quads' - four sided faces: a 'donut' has an outer loop and just ONE inner loop, AND both loops must have the same number of vertices. The new edges remain selected so you can choose to smooth/hide them etc.
              • SplitSausage divides ONE selected sausage shaped face [e.g. a 'squiggle' made with FollowMe] into 'quads' - four sided faces: you must also select ONE edge belonging to that face to use as the 'seed' for the new quads; if there's an uneven number of vertices the last dividing edge makes a triangular face [rather than a 'quad']. The new edges remain selected so you can choose to smooth/hide them etc.
              • Optionally, some EEby... tools can also be added to the submenu/toolbar by a simple edit of the script, if desired.
                mwm5053
                Thanks TIG, my mistake didn't realize SplitUp was a hidden geometry thing the other two SDoughnut and SSausage did't seem to be that way created true geometry. Is this the case? Again thanks for the plugin 👍
                2011 iMac
                V2 Twilight
                • TIGT Online
                  The SplitUp new edges are auto-smoothed [there are likely to be a lot of them and manually adjusting just them could be a pain], but the other two tools make new 'plain-edges' [you might want this type of division NOT smoothed etc] - however, the tools end with all of these new edges selected... so you can then use Entity Info to adjust their 'smooth' setting if desired...
                  Walt: What happened with the error message posted earlier ??
                    mwm5053
                    I'm guessing that since I didn't know about the hidden geo thing. I was performing the operation twice, that caused the hang up the screen shot shows the first attempt no geometry shown and performing operation again shows new geometry but no error in ruby window because of not responding I have the SU repot if you want but it was quite lengthy.
                    2011 iMac
                    V2 Twilight
                    • TIGT Online
                      Please post these error-message[s].
                      Something is wrong. 😕
                      The new edges should be made 'smoothed' and will therefore appear 'dashed' in Hidden Geom' ON or not be seen with it OFF...
                      These new edges look 'solid', so it's NOT completing properly.
                      Can you also answer my other questions about 'editing' etc that might have broken things...
                        mwm5053
                        I didn't change the script at all, seems to work fine now but I still have to view with hidden geometry on to see the dashed lines with hidden geo off I see no subdivision. The reason it SU was not responding was because I did it twice because thinking it didn't work the first time just misunderstood the concept here I guess.
                        2011 iMac
                        V2 Twilight
                        • TIGT Online
                          OK - glad everything seems to be working OK now 😄
                            Does this can work with V 7 ? (I have used the second Zip file)
                            Because I have nothing to enable in the SubMenu / Toolbar 😮
                            Edit : ahhhhhhhh! 😳
                            I must add by hand the 3 variations Split, SplitDonut, SplitSausage from other threads! 😲
                            That is a curious intallation! 💚
                            Why not all in one file zipped ? 😮
                            I must miss something 😄
                            • TIGT Online
                              It should work will all SUp versions...
                              The tools were written as separate utilities - they have their own threads...
                              This tool simply provides a toolbar/Tools-submenu IF the tools are already installed...
                              There are clear links on the download page to get the three main tools AND the Extrusion Tools zipped set if you want to add some of those tools by editing the script yourself...
                                Ok thx for the explanation! 😎
                                • panixiaP Offline
                                  panixia
                                  hi tig i'm going crazy attempting to install the plugin on 8proM2 (running on win7x64) but unfortunately it seems not to work at all!
                                  it does not show neither in any plugin/tools/context menu or toolbars list..
                                  i tryed to install it both automatically (using both the su built-in installer and the tt plugin installer) i also try to install it manually with copy/paste into the plugin folder but just didn't work for me?
                                  is there any possible solution?
                                    schnydix
                                    HelloIInstallet tigs split tools withtomtoms installer but ihave no Plugin and no icons in sketchup ?
                                    Latest sketchup version on XP Any Idea Why?
                                    Thanks for help and for all your workings here
                                    • TIGT Online
                                      It is pointless installing this script "on its own"...
                                      It will only do anything IF you have also installed one or more of the three 'Split...' tools' scripts, which are clearly listed on the download page, AND even linked off to those tools' own download pages, to help you get them relatively easily.
                                      This script simply provides a tools-submenu/toolbar[actived from view>toolbars] IF one or more of the 'Split...' scripts is found to be installed.
                                      Note too that if you want the related 'EEby...' tools adding to the submenu/toolbar you will need to install the files for that toolset too [again it's clearly linked off to the download page] AND in this case you will need to edit the script itself, using a plain text editor [Notepad++ etc] and remove the '#' in front of those tools' code you want to include...
                                      All of this is clearly explained in the script itself too...
                                      • panixiaP Offline
                                        panixia
                                        yeah i was missing pieces.. it's working fine now.. thanks TIG
                                          gelbuilding
                                          Thanks Tig,
                                          Cannot wait to try.
                                            cuttingedge
                                            Hi TIG, been waiting for this tool, Its great that there's a tool to divide the face equally. I always thought this should have been native to sketchup. Im just wondering if you can include the option for "split vertical only" or "split "horizontal only" rather than if I type 4 for example , it divides the face 4x4. (not sure though if vertical or horizontal is the correct term as the face may not be along x,y or z)
                                            Actually what Ive been looking for is something like "connect" in 3ds max, where it split the faces when you connect the selected edges in specified number (if youre familiar with it.)
                                            The easiest is to copy one edge to the other and say “/4” if you wanna divide by four, but this is possible only with regular perpendicular quads similar to what you have suggested here:
                                            404 Not Found
                                            (forums.sketchucation.com)
                                            Anyways, There may be a tool for this already that Im not fmiliar with. Thanks.
                                            • 2 / 3
