    Create Icons for Plugins?
    11 Posts 6 Posters 924 Views 6 Watching
    • Bob JamesB Offline
      Bob James
      I have several plugins that have no icon. Is there a way for me to create icons for them?
        If you mean by Ruby code then yes....
        If you look at the code of a simple plugin that uses an icon you can then apply that to one that doesn't.
        if not file_loaded?(File.basename(__FILE__))
        	new_menu = UI.menu("Draw").add_submenu("Pen Tool +")
        	new_toolbar = UI;;Toolbar.new("Pen Tool +")
        	plugins = Sketchup.find_support_file("Plugins")
        	imgdir = File.join(plugins, "rob_hsltool")
        	cmd = UI;;Command.new("Soft Draw")  {Sketchup.active_model.select_tool(SLineTool.new())  }
        	cmd.small_icon = File.join(imgdir, "sline16x16.png")
        	cmd.large_icon = File.join(imgdir, "sline24x24.png")
        	cmd.tooltip = "Soft Draw"
        	cmd.menu_text = "Soft Draw"
        This is from my/TIG's Pen Tool+. It adds a menu item to the Draw menu then assigns it to a toolbar where it's icons reside in the 'rob_hsltool' folder. Further down it references the small and large icons and some tool tip text when you hover over the icon. There are other things it referencing like classes.
        I've a very custom set of toolbars that I built from various tools with custom icons. The problem arises when someone updates a plugin and then your digging around trying to see what changed etc.
        I'm sure one of the gurus will correct my very rudimentary understanding of it but that's my 2 cents.
          Hay you icon creating maniacs - post them icons back to the developer and it will probably go into the next release. Often icons aren't made because it simply takes time to do them.
          hmmm... community project?
          • fredo6F Offline
            fredo6
            Not just a matter of time, but of artistic capability....!
            Fredo
            • CadFatherC Offline
              CadFather
              ask, and you shall receive! ☀
              • U Offline
                unclex
                Question 2
                How to make a Toolbar within different RB file?
                  CadFather
                  you give the toolbars the same name - then the icons will be in one toolbar
                    Sure?
                    I thought you got two different toolbars. Thought the only way was to share the Toolbar object...
                      At least, if the toolbar has been displayed it won't accept new buttons....
                        CadFather
                        well, that's what i do to group icons - if you share the same menu name, you will get two menus but in the case of toolbars it works. (this tip was from master fredo long time ago)..
                        • U Offline
                          unclex
                          A lots of Billiant Plugins
                          But
                          Perhaps, should need a Standard for write Plugins
                          Such as
                          module Somebody
                          class Something
                          def Somejob
                          it make plugins less conflict
                          and easier for someguy Creating Icons
