    Steel staircase
    32 Posts 17 Posters 3.3k Views 17 Watching
    • U Offline
      unclewk
      Hi guys. This is a steel staircase outside my local Tesco. The structure is quite simple so I modeled it during my free time and here I wish to share with you some of the rendering.
      • jo-keJ Offline
        jo-ke
        brilliant and clean work!
        http://www.zz7.de
          Slimdog
          Good work man. Looks like you have a good understanding of how steel goes together.
          • hellnbakH Offline
            hellnbak
            Very well done 👍
              congellous
              Why did you model that ?
              • soloS Offline
                solo
                I'd guess for the same reason I model all sorts of stuff when I get the time, to learn and keep skills up, not forgetting SU is fun.
                http://www.solos-art.com
                • hellnbakH Offline
                  hellnbak
                  Because it was there
                    raineysky
                    It looks great!!! Could you please tell us which plugins you used.
                    • mojtabata2001M Offline
                      mojtabata2001
                      elegant and accurate 👍
                      • gillesG Offline
                        gilles
                        It can be done without any plugin.
                        • cheddaC Offline
                          chedda
                          Excellent modelling (i'm pretty sure he used pipe along path .rb)
                          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                          • U Offline
                            unclewk
                            Thanks, jo-ke.
                            Yes, Slimdog, I'm a civil/structural drafter by profession, I've done quite a lot of steel structure drafting over the years.
                            Thanks, Steve.
                            Hi Stanley, your question was answered by Pete and Steve. Thanks. 3D is fun with SU.
                            Paul, the structure is rather straight forward, it can be done in SU without any plugin, as pointed out by gilles. Thanks.
                            Mojtaba, thanks.
                            Hi chedda, thanks. No "pipe along path", only "follow me".
                            • H Offline
                              Howard leslie
                              Donald,
                              Really good model, thanks for showing it.
                              Like you, I get involved with modelling steelwork structures.
                              A couple of plug-ins you may want to try that are VERY useful for such work:
                              Profile Builder
                              http://www.smustard.com/script/ProfileBuilder
                              Invaluable - well worth the £ / $
                              StairCaseBuilder
                              A DC I've written to help model staircases - so you don't have to do everything by hand
                              http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
                              Hope this helps
                              Howard L'
                              • U Offline
                                unclewk
                                Thanks, Howard, will check 'em out.
                                  redfox11
                                  Great staircase! Are all connections welded?
                                  http://sketchupengineering.blogspot.com/
                                  • U Offline
                                    unclewk
                                    Thanks, Alexander.
                                    I'm not too sure about the actual construction sequence as this is not one of my project, but in normal practice, connector plates will be welded to main members in factory and connections on site are preferably bolts and nuts, ie. base plated welded to stanchion in factory and the whole thing bolted to stump on site; and connector plates welded to stanchions in factory so the landing beams could be bolted to stanchion on site.
                                    • pmolsonP Offline
                                      pmolson
                                      Free Time...What is that? 😕
                                        Cyberdactyl
                                        That was going to be my question.
                                        I see the handrails appear to be welded to the diamond plate and also there's a solid connection between the building and the staircase by the handrails.
                                        I would also suggest kick plates under the handrails on at least the third level, if not the second.
                                          congellous
                                          @unclewk said:
                                          Thanks, jo-ke.
                                          Thanks, Steve.
                                          Mojtaba, thanks.
                                          I wasn't being rude, if I was looking at your portfolio, unless you wanted to do the external steel detailing in my office I would wonder what your intention was.
                                          • U Offline
                                            unclewk
                                            Thanks for your reminder, Stanley, next time I'll make sure I declare my "intention" prior to posting any image here, I'm sure this is stated in the forum policy somewhere.
                                            • 1 / 2
