    Steel staircase
    32 Posts 17 Posters 3.5k Views 17 Watching
    • gillesG
      gilles
      It looks great!!! Could you please tell us which plugins you used.
      It can be done without any plugin.
      • cheddaC
        chedda
        Excellent modelling (i'm pretty sure he used pipe along path .rb)
        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
        • U
          unclewk
          Thanks, jo-ke.
          Yes, Slimdog, I'm a civil/structural drafter by profession, I've done quite a lot of steel structure drafting over the years.
          Thanks, Steve.
          Hi Stanley, your question was answered by Pete and Steve. Thanks. 3D is fun with SU.
          Paul, the structure is rather straight forward, it can be done in SU without any plugin, as pointed out by gilles. Thanks.
          Mojtaba, thanks.
          Hi chedda, thanks. No "pipe along path", only "follow me".
          • H
            Howard leslie
            Donald,
            Really good model, thanks for showing it.
            Like you, I get involved with modelling steelwork structures.
            A couple of plug-ins you may want to try that are VERY useful for such work:
            Profile Builder
            http://www.smustard.com/script/ProfileBuilder
            Invaluable - well worth the Β£ / $
            StairCaseBuilder
            A DC I've written to help model staircases - so you don't have to do everything by hand
            http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
            Hope this helps
            Howard L'
            • U
              unclewk
              Thanks, Howard, will check 'em out.
                redfox11
                Great staircase! Are all connections welded?
                http://sketchupengineering.blogspot.com/
                • U
                  unclewk
                  Thanks, Alexander.
                  I'm not too sure about the actual construction sequence as this is not one of my project, but in normal practice, connector plates will be welded to main members in factory and connections on site are preferably bolts and nuts, ie. base plated welded to stanchion in factory and the whole thing bolted to stump on site; and connector plates welded to stanchions in factory so the landing beams could be bolted to stanchion on site.
                  • pmolsonP
                    pmolson
                    @unclewk said:
                    I modeled it during my free time
                    Free Time...What is that? πŸ˜•
                    • C
                      Cyberdactyl
                      That was going to be my question.
                      I see the handrails appear to be welded to the diamond plate and also there's a solid connection between the building and the staircase by the handrails.
                      I would also suggest kick plates under the handrails on at least the third level, if not the second.
                      • C
                        congellous
                        @unclewk said:
                        Thanks, jo-ke.
                        Thanks, Steve.
                        Mojtaba, thanks.
                        I wasn't being rude, if I was looking at your portfolio, unless you wanted to do the external steel detailing in my office I would wonder what your intention was.
                        • U
                          unclewk
                          Thanks for your reminder, Stanley, next time I'll make sure I declare my "intention" prior to posting any image here, I'm sure this is stated in the forum policy somewhere.
                          • U
                            unclewk
                            LOL. Lucky me, being a freelancer I still manage to squeeze some free time between projects to learn something new. πŸ˜„
                            • C
                              congellous
                              Hey if you want to model the emergency stair outside Tesco good for you I just wondered if there was a technical issue
                              • U
                                unclewk
                                Hmm... I'm sorry but I didn't get what you mean by "technical issue"? Didn't I mentioned it in my post that this is something I modeled and rendered when I was free?
                                It's not illegal to model and render existing structures/buildings here in Malaysia. Also, this is not a project of mine so I didn't really disclose any sensitive data, if there's any, about the design in the model, which I shared in 3D Warehouse. Lastly, I believe no contractor will build a structural steel staircase solely based on a 3D model without fully annotated and authority approved construction drawings.
                                • N
                                  ninopiamonte
                                  Great render, πŸ˜’
                                  So you modelled it?
                                  Why duntio download from 3D Warehouse
                                  • C
                                    Cyberdactyl
                                    I know where you're coming from. It has been "suggested" to me as well to not share work under construction and/or still under development. I understand the professional and commercial mindset, especially when the project is for a client or the work is sensitive to IP in some way. But for the most part, all the hand-wringing to not share models, especially screenshots or renders is a bit ridiculous.
                                    • david_hD
                                      david_h
                                      @unclewk said:
                                      . . . so I modeled it during my free time..
                                      Free time?.😲
                                      • U
                                        unclewk
                                        @ninopiamonte said:
                                        Great render, πŸ˜’
                                        So you modelled it?
                                        Thanks, Nino.
                                        Yes, I modeled it, 3D with SU is fun, no? πŸ˜„
                                        • U
                                          unclewk
                                          Free time?.😲
                                          Hi David. Uhhh... did I say something wrong? 😳 "Free time" = "leisure", no? Please excuse me if I didn't get it right as English is not my first language, but what I really mean is "I modeled it when I was free."
                                          • david_hD
                                            david_h
                                            no...your English is fine, but the term 'FREE TIME' is so foreign to me anymore. i cant remember the last time I had free time to model anything πŸ‘ : πŸ’š
                                            sorry if my little joke didnt translate very well
