    Creating a rotating 3D image set
    7 Posts 4 Posters 542 Views 4 Watching
      coolrunguy
      Hello all,
      I have seen the topic of rotating a camera view about a point covered in this forum and elsewhere, but so far I haven't found a solution that solves my problem. What I am trying to do is recreate the view each of your eyes would see if you rotated on the spot in a room. I've made a scene in SU, and now I want to stand at the origin and save a picture for each degree of rotation (360 pics for each "eye"). I will need to have each "eye" camera looking outwards, but at a slight angle toward the midline so I can stitch them together later and make a 3D image. This would mean that the rotation for each eye would also have to be offset slightly from the origin. I've found a discussion here and on the Google Sketch up forum about this, but no solution offered the precise control I need. Anybody?
      Thanks!
      Steven
      • peter_shawP Offline
        peter_shaw
        doesnt seem like there's a script like that. i suck at ruby, never tried to do anything, but it shouldn't be that hard to write that IMO.
        in the meanwhile u could do it manually: also never actually tested it myself, but maybe advanced camera tools will do the trick? placing the 2 cameras on a platform and rotating the platform in 1° steps. when u safe each view as as scene (2x360 scenes, lot of work i know, i know 😞), u can batch render them with vray for sketchup. there might also be a plugin for batch exporting scenes as jpg.
        also, there might be some render engines that can do stereo-images, that would save u some work
        hope someone else can help, cool idea!
          Isn't that a 'pano' ?
          Try this http://www.smustard.com/script/CubicPanoOut there are undoubtedly others if you google...
          [tutorial is here http://www.cad-addict.com/2009/04/sketchup-plugins-create-360-degree.html ]
            peter_shaw
            this is for 2D panorama pictures. he needs a sequence of 3D images if i understand correctly
              But all it needs is the scene-tab 'pages' made for each 'shot' ?
              If he uses the correct settings as well as the images he gets those scene-tabs 'pages' made too... πŸ˜•
              'Pages' is the old name for 'scene-tabs'...
              • cottyC Offline
                cotty
                Something like this?
                • concstruct the positions of the eyes with lines
                • position camera tool: click left eye (hold down mouse button) and release at target point
                • save picture 1
                • position camera tool: click right eye (hold down mouse button) and release at same target point
                • save picture 2
                Which software do you use for creating the stereo image?
                my SketchUp gallery
                  See http://www.smustard.com/script/Stereo
                  as a possibility, BUT not use why it's not currently downloadable - it used to be...
                  Lumion might also have some capabilities you'd like...
