    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 258.9k Views 45 Watching
    • panixiaP Offline
      panixia
      @cotty said:
      The making of the wine glass is in the .skp:
      • Draw lines on picture
      • Follow me with hexagon
      • Subdivide with Artisan
        (The wine is a copy of the inner glass with a little scalefactor and closed top face)
      why do you need subdivision to do this? can't you just followme a circle instead of exagon? or i'm missing something?
      • panixiaP Offline
        panixia
        πŸ˜›
        • cottyC Offline
          cotty
          You are right, but then it would not fit in this post 😎
          (in German we would say "mit Kanonen auf Spatzen schießen", something like "shoot with cannons at sparrows"...)
          my SketchUp gallery
          • bazB Offline
            baz
            Can't remember who did this, but it's very simple and easy to understand, so it should be in this great thread.
            Proxie Sample.skp
            • cottyC Offline
              cotty
              Same workflow as the wine glass, therefore only the renders...
              my SketchUp gallery
              • N Offline
                ninopiamonte
                It's so great cotty! How'd you do with the foam & bubbles?
                • cottyC Offline
                  cotty
                  The foam is simple diffuse material with formed mesh on top (Artisan). Headroom says that it would look more realistic with some SSS, I will try this later.
                  The bubble workflow is described in the Indigo Renderer forum.
                  my SketchUp gallery
                  • cottyC Offline
                    cotty
                    Some abstract drops...
                    cotty_drops.skp
                    my SketchUp gallery
                    • alvisA Offline
                      alvis
                      original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
                      nervos.zip
                      • cottyC Offline
                        cotty
                        Thanks for sharing! Do you still have the original proxy? It would be very helpful to play with it...
                        my SketchUp gallery
                        • P Offline
                          pololo
                          Excellent Post Cotty!!! Your models are great, thanks for sharing!!!
                          • cottyC Offline
                            cotty
                            A lamp from hieru, SU-model is in his post...
                            my SketchUp gallery
                            • cottyC Offline
                              cotty
                              A simple SU keyboard key...
                              cotty_keyboardkey.skp
                              my SketchUp gallery
                              • panixiaP Offline
                                panixia
                                teapot  proxy.jpga very quick and basic quad-based teapot proxy.. classic..
                                • cottyC Offline
                                  cotty
                                  Some nice hints from Elisei:
                                  @ely862me said:
                                  Few things that is good to keep in mind when using artisan :
                                  1.Keep all the diagonals oriented in the same way
                                  2.If you can't go all the way quads then you have to have all the way triangles(at least don't let single quads in the middle of triangles), otherwise the smoothed geometry won't be that nice .
                                  Example:
                                  Edited: changed image
                                  my SketchUp gallery
                                  • iichiversiiI Offline
                                    iichiversii
                                    I modelled this using the plugins, "vertex tools" "quad based tools" "Artisan", you can find in more detail how i made this view topic
                                    http://forums.sketchucation.com/viewtopic.php?f=81&t=47740
                                    Will be adding more detail in the coming days and eventually UV map a better texture to the surface πŸ˜„
                                    Bring on the Rain...
                                    • MarianM Offline
                                      Marian
                                      Good job Damien, he looks just like you. πŸ˜†
                                      • pbacotP Offline
                                        @panixia said:
                                        [attachment=0:3l722n90]<!-- ia0 -->teapot proxy.jpg<!-- ia0 -->[/attachment:3l722n90]a very quick and basic quad-based teapot proxy.. classic..
                                        Nice! An ode to the Google Years.
                                          iichiversii
                                            Alien Head_BomBom.skp
                                            • 6
                                            • 7
                                            • 8
                                            • 22
                                            • 23
                                            • 6 / 23
