    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.3k Views 45 Watching
    • bazB
      baz
      Can't remember who did this, but it's very simple and easy to understand, so it should be in this great thread.
      Proxie Sample.skp
      • cottyC
        cotty
        Same workflow as the wine glass, therefore only the renders...
        my SketchUp gallery
        • N
          ninopiamonte
          It's so great cotty! How'd you do with the foam & bubbles?
          • cottyC
            cotty
            The foam is simple diffuse material with formed mesh on top (Artisan). Headroom says that it would look more realistic with some SSS, I will try this later.
            The bubble workflow is described in the Indigo Renderer forum.
            my SketchUp gallery
            • cottyC
              cotty
              Some abstract drops...
              cotty_drops.skp
              my SketchUp gallery
              • alvisA
                alvis
                original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
                nervos.zip
                • cottyC
                  cotty
                  Thanks for sharing! Do you still have the original proxy? It would be very helpful to play with it...
                  my SketchUp gallery
                  • P
                    pololo
                    Excellent Post Cotty!!! Your models are great, thanks for sharing!!!
                    • cottyC
                      cotty
                      A lamp from hieru, SU-model is in his post...
                      my SketchUp gallery
                      • cottyC
                        cotty
                        A simple SU keyboard key...
                        cotty_keyboardkey.skp
                        my SketchUp gallery
                        • panixiaP
                          panixia
                          teapot  proxy.jpga very quick and basic quad-based teapot proxy.. classic..
                          • cottyC
                            cotty
                            Some nice hints from Elisei:
                            @ely862me said:
                            Few things that is good to keep in mind when using artisan :
                            1.Keep all the diagonals oriented in the same way
                            2.If you can't go all the way quads then you have to have all the way triangles(at least don't let single quads in the middle of triangles), otherwise the smoothed geometry won't be that nice .
                            Example:
                            Edited: changed image
                            my SketchUp gallery
                            • iichiversiiI
                              iichiversii
                              I modelled this using the plugins, "vertex tools" "quad based tools" "Artisan", you can find in more detail how i made this view topic
                              http://forums.sketchucation.com/viewtopic.php?f=81&t=47740
                              Will be adding more detail in the coming days and eventually UV map a better texture to the surface ๐Ÿ˜„
                              Bring on the Rain...
                              • MarianM
                                Marian
                                Good job Damien, he looks just like you. ๐Ÿ˜†
                                • pbacotP
                                  @panixia said:
                                  [attachment=0:3l722n90]<!-- ia0 -->teapot proxy.jpg<!-- ia0 -->[/attachment:3l722n90]a very quick and basic quad-based teapot proxy.. classic..
                                  Nice! An ode to the Google Years.
                                  • iichiversiiI
                                    iichiversii
                                    ๐Ÿคฃ
                                      Alien Head_BomBom.skp
                                      • iichiversiiI
                                        iichiversii
                                        @rich o brien said:
                                        [attachment=1:3tf2izkx]<!-- ia1 -->Lo-Poly.png<!-- ia1 -->[/attachment:3tf2izkx]
                                        [attachment=0:3tf2izkx]<!-- ia0 -->Alien Head_BomBom.skp<!-- ia0 -->[/attachment:3tf2izkx]
                                        Nice Rich, I'll be studying this later and learn more from it, thank you ๐Ÿ‘
                                        • cottyC
                                          cotty
                                          Thanks for sharing!
                                          A little chubaka interpretation ๐Ÿ˜‰ ...
                                          my SketchUp gallery
                                          • iichiversiiI
                                            iichiversii
                                            Is that you chewie ๐Ÿ˜ฎ
                                            • 22
                                            • 23
                                            • 6 / 23
