    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.3k Views 45 Watching
    • panixiaP
      panixia
      πŸ˜›
      • cottyC
        cotty
        @panixia said:
        why do you need subdivision to do this? can't you just followme a circle instead of exagon? or i'm missing something?
        You are right, but then it would not fit in this post 😎
        (in German we would say "mit Kanonen auf Spatzen schießen", something like "shoot with cannons at sparrows"...)
        my SketchUp gallery
        • bazB
          baz
          Can't remember who did this, but it's very simple and easy to understand, so it should be in this great thread.
          Proxie Sample.skp
          • cottyC
            cotty
            Same workflow as the wine glass, therefore only the renders...
            my SketchUp gallery
            • N
              ninopiamonte
              It's so great cotty! How'd you do with the foam & bubbles?
              • cottyC
                cotty
                The foam is simple diffuse material with formed mesh on top (Artisan). Headroom says that it would look more realistic with some SSS, I will try this later.
                The bubble workflow is described in the Indigo Renderer forum.
                my SketchUp gallery
                • cottyC
                  cotty
                  Some abstract drops...
                  cotty_drops.skp
                  my SketchUp gallery
                  • alvisA
                    alvis
                    original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
                    nervos.zip
                    • cottyC
                      cotty
                      Thanks for sharing! Do you still have the original proxy? It would be very helpful to play with it...
                      my SketchUp gallery
                      • P
                        pololo
                        Excellent Post Cotty!!! Your models are great, thanks for sharing!!!
                        • cottyC
                          cotty
                          A lamp from hieru, SU-model is in his post...
                          my SketchUp gallery
                          • cottyC
                            cotty
                            A simple SU keyboard key...
                            cotty_keyboardkey.skp
                            my SketchUp gallery
                            • panixiaP
                              panixia
                              teapot  proxy.jpga very quick and basic quad-based teapot proxy.. classic..
                              • cottyC
                                cotty
                                Some nice hints from Elisei:
                                @ely862me said:
                                Few things that is good to keep in mind when using artisan :
                                1.Keep all the diagonals oriented in the same way
                                2.If you can't go all the way quads then you have to have all the way triangles(at least don't let single quads in the middle of triangles), otherwise the smoothed geometry won't be that nice .
                                Example:
                                Edited: changed image
                                my SketchUp gallery
                                • iichiversiiI
                                  iichiversii
                                  I modelled this using the plugins, "vertex tools" "quad based tools" "Artisan", you can find in more detail how i made this view topic
                                  http://forums.sketchucation.com/viewtopic.php?f=81&t=47740
                                  Will be adding more detail in the coming days and eventually UV map a better texture to the surface πŸ˜„
                                  Bring on the Rain...
                                  • MarianM
                                    Marian
                                    Good job Damien, he looks just like you. πŸ˜†
                                    • pbacotP
                                      @panixia said:
                                      [attachment=0:3l722n90]<!-- ia0 -->teapot proxy.jpg<!-- ia0 -->[/attachment:3l722n90]a very quick and basic quad-based teapot proxy.. classic..
                                      Nice! An ode to the Google Years.
                                      • iichiversiiI
                                        iichiversii
                                          Alien Head_BomBom.skp
                                          • iichiversiiI
                                            iichiversii
                                            @rich o brien said:
                                            [attachment=1:3tf2izkx]<!-- ia1 -->Lo-Poly.png<!-- ia1 -->[/attachment:3tf2izkx]
                                            [attachment=0:3tf2izkx]<!-- ia0 -->Alien Head_BomBom.skp<!-- ia0 -->[/attachment:3tf2izkx]
                                            Nice Rich, I'll be studying this later and learn more from it, thank you πŸ‘
                                            • 22
                                            • 23
                                            • 6 / 23
