    Text and dimensions won't print
    8 Posts 3 Posters 2.5k Views 3 Watching
    • M
      mwm5053
      I can get the walls to print but not the text or dimensions, leader lines maybe it's my printer?
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • TIGT
        You clearly made that image so you know they exist.
        HOW are you trying to "print" the view ?
        What are your settings/options when you do so ??
        • M
          mwm5053
          I used the print from File menu, I exported it as a 2d graphic in every format possible I read somewhere on the SU help to change dpi from 72 to something like 300 still didn't print well enough to give anyone.
          2011 iMac
          V2 Twilight
          • M
            mwm5053
            ah changing line weight to 3.00 in print dialogue box
            2011 iMac
            V2 Twilight
            • jeff hammondJ
              jeff hammond
              try selecting all the text and dimensions then grouping them.. then export
              this is a SU bug and the grouping workaround is the only way I know of to prevent it.
              dotdotdot
              • M
                mwm5053
                thanks Jeff and Tig that worked. Just another question I notice when printing a section cut the line wieght is really heavy any way to fix this.
                Thanks in advance
                2011 iMac
                V2 Twilight
                • TIGT
                  The thickness/color of the Section-Cut is set in the current Style ...Capture.PNG
                  • M
                    mwm5053
                    hey thanks Tig
                    2011 iMac
                    V2 Twilight
