    Text and dimensions won't print
    8 Posts 3 Posters 2.4k Views 3 Watching
      mwm5053
      I can get the walls to print but not the text or dimensions, leader lines maybe it's my printer?
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        You clearly made that image so you know they exist.
        HOW are you trying to "print" the view ?
        What are your settings/options when you do so ??
          mwm5053
          I used the print from File menu, I exported it as a 2d graphic in every format possible I read somewhere on the SU help to change dpi from 72 to something like 300 still didn't print well enough to give anyone.
          2011 iMac
          V2 Twilight
            mwm5053
            ah changing line weight to 3.00 in print dialogue box
            2011 iMac
            V2 Twilight
            • jeff hammondJ Offline
              try selecting all the text and dimensions then grouping them.. then export
              this is a SU bug and the grouping workaround is the only way I know of to prevent it.
                mwm5053
                thanks Jeff and Tig that worked. Just another question I notice when printing a section cut the line wieght is really heavy any way to fix this.
                Thanks in advance
                2011 iMac
                V2 Twilight
                  The thickness/color of the Section-Cut is set in the current Style ...Capture.PNG
                    mwm5053
                    hey thanks Tig
                    2011 iMac
                    V2 Twilight
