    Selecting edge loops?
    12 Posts 8 Posters 969 Views 8 Watching
    • N Offline
      NickGenerator
      Can I do something like this in SU?
      "Holding Alt while selecting an edge selects a loop of edges that are connected in a line end to end, passing through the edge under the mouse pointer."
        Look for Thomthom's Selection Toys tools...
          There's also TGI3D training Edition that got one of the best Selection tools I've used
          • N Offline
            NickGenerator
            That looks good, but I can just find "Select > Quad-face Loops". Do you perhaps know how to make a selection like in the image above??
              Not exactly for this loop but a funny tool when all edges have the same length by Chris Fullmer
              Select lines by length
              so here for the latitudes = an horizontal loop! 😉
              Maybe also inside Thomthom Toys Selection ?
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                TRICK no 1:
                Use Parallel Projection then orbit the view so that the "loop" is seen from it side.
                This shall allow you to do a window select in order to only select the loop. Going to wire frame may even help in eliminating the selection of very small facets.
                TRICK no 2:
                If the loop is on one plane (all the edges are coplanar), retrace one edge to actually close a face. Select the face with a double click to select it with its perimeter (the wanted loop) then deselect the face to keep only the loop selected. Delete the face when done.
                Just ideas.
                  lapx
                  Quadface tools will do exaclty what you are atempting,"grow loop".
                  • N Offline
                    NickGenerator
                    Tool for selecting edge loops is here:
                    http://forums.sketchucation.com/viewtopic.php?t=39442
                    Thanks. Guess now I have all the plugins a newbie really needs. 😄
                    • H Offline
                      hulahopka
                      Hi. for me quadface plugin not work (some error on start SU)
                      so I ask is any other option to loop selection, like on Cinema 4D (loop or ring slection tool, and other, if may select cells or lines through a pipe to select inside and outside ring on tube for exsample, something like on this picture, but must select bothi sides.
                      Thank you.
                      http://s17.postimage.org/e6fm2myfz/loop_selection.jpg
                        Considering it works fine for me I would recommend revisiting the installation instructions
                        • H Offline
                          hulahopka
                          Hi. I will try reinstall, maybe is problem there. I will report back.
                          Thank you.
                          • cottyC Offline
                            cotty
                            If you own the plugin SketchUV, you can use its "Path Select Tool" and get this kind of selection with one double click.
                            my SketchUp gallery
