    Selecting edge loops?
    12 Posts 8 Posters 1.1k Views 8 Watching
      Look for Thomthom's Selection Toys tools...
        There's also TGI3D training Edition that got one of the best Selection tools I've used
        • N
          NickGenerator
          That looks good, but I can just find "Select > Quad-face Loops". Do you perhaps know how to make a selection like in the image above??
            Not exactly for this loop but a funny tool when all edges have the same length by Chris Fullmer
            Select lines by length
            so here for the latitudes = an horizontal loop! 😉
            Maybe also inside Thomthom Toys Selection ?
            • Jean LemireJ
              Jean Lemire
              Hi folks.
              TRICK no 1:
              Use Parallel Projection then orbit the view so that the "loop" is seen from it side.
              This shall allow you to do a window select in order to only select the loop. Going to wire frame may even help in eliminating the selection of very small facets.
              TRICK no 2:
              If the loop is on one plane (all the edges are coplanar), retrace one edge to actually close a face. Select the face with a double click to select it with its perimeter (the wanted loop) then deselect the face to keep only the loop selected. Delete the face when done.
              Just ideas.
              • L
                lapx
                Quadface tools will do exaclty what you are atempting,"grow loop".
                • N
                  NickGenerator
                  Tool for selecting edge loops is here:
                  http://forums.sketchucation.com/viewtopic.php?t=39442
                  Thanks. Guess now I have all the plugins a newbie really needs. 😄
                  • H
                    hulahopka
                    Hi. for me quadface plugin not work (some error on start SU)
                    so I ask is any other option to loop selection, like on Cinema 4D (loop or ring slection tool, and other, if may select cells or lines through a pipe to select inside and outside ring on tube for exsample, something like on this picture, but must select bothi sides.
                    Thank you.
                    http://s17.postimage.org/e6fm2myfz/loop_selection.jpg
                      Considering it works fine for me I would recommend revisiting the installation instructions
                      • H
                        hulahopka
                        Hi. I will try reinstall, maybe is problem there. I will report back.
                        Thank you.
                        • cottyC
                          cotty
                          If you own the plugin SketchUV, you can use its "Path Select Tool" and get this kind of selection with one double click.
                          my SketchUp gallery
