[Plugin] Slicer5
sketchup pro 2023
no , acabo de probar y no medeja manualmente
no hay mas mensajes
en el pdf que me sale adjunto , habla sobre fredo spline , pero no se a que se refiere , es neceserio comprar fredospline
un saludo
@martinguillermo11 Failing to export DXFs at all is a symptom of something other than Slicer5 !
Have you tried repairing SketchUp/Layout ?
Doing this will not affect your extensions, other settings, licenses etc.
Follow these steps...
Close SketchUp/Layout.
Find the SketchUp installer's exe file - usually in Downloads, but if you have deleted it you can always download another copy from sketchup.com.
Select the installer's exe file's icon, right-click > context-menu > "Run as administrator"
When prompted choose "Repair"
After it completes restart you computer and see if anything has improved...Installing a complex app in Windows by double-clicking on its icon to "Run" it is not the same as doing it as I described - even if you have admin powers - it can cause all kinds of unpredictable weirdness, perhaps including your DXF exporter missing...
@TIG de acuerdo , probare a ver que pasa , cuando encuentre el problema y lo solucione lo pondre por aqui , por si a algun otro neofito en el tema le sirve jajajaj
gracias
