    [Plugin] Slicer5
    338 Posts 83 Posters 375.0k Views 82 Watching
      If you object's overall size is not an exact multiple of the spacing & thickness [allowing for the last-most slice/gap], then this will occur.
      It looks like the start/end gaps are 1/2 a gap ?
      Also choosing to centralize the slice can exacerbate this result - try centralizing the gap ?
      You can also tweak the start/end insets to adjust the sliced result.
      Supplying the model would help us see what's what...
      T 1 Reply Last reply Reply Quote 0
        The_Guru Newcomers @TIG
        @TIG Ah, the multiples will be the issue then, I was just throwing random shapes and spacings and seeing what came out.
        Thanks for the help!
          Chelmite
          Will this take slices along a curve, perpendicular to the path? I.e., take cross-sections along a snake.
            Chelmite
            Can you take slices along a curved path, perpendicular to the path, for a given increment? I want to model a snake.
              Dave R @Chelmite
              @Chelmite no. It makes parallel slices.
              For your snake you could create a plane component and use Copy Along Path to do what you are looking for.
              C 1 Reply Last reply Reply Quote 0
                Chelmite
                This post is deleted!
                  Chelmite
                    Chelmite
                      Chelmite @Dave R
                      @Dave-R said in [Plugin] Slicer5:
                      l
                      Please explain.
                      Thanks,
                      Steve
                        brague Newcomers
                        Hi guys, Mac usuer I can't download the TXT ttf font, all the link aren't working no more. Can someone tell how to donwloadd it ?
                          The link in the very first thread in this topic contains the working url to download the zip file containing the txt font's ttf file.
                          https://community.sketchucation.com/uploads/imported_attachments/pdqA_txt_____.zip
                          I just used it.
                          I can't see what your issue might be...
                          • 13
                          • 14
                          • 15
                          • 16
                          • 17
                          • 17 / 17
