    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Slicer5
    336 Posts 82 Posters 310.8k Views 81 Watching
      TBoy
      Mr. TIG
      Is it possible to make variation of this plugin for cutting object to pieces
      (For example a big object cut to pieces fitting for 3d printing) ?
      May be "Slicer" workflow will be OK - cutting in X, Y, Z or any combination of the 3 axes.
        Look at my "Split to Plane" - which should be able to split your container into parts...
        https://sketchucation.com/pluginstore?pln=TIG_Split_to_plane
          TBoy
          OK, but the idea is to make multiple cuts at once.
          To convert a cube to Rubik's cube - serial cuts in different directions controlling distance between cuts (like slicer).
            Slicer5 will make cuts in two planes ?
            I don't understand your issue...
              TBoy
              I'm talking about new plugin that will work similar to "Slicer" but cutting object to smaller parts.
              Cutting in 1 or 2 or 3 planes (X, Y, Z) and why not in additional "A and R-planes" like the planes in "Slicer"
              "Split to plane" is OK for few splits, but what if I want to make 100 splits(cuttings) equal in height in Z-plane then each of these in Y-plane, and then in X-plane.
                With appropriate settings Slicer5 will already split your solid along any 2 planes.
                But unfortunately not with 3 planes !
                Omitting all gaps/slots/tolerances etc would probably make it simple enough, and then allow a new tool with XYZ slicing...
                Unfortunately I don't have the time to do any of this, this year !
                The code is readable and you are welcome to try your own new XYZ version...
                  TBoy
                  Is this possible with Slicer?
                  I don't think so, or I obviously miss something in Slicer settings.
                    The slice settings are XY XZ and YZ
                    But there's no XYZ !
                      TBoy
                      TIG I understand this. The main problem is is not 2 or 3 axes/planes, problem is Slicer is not making actual cutting.
                      My English is poor and may be I do not use proper words - splitting, slicing or cutting.
                      So I'll use word dividing.
                      Slicer is not dividing objects. The idea is to divide in different planes.
                      In the Lion illustration above every horizontal part has to be separate object. Start with whole Lion as 1 object, applying divide in Z-plane and the result is as in illustration > separate objects instead of 1 whole lion.
                      Is the idea clear now?
                        So. your request has little to do with Slicer.
                        You want a tool which splits an object along the XY and Z planes in one step.
                        i.e. something like my Split tool, but with more repetitions per plane...
                        Again, I'm sure it's possible but I am unlikely to create a split-XYZ tool any time soon ๐Ÿ˜ž
                          TBoy
                          The future tool already has a very good name:
                          Split-XYZ ๐Ÿ‘
                            joemanzz
                            Please contact me through my IG account j.margulis
                            Would really like to have a conversation about some ideas that might help you in your process
                              dreamdesignar Newcomers
                              how to downlode it....?
                                Install the Sketchucation Extension Store tool, search for Slicer5 and press the Install button.
                                  mtomy2008
                                  Thank you so much Dave!
                                  travelagu.io
                                  M 1 Reply Last reply Reply Quote 0
                                    martinguillermo11 Newcomers @mtomy2008
                                    buenas , tengo un problema con slicer5 a la hora de exportar a DXF , a PNG no tengo problema pero cuando quiero exportar a DXF me sale un archivo pdf y un block de notas , en el ordenador que lo tenia instalado antes no tenia problemas en la carpeta de DXF aparecian los 12 o 13 archivos DXF sin embargo en el ordenador nuevo en la carpeta DXF me sale un archivo pdf y un block de notas , ojala me podais ayudar , gracias de antemano
                                    TIGT 1 Reply Last reply Reply Quote 1
                                      TIG Moderator @martinguillermo11
                                      @martinguillermo11
                                      Can you try with a very very simple sliced model, and zip the PDF and DXF results and post it here or send it to me in a Chat [PM]...
                                      Do you see any error messages in the Ruby Console ?
                                        buenas , gracias por la respuesta , no se como enviar chat jajajaj 1711558903622.jpg ![1711558903611.jpg](/assets/uploads/files/1711559076117-1711558903622.jpg 1711558903611-resized.jpg)
                                        espero que se vean
                                            @martinguillermo11 What version of SketchUp are you using on this new computer ?
                                            It must be 'Pro' to have built-in DXF export... Otherwise it'll be PDF ?
                                            Can you manually export things as DXF ?
                                            Are there any other error messages or Ruby-Console output ?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
