    [Plugin] Slicer5
    338 Posts 83 Posters 394.1k Views 82 Watching
      Slicer5 will make cuts in two planes ?
      I don't understand your issue...
      • T
        TBoy
        I'm talking about new plugin that will work similar to "Slicer" but cutting object to smaller parts.
        Cutting in 1 or 2 or 3 planes (X, Y, Z) and why not in additional "A and R-planes" like the planes in "Slicer"
        "Split to plane" is OK for few splits, but what if I want to make 100 splits(cuttings) equal in height in Z-plane then each of these in Y-plane, and then in X-plane.
          With appropriate settings Slicer5 will already split your solid along any 2 planes.
          But unfortunately not with 3 planes !
          Omitting all gaps/slots/tolerances etc would probably make it simple enough, and then allow a new tool with XYZ slicing...
          Unfortunately I don't have the time to do any of this, this year !
          The code is readable and you are welcome to try your own new XYZ version...
          • T
            TBoy
            Is this possible with Slicer?
            I don't think so, or I obviously miss something in Slicer settings.
              The slice settings are XY XZ and YZ
              But there's no XYZ !
              • T
                TBoy
                TIG I understand this. The main problem is is not 2 or 3 axes/planes, problem is Slicer is not making actual cutting.
                My English is poor and may be I do not use proper words - splitting, slicing or cutting.
                So I'll use word dividing.
                Slicer is not dividing objects. The idea is to divide in different planes.
                In the Lion illustration above every horizontal part has to be separate object. Start with whole Lion as 1 object, applying divide in Z-plane and the result is as in illustration > separate objects instead of 1 whole lion.
                Is the idea clear now?
                  So. your request has little to do with Slicer.
                  You want a tool which splits an object along the XY and Z planes in one step.
                  i.e. something like my Split tool, but with more repetitions per plane...
                  Again, I'm sure it's possible but I am unlikely to create a split-XYZ tool any time soon 😞
                  • T
                    TBoy
                    The future tool already has a very good name:
                    Split-XYZ πŸ‘
                      joemanzz
                      Please contact me through my IG account j.margulis
                      Would really like to have a conversation about some ideas that might help you in your process
                        dreamdesignar Newcomers
                        how to downlode it....?
                          Install the Sketchucation Extension Store tool, search for Slicer5 and press the Install button.
                            mtomy2008
                            Thank you so much Dave!
                            travelagu.io
                            M 1 Reply Last reply
                              martinguillermo11 Newcomers @mtomy2008
                              buenas , tengo un problema con slicer5 a la hora de exportar a DXF , a PNG no tengo problema pero cuando quiero exportar a DXF me sale un archivo pdf y un block de notas , en el ordenador que lo tenia instalado antes no tenia problemas en la carpeta de DXF aparecian los 12 o 13 archivos DXF sin embargo en el ordenador nuevo en la carpeta DXF me sale un archivo pdf y un block de notas , ojala me podais ayudar , gracias de antemano
                              TIGT 1 Reply Last reply
                                TIG Moderator @martinguillermo11
                                @martinguillermo11
                                Can you try with a very very simple sliced model, and zip the PDF and DXF results and post it here or send it to me in a Chat [PM]...
                                Do you see any error messages in the Ruby Console ?
                                  buenas , gracias por la respuesta , no se como enviar chat jajajaj 1711558903622.jpg ![1711558903611.jpg](/assets/uploads/files/1711559076117-1711558903622.jpg 1711558903611-resized.jpg)
                                  espero que se vean
                                      @martinguillermo11 What version of SketchUp are you using on this new computer ?
                                      It must be 'Pro' to have built-in DXF export... Otherwise it'll be PDF ?
                                      Can you manually export things as DXF ?
                                      Are there any other error messages or Ruby-Console output ?
                                        sketchup pro 2023
                                        no , acabo de probar y no medeja manualmente
                                        no hay mas mensajes
                                        en el pdf que me sale adjunto , habla sobre fredo spline , pero no se a que se refiere , es neceserio comprar fredospline
                                        un saludo
                                          @martinguillermo11 Failing to export DXFs at all is a symptom of something other than Slicer5 !
                                          Have you tried repairing SketchUp/Layout ?
                                          Doing this will not affect your extensions, other settings, licenses etc.
                                          Follow these steps...
                                          Close SketchUp/Layout.
                                          Find the SketchUp installer's exe file - usually in Downloads, but if you have deleted it you can always download another copy from sketchup.com.
                                          Select the installer's exe file's icon, right-click > context-menu > "Run as administrator"
                                          When prompted choose "Repair"
                                          After it completes restart you computer and see if anything has improved...
                                          Installing a complex app in Windows by double-clicking on its icon to "Run" it is not the same as doing it as I described - even if you have admin powers - it can cause all kinds of unpredictable weirdness, perhaps including your DXF exporter missing...
                                            martinguillermo11 Newcomers @TIG
                                            @TIG de acuerdo , probare a ver que pasa , cuando encuentre el problema y lo solucione lo pondre por aqui , por si a algun otro neofito en el tema le sirve jajajaj
                                            gracias
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
