    Vray ignores my omnis :(
    renderpluginsextensions
    6 Posts 5 Posters 1.2k Views 5 Watching
    • john2J Offline
      john2
      I’m trying to render a scene [interior scene] with Omni light on. I have low GI value set to 1. But in the final render, vray considers only the natural light and ignores the artificial lighting [Omni’s and rectangular] that I’ve put up in my room. Where I’m going wrong?
      • chonC Offline
        chon
        Are your omni and rectangular lighted and well setted ?
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
          What light values do you have? And do you have Physical Camera enabled or disabled?
          • john2J Offline
            john2
            my physical camera is on and here are my light settings.
            http://i.imgur.com/QFPeE.jpg
            here is the file.
            http://www.sendspace.com/file/tnuzrf
            • peter_shawP Offline
              peter_shaw
              maybe its just not bright enough. try increasing intensity to a much higher value, like 500
              • V Offline
                valerostudio
                With decay set to inverse sqaure, you will need a much higher value than 5. I set my Units to Radiant power (W) and use a value between 100-300 depending on the scene. Also, I would not use pure white as your color. In reality lighting gives off either cool or warm tones depending on the type of fixture. I like to set my omnis to a very light warm yellow/orange.
