    [Plugin] AreaTextTag
    97 Posts 27 Posters 81.8k Views 27 Watching
      jeff2047
      got it, thanks share
        Bokkie
        hi, was wondering if this plugin will / could, extract or copy an atrribute's value, when inserted into a block with attributes?
          It reports the area of the face it's 'attached' to.
          The face/tag need to be in the same context.
          It doesn't 'report attributes'.
          There are other tools that do that, but you need to be somewhat clearer in your question...
          • F Offline
            ffox
            Thank you, I am finding all of this really helpful.
            I searched through the chain and don't think that this has been addressed yet. I am wondering if it is possible to input two text entries per tag. For example, "room #" and "department" both associated with the same square footage, so when exported, you have two text columns per sf which can be sorted accordingly.
            Thanks in advance!
            • G Offline
              gclyde
              Would it be possible to select and group a number of faces and give a tag that relates to the total surface area of all selected faces?
              In addition, would it be possible to produce a similar ruby that totals up the lengths of selected lines/junctions? (not necessarily the perimeter of a face)...this would be icing on the cake for me 😍
              Graham
              • atelierpaarA Offline
                atelierpaar
                Hello TIG
                Great script !!
                Since I am always short in space it would be of great help if it would we possible to have 2-line Text-Tags for instance :
                Entrance
                30 m²
                alignment options
                • Left
                  Right
                  Center
                  Thanks for looking into it
                  Uli
                  billmorr
                  Hi TIG
                  Firstly, great plug in - thank you for that 😄
                  It seems to crash my SU 2015 (Mac version)when installed alongside Twilight renderer.
                  I have just uninstalled Twilight and everything is cool again.
                  Just thought i'd report the clash in case anyone else has the same problem or if you can fix?
                  Bill
                    billmorr
                    Hi TIG
                    Firstly - great plugin - thank you for this 😄
                    Just discovered on SU 2015 on my Mac, that it crashed SU if Twilight is installed at the same time
                    Don't know if you can fix?
                      mcmcxlxl
                      Hi tig,
                      Thank you for this Tag plugin.
                      I modified it quite deeply to make it easier.
                      Could you give me your mail so that i can send it to you.
                      I would appreciate some critics because i'm not a programmer (but architect) and the way i program is dirty.
                      Michael
                        Please use the "Private Message" option here to exchange non-public info...
                          mcmcxlxl
                          Sorry
                          hmm. I have no access to private messages...
                          Michaël
                            New members get access to PM-ing after a few valid posts - so try again...
                              atelierpaar
                              Hello Tig,
                              these Area Tex Tags are great - thanks for offering this plugin.
                              After installing SU 2017 they won`t work anymore and I am in trouble.
                              Do you have a chance to look into this ?
                              Thanks already
                              Ulrich
                                The error in the Ruby Console tells the story.
                                Unfortunately v2017 looses earlier references set to the contents of a group, e.g. when it's exploded, so the code fails, I'm currently fixing this weirdness in my ExtrudeTools...
                                However, it might be some other Ruby2.2 foible...
                                I'll look into this tool asap...
                                  atelierpaar
                                  Hello Tig
                                  thanks so much for your fast response
                                  I which I could help but unfortunately this is not my Cup of tea.
                                  Anyways, thanks a lot
                                  Ulrich
                                    Here's v2.0.
                                    http://sketchucation.com/pluginstore?pln=TIG_AreaTextTag
                                    It is now compatible with v2017's newest Ruby.
                                    Users with unsupported versions like v8 are advised not to update as it might now cause issues...
                                      atelierpaar
                                      everything is shiny again
                                      Thanks Tig,I appreciate
                                      Ulrich
                                        atelierpaar
                                        Hello TIG
                                        I am in need of some additional Information on my plans. So I come back to my question from 2015:
                                        Is it possible to have a multi line Text-Tag, possibly with alignment Options (left/right/center) ?
                                        For instance :
                                        Name 1 Entrance
                                        Name 2 Tiles
                                        Area 25 m²
                                        Circumference 20 m
                                        Uli
                                          Text is always centered. it could have options but that needs considerable recoding...
                                          You need to include a new-line marker in the string to get multiple lines.
                                          So in the example you offered...
                                          Entrance
                                          Tiles
                                          25 m²
                                          Perimeter 20 m
                                          needs to be entered thus:
                                          Entrance**\n**Tiles**\n**<>**\n**Perimeter 20 m
                                          The \n tells it where to add a new-line.
                                          The <> is the formatted current area part.
                                          Note that using <-> would add the area without a units suffix.
                                          It's not possible to report the perimeter [easily] without major recoding, but it's easy enough to manually select the face+edges by a double-click on it, then immediately Ctrl+Shift+click it again to leave only the edges selected, when Entity Info will report the length in current units.
                                          This 'perimeter' can then be added to the text by an edit...
                                          PS: I assume you mean 'perimeter' - as that's the edge length of any face, in English a 'circumference' only applies to circular [and perhaps oval] faces...
                                            Here's v3.0
                                            It includes the following enhancements.
                                            a. The settings dialog now allows you to specify the Text's Alignment:
                                            Center [default]
                                            Left
                                            Right
                                            These only affect multi-line entries which have used \n to signify a newline.
                                            b. The reserved character combinations to locate a formatted area for the face:
                                            <> with units & <-> without units
                                            are now complemented with character combos to locate a formatted perimeter length for the face:
                                            || with units & |-| without units
                                            The associated perimeter length is displayed using the same units as the area [using the same dp].
                                            For Acres it uses ft, and Hectares m.
                                            • 4 / 5
