    [Plugin] AreaTextTag
    97 Posts 27 Posters 84.4k Views 27 Watching
    • guanjinG Offline
      guanjin
      Paste the local, show normal
        It works fine for our western PCs? 😕
        As a temporary fix...
        Edit the main .rb file inside this tool's subfolder using Notepad.exe.
        Find the 4 occurrences of the text
        .gsub(/2/,"²")
        and change it to read
        .gsub(/2/,"2")
        then you will get
        1.23 m2
        instead of the intended [but failing]
        1.23 m²
        which whilst not perfect it is better.
        If you would prefer
        1.23 m^2
        then change the replacement text
        .gsub(/2/,"2")
        to be
        .gsub(/2/,"^2")
        • guanjinG Offline
          guanjin
          Thank you, of TIG: has been resolved, thanks again!
            jeff2047
            got it, thanks share
              Bokkie
              hi, was wondering if this plugin will / could, extract or copy an atrribute's value, when inserted into a block with attributes?
                It reports the area of the face it's 'attached' to.
                The face/tag need to be in the same context.
                It doesn't 'report attributes'.
                There are other tools that do that, but you need to be somewhat clearer in your question...
                • F Offline
                  ffox
                  Thank you, I am finding all of this really helpful.
                  I searched through the chain and don't think that this has been addressed yet. I am wondering if it is possible to input two text entries per tag. For example, "room #" and "department" both associated with the same square footage, so when exported, you have two text columns per sf which can be sorted accordingly.
                  Thanks in advance!
                    gclyde
                    Would it be possible to select and group a number of faces and give a tag that relates to the total surface area of all selected faces?
                    In addition, would it be possible to produce a similar ruby that totals up the lengths of selected lines/junctions? (not necessarily the perimeter of a face)...this would be icing on the cake for me 😍
                    Graham
                    • atelierpaarA Offline
                      atelierpaar
                      Hello TIG
                      Great script !!
                      Since I am always short in space it would be of great help if it would we possible to have 2-line Text-Tags for instance :
                      Entrance
                      30 m²
                      alignment options
                      • Left
                        Right
                        Center
                        Thanks for looking into it
                        Uli
                        billmorr
                        Hi TIG
                        Firstly, great plug in - thank you for that 😄
                        It seems to crash my SU 2015 (Mac version)when installed alongside Twilight renderer.
                        I have just uninstalled Twilight and everything is cool again.
                        Just thought i'd report the clash in case anyone else has the same problem or if you can fix?
                        Bill
                          billmorr
                          Hi TIG
                          Firstly - great plugin - thank you for this 😄
                          Just discovered on SU 2015 on my Mac, that it crashed SU if Twilight is installed at the same time
                          Don't know if you can fix?
                            mcmcxlxl
                            Hi tig,
                            Thank you for this Tag plugin.
                            I modified it quite deeply to make it easier.
                            Could you give me your mail so that i can send it to you.
                            I would appreciate some critics because i'm not a programmer (but architect) and the way i program is dirty.
                            Michael
                              Please use the "Private Message" option here to exchange non-public info...
                                mcmcxlxl
                                Sorry
                                hmm. I have no access to private messages...
                                Michaël
                                  New members get access to PM-ing after a few valid posts - so try again...
                                    atelierpaar
                                    Hello Tig,
                                    these Area Tex Tags are great - thanks for offering this plugin.
                                    After installing SU 2017 they won`t work anymore and I am in trouble.
                                    Do you have a chance to look into this ?
                                    Thanks already
                                    Ulrich
                                      The error in the Ruby Console tells the story.
                                      Unfortunately v2017 looses earlier references set to the contents of a group, e.g. when it's exploded, so the code fails, I'm currently fixing this weirdness in my ExtrudeTools...
                                      However, it might be some other Ruby2.2 foible...
                                      I'll look into this tool asap...
                                        atelierpaar
                                        Hello Tig
                                        thanks so much for your fast response
                                        I which I could help but unfortunately this is not my Cup of tea.
                                        Anyways, thanks a lot
                                        Ulrich
                                          Here's v2.0.
                                          http://sketchucation.com/pluginstore?pln=TIG_AreaTextTag
                                          It is now compatible with v2017's newest Ruby.
                                          Users with unsupported versions like v8 are advised not to update as it might now cause issues...
                                            atelierpaar
                                            everything is shiny again
                                            Thanks Tig,I appreciate
                                            Ulrich
                                            • 4 / 5
