    [Plugin] AreaTextTag
    97 Posts 27 Posters 83.9k Views 27 Watching
    • F Offline
      ffox
      Thank you, I am finding all of this really helpful.
      I searched through the chain and don't think that this has been addressed yet. I am wondering if it is possible to input two text entries per tag. For example, "room #" and "department" both associated with the same square footage, so when exported, you have two text columns per sf which can be sorted accordingly.
      Thanks in advance!
        gclyde
        Would it be possible to select and group a number of faces and give a tag that relates to the total surface area of all selected faces?
        In addition, would it be possible to produce a similar ruby that totals up the lengths of selected lines/junctions? (not necessarily the perimeter of a face)...this would be icing on the cake for me 😍
        Graham
        • atelierpaarA Offline
          atelierpaar
          Hello TIG
          Great script !!
          Since I am always short in space it would be of great help if it would we possible to have 2-line Text-Tags for instance :
          Entrance
          30 m²
          alignment options
          • Left
            Right
            Center
            Thanks for looking into it
            Uli
            billmorr
            Hi TIG
            Firstly, great plug in - thank you for that 😄
            It seems to crash my SU 2015 (Mac version)when installed alongside Twilight renderer.
            I have just uninstalled Twilight and everything is cool again.
            Just thought i'd report the clash in case anyone else has the same problem or if you can fix?
            Bill
              billmorr
              Hi TIG
              Firstly - great plugin - thank you for this 😄
              Just discovered on SU 2015 on my Mac, that it crashed SU if Twilight is installed at the same time
              Don't know if you can fix?
                mcmcxlxl
                Hi tig,
                Thank you for this Tag plugin.
                I modified it quite deeply to make it easier.
                Could you give me your mail so that i can send it to you.
                I would appreciate some critics because i'm not a programmer (but architect) and the way i program is dirty.
                Michael
                  Please use the "Private Message" option here to exchange non-public info...
                    mcmcxlxl
                    Sorry
                    hmm. I have no access to private messages...
                    Michaël
                      New members get access to PM-ing after a few valid posts - so try again...
                        atelierpaar
                        Hello Tig,
                        these Area Tex Tags are great - thanks for offering this plugin.
                        After installing SU 2017 they won`t work anymore and I am in trouble.
                        Do you have a chance to look into this ?
                        Thanks already
                        Ulrich
                          The error in the Ruby Console tells the story.
                          Unfortunately v2017 looses earlier references set to the contents of a group, e.g. when it's exploded, so the code fails, I'm currently fixing this weirdness in my ExtrudeTools...
                          However, it might be some other Ruby2.2 foible...
                          I'll look into this tool asap...
                            atelierpaar
                            Hello Tig
                            thanks so much for your fast response
                            I which I could help but unfortunately this is not my Cup of tea.
                            Anyways, thanks a lot
                            Ulrich
                              Here's v2.0.
                              http://sketchucation.com/pluginstore?pln=TIG_AreaTextTag
                              It is now compatible with v2017's newest Ruby.
                              Users with unsupported versions like v8 are advised not to update as it might now cause issues...
                                atelierpaar
                                everything is shiny again
                                Thanks Tig,I appreciate
                                Ulrich
                                  atelierpaar
                                  Hello TIG
                                  I am in need of some additional Information on my plans. So I come back to my question from 2015:
                                  Is it possible to have a multi line Text-Tag, possibly with alignment Options (left/right/center) ?
                                  For instance :
                                  Name 1 Entrance
                                  Name 2 Tiles
                                  Area 25 m²
                                  Circumference 20 m
                                  Uli
                                    Text is always centered. it could have options but that needs considerable recoding...
                                    You need to include a new-line marker in the string to get multiple lines.
                                    So in the example you offered...
                                    Entrance
                                    Tiles
                                    25 m²
                                    Perimeter 20 m
                                    needs to be entered thus:
                                    Entrance**\n**Tiles**\n**<>**\n**Perimeter 20 m
                                    The \n tells it where to add a new-line.
                                    The <> is the formatted current area part.
                                    Note that using <-> would add the area without a units suffix.
                                    It's not possible to report the perimeter [easily] without major recoding, but it's easy enough to manually select the face+edges by a double-click on it, then immediately Ctrl+Shift+click it again to leave only the edges selected, when Entity Info will report the length in current units.
                                    This 'perimeter' can then be added to the text by an edit...
                                    PS: I assume you mean 'perimeter' - as that's the edge length of any face, in English a 'circumference' only applies to circular [and perhaps oval] faces...
                                      Here's v3.0
                                      It includes the following enhancements.
                                      a. The settings dialog now allows you to specify the Text's Alignment:
                                      Center [default]
                                      Left
                                      Right
                                      These only affect multi-line entries which have used \n to signify a newline.
                                      b. The reserved character combinations to locate a formatted area for the face:
                                      <> with units & <-> without units
                                      are now complemented with character combos to locate a formatted perimeter length for the face:
                                      || with units & |-| without units
                                      The associated perimeter length is displayed using the same units as the area [using the same dp].
                                      For Acres it uses ft, and Hectares m.
                                        atelierpaar
                                        Hello TIG, thanks so much for such good work.
                                        You're right - I mean 'perimeter', not 'circumference'
                                        I tried your advice using a new-line marker and I got what I was looking for.
                                        A small drawback seems to be, that the editing-textbox is very small and one can`t see the hole text string.
                                        Another issue is that the 'perimeter' doesn't get updated if the area changes (which happens quite frequently).
                                        How could I help to recode this? - let me know if there way.
                                        Anyways, thanks a lot for your work
                                        I really appreciate
                                        Ulrich
                                          At the moment the Area ONLY update does the area ?
                                          The text-box is the width that SketchUp gives us...
                                          You can pick in it and drag left/right or use the arrow keys <- -> to get to the start/end ?
                                          I'll look at a tweak...
                                            I rechecked everything.
                                            If I update a tag and its face's area has changed, then it does update the <> area. AND the || perimeter ???
                                            Can you provide an example where it fails ?
                                            • 4 / 5
