    [Plugin] AreaTextTag
    97 Posts 27 Posters 84.5k Views 27 Watching
      mcmcxlxl
      Hi tig,
      Thank you for this Tag plugin.
      I modified it quite deeply to make it easier.
      Could you give me your mail so that i can send it to you.
      I would appreciate some critics because i'm not a programmer (but architect) and the way i program is dirty.
      Michael
        Please use the "Private Message" option here to exchange non-public info...
          mcmcxlxl
          Sorry
          hmm. I have no access to private messages...
          Michaël
            New members get access to PM-ing after a few valid posts - so try again...
            • atelierpaarA Offline
              atelierpaar
              Hello Tig,
              these Area Tex Tags are great - thanks for offering this plugin.
              After installing SU 2017 they won`t work anymore and I am in trouble.
              Do you have a chance to look into this ?
              Thanks already
              Ulrich
                The error in the Ruby Console tells the story.
                Unfortunately v2017 looses earlier references set to the contents of a group, e.g. when it's exploded, so the code fails, I'm currently fixing this weirdness in my ExtrudeTools...
                However, it might be some other Ruby2.2 foible...
                I'll look into this tool asap...
                  atelierpaar
                  Hello Tig
                  thanks so much for your fast response
                  I which I could help but unfortunately this is not my Cup of tea.
                  Anyways, thanks a lot
                  Ulrich
                    Here's v2.0.
                    http://sketchucation.com/pluginstore?pln=TIG_AreaTextTag
                    It is now compatible with v2017's newest Ruby.
                    Users with unsupported versions like v8 are advised not to update as it might now cause issues...
                      atelierpaar
                      everything is shiny again
                      Thanks Tig,I appreciate
                      Ulrich
                        atelierpaar
                        Hello TIG
                        I am in need of some additional Information on my plans. So I come back to my question from 2015:
                        Is it possible to have a multi line Text-Tag, possibly with alignment Options (left/right/center) ?
                        For instance :
                        Name 1 Entrance
                        Name 2 Tiles
                        Area 25 m²
                        Circumference 20 m
                        Thanks for looking into it
                        Uli
                          Text is always centered. it could have options but that needs considerable recoding...
                          You need to include a new-line marker in the string to get multiple lines.
                          So in the example you offered...
                          Entrance
                          Tiles
                          25 m²
                          Perimeter 20 m
                          needs to be entered thus:
                          Entrance**\n**Tiles**\n**<>**\n**Perimeter 20 m
                          The \n tells it where to add a new-line.
                          The <> is the formatted current area part.
                          Note that using <-> would add the area without a units suffix.
                          It's not possible to report the perimeter [easily] without major recoding, but it's easy enough to manually select the face+edges by a double-click on it, then immediately Ctrl+Shift+click it again to leave only the edges selected, when Entity Info will report the length in current units.
                          This 'perimeter' can then be added to the text by an edit...
                          PS: I assume you mean 'perimeter' - as that's the edge length of any face, in English a 'circumference' only applies to circular [and perhaps oval] faces...
                            Here's v3.0
                            It includes the following enhancements.
                            a. The settings dialog now allows you to specify the Text's Alignment:
                            Center [default]
                            Left
                            Right
                            These only affect multi-line entries which have used \n to signify a newline.
                            b. The reserved character combinations to locate a formatted area for the face:
                            <> with units & <-> without units
                            are now complemented with character combos to locate a formatted perimeter length for the face:
                            || with units & |-| without units
                            The associated perimeter length is displayed using the same units as the area [using the same dp].
                            For Acres it uses ft, and Hectares m.
                              atelierpaar
                              Hello TIG, thanks so much for such good work.
                              You're right - I mean 'perimeter', not 'circumference'
                              I tried your advice using a new-line marker and I got what I was looking for.
                              A small drawback seems to be, that the editing-textbox is very small and one can`t see the hole text string.
                              Another issue is that the 'perimeter' doesn't get updated if the area changes (which happens quite frequently).
                              How could I help to recode this? - let me know if there way.
                              Anyways, thanks a lot for your work
                              I really appreciate
                              Ulrich
                                At the moment the Area ONLY update does the area ?
                                The text-box is the width that SketchUp gives us...
                                You can pick in it and drag left/right or use the arrow keys <- -> to get to the start/end ?
                                I'll look at a tweak...
                                  I rechecked everything.
                                  If I update a tag and its face's area has changed, then it does update the <> area. AND the || perimeter ???
                                  Can you provide an example where it fails ?
                                    atelierpaar
                                    Hello TIG, oh yes, the perimeter does work superb now
                                    I just didn't get it right the first time - my fault- I`am awfully sorry
                                    in Terms of changing the texblock it's not too much work either if one copy /paste the text string and then just change the names
                                    [highlight=#ffff40:22w4wmcs]Entrance[/highlight:22w4wmcs]\n[highlight=#ffff00:22w4wmcs]Tile[/highlight:22w4wmcs]\n<>\n||
                                    using arrow keys to move inside the editing-textbox works fine
                                    thanks a lot for your great work and support
                                    Ulrich
                                      Ben Ritter
                                      TIG,
                                      Thank you so much for your work in writing this and sharing.
                                      Is there a way to update the text to an new text height, or would I have to re-do each one with new text height settings?
                                      Thanks.
                                      • srxS Offline
                                        srx
                                        Thanks for the another useful plugin. My question would be - Is it possible not to hide lines? What to change? My problem is that Scalp section style "doesn't see" tags.
                                        www.saurus.rs
                                        • OxerO Offline
                                          Oxer
                                          When I try to make the Report it appears this message in Ruby Console:
                                          Error; #<NameError; undefined local variable or method `area2ever' for TIG;;AreaTextTag;Module>
                                          /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/TIG-AreaTextTag/TIG-AreaTextTag.rb;1537;in `report'
                                          /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/TIG-AreaTextTag/TIG-AreaTextTag.rb;254;in `block in <module;AreaTextTag>'
                                          SketchUp;1;in `call'
                                          OSX 10.11.6 & Sketchup 2017
                                            @Oxer
                                            Thanks for the error report.
                                            Seems that that variable 'area2ever' was declared inside a {} block and not accessible later on in several circumstances !
                                            So it was an error waiting for a disaster for ~six years ! ...
                                            Anyway here is a corrected version 4.0
                                            PS: @srx
                                            Also added an extra option in the Settings to hide the Tag's text's edges [Yes|No]: defaults Yes - choosing No will show the edges [remember that if there are any existing Tags you will to use Update...]. That new Setting is remembered with each model...
                                            • 4 / 5
